Posted: Fri Mar 21, 2008 4:47 pm Post subject: heated pitot to plastic tube connector |
Looked at archives and see questions on this but not the specific adaptor I'll need for the heated pitot tube copper connector to the plastic tubing I plan to use (instead of the aluminum).
anyone know what I need to make this connection happen?
Thanks!
Pascal
AV8ORJWC
Posted: Fri Mar 21, 2008 6:05 pm Post subject: heated pitot to plastic tube connector |
Tygon F4040-A Fuel and Lubricant tubing comes to mind. We use it on the turbine engines near a fuel transfer point with extreme heat near the exhaust stacks. Heat resistance is important but so is compatibility with cleaning solvents and hydrocarbons. YMMV.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Friday, March 21, 2008 5:44 PM
Subject: heated pitot to plastic tube connector
Thanks!
Pascal
 Download |
| Filename: |
tyf4040a.pdf |
143.63 KB |
| Downloaded: |
291 Time(s) |
Posted: Fri Mar 21, 2008 8:45 pm Post subject: heated pitot to plastic tube connector |
thanks John, what connector/connection/adaptor would I use to connect the copper connector from the pitot tube to this tubing?
Thanks!
Pascal
johngoodman
Posted: Sat Mar 22, 2008 10:45 am Post subject: Re: heated pitot to plastic tube connector |
Pascal,
What brand of heated pitot is it? Unless it's something unusual I'd think the adapters from Safair1 would work fine. Once you're about 5 or 6 inches away from the pitot, heat shouldn't be an issue. Scroll down this web page:
http://www.safeair1.com/index.htm
toaster73(at)embarqmail.c Guest
Posted: Sat Mar 22, 2008 5:07 pm Post subject: heated pitot to plastic tube connector |
Pascal
Here is a setup I copied for my salvaged cessna heated probe. I just have the total not the total and static as is shown. The nylon part I used was PN 266N04X04 from spruce.
http://bmnellis.com/images/Wings/Dcp01628.jpg
Chris Lucas
#40072
