patreilly43(at)hotmail.co Guest
Posted: Mon Mar 24, 2008 1:55 pm Post subject: skis |
Kitfoxers, Skis, I want to build a set of skis. I have pictures of 2 designs of wheel skis from this site. They look like great designs fabricated from steel tubing. One design is made of square tubing and the other is fabricated from round tubing I was wondering about what size wheels and tires to run. I have large 18" OD rough field tires similar to the Kingfoxes. I would imagine smaller, maybe 16" OD tires and narrower are what is needed. How do wheel skis mount on the axle? Do you need to swap in a longer axle to accept the ski bushings on either side of the wheel?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
henrysfork1(at)msn.com Guest
Posted: Mon Mar 24, 2008 2:28 pm Post subject: skis |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> There is lots of good info in the archives. Also John Perry knows stuff about skis, he would be a good source to ask questions.
Dee Young
Model II
N345DY
LarryM
Posted: Mon Mar 24, 2008 7:02 pm Post subject: Re: skis |
Hey Pat,
I have a set of skis that you could use as a pattern. I live in Genoa.
815-784-3476
larry
Lynn Matteson
Posted: Mon Mar 24, 2008 7:26 pm Post subject: skis |
Pat-
I built mine from round 4130 tubing. Tires are 16" OD, penetrate 2",
but I would make that less next time.
My inner mounts are pictured below, with some of the hardware shown.
I'm looking for pics of outer "axle."
The square aluminum block is bolted to the inner surface of the Grove
gear, and I added a zerk fitting to the ski at the bearing area. The
1/2" outer axle slides into the Grove axle.
This was a slow year for ski flying for me. Only about 27 hrs logged
since late Dec. Bad weather for the Oshkosh Skiplane Fly-in cut into
my available time this winter. They are off now.
Lynn Matteson
flying w/480+ hrs/down for annual
On Mar 24, 2008, at 5:51 PM, Pat Reilly wrote:
Quote: | Kitfoxers, Skis, I want to build a set of skis. I have pictures of
Pat Reilly
Mod 3 Rebuild
Rockford, IL
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
Description: |
Filesize: |
102.16 KB |
Viewed: |
620 Time(s) |
Description: |
Filesize: |
102.27 KB |
Viewed: |
542 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Mon Mar 24, 2008 7:51 pm Post subject: skis |
Lynn, Thanks for the photos. You really put some time and work into your skis. I saw a picture on the archives of a pair Deke Morisse built from plastic snowmobile skis(not wheel skis though) that are ingeniously simple.
Pat Reilly
Mod 3 Rebuild
Rockford,IL
Quote: | From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: skis
Date: Mon, 24 Mar 2008 23:17:12 -0400
Pat-
Posted: Mon Mar 24, 2008 7:53 pm Post subject: skis |
Larry, Thanks, I plan on coming over there when it warms up. I want to mwwt you.
Do not archive.
Pat Reilly
Lynn Matteson
Posted: Tue Mar 25, 2008 3:42 am Post subject: skis |
Thanks, Pat...the next pair will be wider, and maybe repositionable.
I may even try my hand at making them out of aluminum sheet instead
of the tubing.
Lynn Matteson
On Mar 24, 2008, at 11:48 PM, patrick reilly wrote:
Quote: | Lynn, Thanks for the photos. You really put some time and work into
ingeniously simple.
Pat Reilly
Mod 3 Rebuild
Rockford,IL
> Subject: Re: skis
> To: kitfox-list(at)matronics.com
> Pat-
contribution_-
N369LM |
Posted: Tue Mar 25, 2008 6:42 am Post subject: skis |
Lynn, You mean your going to build anothe pair! I saw a pair of ingeniously adapted plastic snowmobile skis done by Deke Morrisse on www.sportflight.com. They are the other end of the spectrum in time and $ spent from yours. I just might use his technique and add skateboard wheels protruding through the bottom to roll in and out of the hanger.
Pat reilly
Mod 3 Rebuild
Rockford, IL
Subject: Re: skis
Date: Tue, 25 Mar 2008 07:39:45 -0400
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Thanks, Pat..the next pair will be wider, and maybe repositionable.
of the tubing.
