patreilly43(at)hotmail.co Guest
Posted: Wed Mar 19, 2008 6:40 am Post subject: Intercom |
Kitfoxers, I am rebuilding a Mod 3 with a 582 Rotax engine and want to know what panel mounted intercom to install. I will be using an Icom A200 radio if that makes any difference. I am concerned about high noise level and squelech ability. What one should I use? Anybody out there have a good used one for sale?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Mar 19, 2008 7:04 am Post subject: Re: Intercom |
| Quote: | | Kitfoxers, I am rebuilding a Mod 3 with a 582 Rotax engine and want to know what panel mounted intercom to install. I will be using an Icom A200 radio if that makes any difference. I am concerned about high noise level and squelech ability. What one should I use? Anybody out there have a good used one for sale? |
Pat, Sigtronics has one that is supposed to be for high noise environments.
http://www.chiefaircraft.com/airsec/Aircraft/Intercoms/Sigtronics.html
My Kitfox is noisy in the cabin with that 2 stroke screaming out there. It's funny people sometimes comment how quiet it is when I fly over. Anyhow, I have a Comtronics but havent tried it yet. I will be anxious to see if anyone has some tips for dealing with the noise.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Wed Mar 19, 2008 7:27 am Post subject: Intercom |
Pat,
I have a Sigtronics SPA-400 and RES-2 Audio Switcher with Sigtronics
stereo headset. I also have an A200 radio. I don't have any real
experience with it however since it came installed in the damaged model
2 I bought to restore. So far I've only powered the panel to check the
radio and listened to ATIS. My plane has similar components to yours and
I think it should work well. The original builder I bought it from
seemed to like it.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Pat Reilly wrote:
| Quote: | Kitfoxers, I am rebuilding a Mod 3 with a 582 Rotax engine and want to
Pat Reilly
Mod 3 Rebuild
Rockford, IL
_________________ Rex
N740GP - M2/582
Colorado |
Guy Buchanan
Posted: Wed Mar 19, 2008 8:50 am Post subject: Intercom |
At 08:24 AM 3/19/2008, you wrote:
| Quote: | I have a Sigtronics SPA-400 and RES-2 Audio Switcher with Sigtronics
model 2 I bought to restore. So far I've only powered the panel to
check the radio and listened to ATIS. My plane has similar
components to yours and I think it should work well. The original
builder I bought it from seemed to like it.
I'm very happy with my SPA-400 and A200. The only thing I
would do over would be to pay more attention to wire routing, keeping
all electrical power generation wires well away from anything to do
with avionics. I've got a little alternator whine.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Posted: Wed Mar 19, 2008 10:25 am Post subject: Intercom |
Rex, What is a RES Audio switcher? Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford , IL
| Quote: | Date: Wed, 19 Mar 2008 09:24:50 -0600
Subject: Re: Intercom
--> Kitfox-List message posted by: Rexinator <hefferans(at)gmail.com>
Pat,
seemed to like it.
Rex Hefferan
> Pat Reilly
> Mod 3 Rebuild
> Rockford, I=============
Posted: Wed Mar 19, 2008 10:36 am Post subject: Intercom |
Tom, Thanks for the info. I saw that intercom in ACS catalog. I was hoping to find a used intercom, but will probably end up with a new one of those.
Pat Reilly
| Quote: | Subject: Re: Intercom
Date: Wed, 19 Mar 2008 08:04:30 -0700
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=170937#170937
Rex Hefferan
Posted: Wed Mar 19, 2008 7:42 pm Post subject: Intercom |
It's a circuit that allows alternate audio (music for instance) to be
heard while monitoring the communications channels. Any audio from the
communications radio will override/mute the music so you don't miss ATC
calls. Also a passenger can listen to music and not be interrupted by
ATC. The fellow who built my Kitfox installed a AM/FM casette radio in
the panel. I removed it (the AM/FM) and may install an MP3 player with
radio, I'm not sure. Having an AM/FM radio at altitude may make channel
isolation a problem at times I think.