Lynn Matteson
> ingeniously simple.
> Do not archive
> Pat Reilly
> Mod 3 Rebuild
> Rockford,IL
> > Subject: Re: skis
> > Pat-
> ========== _-
> ========== _-
> contribution_-
Lynn Matteson
Posted: Tue Mar 25, 2008 9:54 am Post subject: skis |
I get so much drag with the tires poking through as far as they do,
and if I was to reduce that penetration to 1" instead of 2", I could
close up the hole that the tire protrudes through. Or, another school
of thought is to make the skis hydraulically operated, and instead of
a hole in the shoe for tire protrusion, make a notch like I have seen
on other skis, where the tire fits into a notch. Then the ski is
kinda "L" shaped, with the wide part of the ski out front like the
bottom of the "L", and the tire fitting into the notch which is the
included angle between the bottom of the "L" and the vertical part.
With this arrangement, there is no part of the shoe that will try to
undercut the snow and cause drag. This is what I fight now with shoe
area right behind the tire. I've seen this type of ski in pictures,
and I've surmised that it could be built as a rigid setup, or
possibly as a hydraulically-actuated lowering ski, that would take
the tire drag right out of the picture.
As a sport Pilot, I might not be able to get away with any form of
"repositionable" landing arrangement, however the FAA has approved
repositionable wheels for a couple of models of LSA water-landing
crafts, so the door has been opened.
I think it would be fun to try and make them out of aluminum sheet,
formed and riveted into a structural shape, then apply the nylon/
plastic/UHMW material on the bottom as a means to keep the shoe from
freezing/sticking to the surface.
I've seen pictures of Deke's, and his (no wheels) work well up in his
"neck of the woods" where they get more snow than down south here,
and it probably stays around longer. Down south here...160-some
miles...the snow comes and goes all winter long. Deke might even be
subjected to more lake effects snow, being close to Lake Huron. I am
lower mid-state, and we kind of get what's left over from battering
both sides of the state with snow. So, due to the vagaries of our
snowfall, I need wheels on the plane all the time.
Just thinking out loud some of the reasons for building mine the way
I did/do.
Lynn Matteson
On Mar 25, 2008, at 10:35 AM, patrick reilly wrote:
Quote: | Lynn, You mean your going to build anothe pair! I saw a pair of
of the hanger.
Pat reilly
Mod 3 Rebuild
Rockford, IL
> Subject: Re: skis
> of the tubing.
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
into
> > ingeniously simple.
> > Do not archive
> > Pat Reilly
> > Mod 3 Rebuild
> > Rockford,IL
> > > Subject: Re: skis
> > > Pat-
penetrate 2",
shown.
> > ========== _-
> > ========== _-
> > contribution_-
contribution_-
N369LM |
avidfox
Posted: Tue Mar 25, 2008 10:14 am Post subject: skis |
Got ya covered Lynn...
[url=http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgFinalRule.nsf/0/db3949786adf3cf6862572c600597b19!OpenDocument]http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgFinalRule.nsf/0/db3949786adf3cf6862572c600597b19!OpenDocument[/url]
Federal Aviation Administration
14 CFR Part 1
[Docket No. FAA-2007-27160; Amendment No. 1-56]
RIN 2120-AI97
Changes to the Definition of Certain Light-Sport Aircraft
Preamble Information
AGENCY: Federal Aviation Administration (FAA), DOT.
ACTION: Direct final rule; request for comments.
SUMMARY: This action corrects an unintended consequence created when we adopted the original Light-Sport Aircraft (LSA) Rule; we did not have sufficient information at that time to foresee this difficulty. This action amends the definition of an LSA in two areas. The changes will (1) permit development of lighter-than-air (LTA) LSA, and (2) allow retractable landing gear for LSA intended for operation on water. The LTA change will result in a common land-based LSA maximum takeoff weight limit and allow the LTA LSA industry to design and build safe, functional LTA aircraft. Allowing retractable landing gear for LSA intended for operation on water recognizes the realities of the operation of these LSA and will also enhance the growth of that industry.
Steve
84KF
KF5\912UL
avidfox
Posted: Tue Mar 25, 2008 10:16 am Post subject: skis |
Opps skis...not floats...my bad.