Rex Hefferan
patrick reilly wrote:
| Quote: | Rex, What is a RES Audio switcher? Do not archive
Pat Reilly
Mod 3 Rebuild
Rockford , IL
> To: kitfox-list(at)matronics.com
> From: hefferans(at)gmail.com
> Pat,
and
> seemed to like it.
> Rex Hefferan
N740GP - M2/582
Colorado |
Float Flyr
Posted: Fri Mar 21, 2008 5:45 am Post subject: Intercom |
If your audio is powered by the engine you could try an RF choke on your
power line to notch out the whine.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
msm_9949(at)yahoo.com Guest
Posted: Sat Mar 22, 2008 6:51 am Post subject: Intercom |
Pat,
Rather that an intercom, I installed a Micro-Air M720 radio with side-tone that serves as an intercom. The unit is tiny, fits into a 2" hole and works great. The only disadvantage is that with the side-tone, the intercom mic is always "hot" can result in alot of background noise. To counter this I have a toggle switch to turn the intercom off/on. I advise passengers, "if you have to talk to me, flip this switch." Keeps the chit-chat down.
Pat Reilly <patreilly43(at)hotmail.com> wrote:
[quote] Kitfoxers, I am rebuilding a Mod 3 with a 582 Rotax engine and want to know what panel mounted intercom to install. I will be using an Icom A200 radio if that makes any difference. I am concerned about high [quote][b]
Posted: Sat Mar 22, 2008 7:20 am Post subject: Intercom |
Marco, Thanks for the info. I am still selecting intercoms to match up with my Icom IC-A200. Are you the Kitfoxer located in Puerto Rico?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
[quote] Date: Sat, 22 Mar 2008 07:42:13 -0700
Pat,
| Quote: | Kitfoxers, I am rebuilding a Mod 3 with a 582 Rotax engine and want to know what panel mounted intercom to install. I will be using an Icom A200 radio if that makes any difference. I am concerned about high | Quote: |
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
| [b]
andynfultz(at)bellsouth.n Guest
Posted: Sat Mar 22, 2008 6:40 pm Post subject: Intercom |
Pat,
I have no idea what the trade difference might be but Icom has a newer version of your radio that has several new bells and whistles. Among them is a built in voice activated intercom and dual watch. I think it's the IC-A210. NO new holes needed in the panel.
Andy F.
[quote] --
Posted: Sat Mar 22, 2008 8:46 pm Post subject: Intercom |
[quote] From: andynfultz(at)bellsouth.net
Subject: RE: Intercom
Date: Sat, 22 Mar 2008 21:37:51 -0500
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat,
Andy F.
[quote] --
Posted: Sun Mar 23, 2008 10:24 am Post subject: Intercom |
No, sadly, I'm in Michigan wishing I was in Puerto Rico.
[quote] [quote] [quote]Marco, Thanks for the info. I am still selecting intercoms to match up with my Icom IC-A200. Are you the Kitfoxer located in Puerto Rico?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
| Quote: | Date: Sat, 22 Mar 2008 07:42:13 -0700
Pat,
| Quote: | Kitfoxers, I am rebuilding a Mod 3 with a 582 Rotax engine and want to know what panel mounted intercom to install. I will be using an Icom A200 radio if that makes any difference. I am concerned about high | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List p://forums.matronics.com blank>http://www.matronics.com/contribution |
| Andy, I saw the new Icon A210
but purchased the 200 slaghtly used for $200 less than a new one so that's the way I went. I doubt if you will find a used 210 for awhile.Pat ReillyMod 3 RebuildRockford, IL Do not archive href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c | ============== x-List" target=_blank>http://www.matronics.com/Navigator?Kitfox-List ============== blank>http://forums.matronics.com ============== ==========" Be a better friend, newshound, and [quote][b]