Steve, with foot in mouth [quote][b]
Michel
Posted: Tue Mar 25, 2008 10:35 am Post subject: skis |
Yep! Good thinking, Lynn! I haven't used my skis this winter because the snow hasn't come ... before now. But my experience is exctly the same as yours and your L-shape idea sounds very good to me.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Posted: Tue Mar 25, 2008 10:41 am Post subject: skis |
Lynn, Yes the wheel skis are much more convient in our witer climate where snow comes and goes. I was just impressed with the simplesity of his adaption.
Pat Reilly
Date: Tue, 25 Mar 2008 13:50:19 -0400
I did/do.
Lynn Matteson
> of the hanger.
> Do not archive
> Pat reilly
> Mod 3 Rebuild
> Rockford, IL
> > Subject: Re: skis
> > of the tubing.
> > Lynn Matteson
> into
> > > ingeniously simple.
> > > Do not archive
> > > Pat Reilly
> > > Mod 3 Rebuild
> > > Rockford,IL
> > > > Subject: Re: skis
> > > > Pat-
> penetrate 2",
> shown.
> > > ========== _-
> > > ========== _-
> > > contribution_-
> ========== _-
> ========== _-
> contribution_-
Lynn Matteson
Posted: Tue Mar 25, 2008 10:59 am Post subject: skis |
Thanks, Steve....I'd take their words "(2) allow retractable
landing gear for LSA intended for operation on water" and go with
it. My thinking is that it's not my fault that "their" water got
turned to snow or ice. : ) Jeez...I shoulda been a lawyer!
Lynn Matteson
14 CFR Part 1
RIN 2120-AI97
Steve
84KF
KF5\912UL
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
N369LM |
Lynn Matteson
Posted: Tue Mar 25, 2008 11:04 am Post subject: skis |
Just to keep me from getting a swelled head, it wasn't my idea for
the "L" shape...I'm just seeing what others have built and borrowing
their ideas.
Thanks, Michel...
Lynn Matteson
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
akflyer
Posted: Tue Mar 25, 2008 11:09 am Post subject: Re: skis |
[quote="avidfox"]Opps skis...not floats...my bad.
Steve, I would argue that the snow or ice that Lynn would be landing on is actually water that is a bit cold.. I would argue it just the same as they did for amphibs, and get a ruling that retractable skis are no different.
Just my argumentative side, that I am sure you were unaware I had.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
avidfox
Posted: Tue Mar 25, 2008 11:14 am Post subject: skis |
Ya should have worn that helmet.....
Lynn Matteson
Posted: Tue Mar 25, 2008 11:38 am Post subject: skis |
And to set the record even straighter, it was Leonard's brother John
that sent me some valuable info when I was building my skis. This was
before he went back to the frozen tundra, right Leonard?
Lynn Matteson
> [b]
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=172595#172595
N369LM |
avidfox
Posted: Tue Mar 25, 2008 11:39 am Post subject: skis |
Look at it this way:
The aircraft configuration is intended for use on land, and IAW the regs, landing gear IS fixed....Nothing in the regs say the skis cannot used, or that said skis cannot be retractable.
As always, we must not make things seem worse by ASSUMING the FAA says something, when in reality, they haven't.
Steve
84KF
akflyer
Posted: Tue Mar 25, 2008 12:11 pm Post subject: Re: skis |
Lynn, that is correct that John sent the drawings I think, also correct he is my brother.
One trick we use is to have a plate that covers the hole in the ski so when we get out in the back country, and find ourselves in deep snow, you let the air out of the tire, roll the plate between the ski and tire then put enough air back in the tire to hold it. This will make a virtually impossible takeoff very easy. I know guys that landed just fine but there was too much drag for them to be able to take off again with wheel penetration skis. The spent alot of time on snowshoes packing a runway.
The best way I have seen to make this plate it to make your cut out in the ski at a bevel not a straight cut. Then you cut out your plate on a bevel so it will drop in flush with the cut out. You have then made a set of normal straight skis with very little drag in the snow.
Steve, a VERY valid point. the wheels would remain fixed therefor the primary gear is fixed, not retractable... very good point, i would argue that one all day long too, but then again, I just love to argue, especially with an official.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
