avidfox
Posted: Tue Mar 25, 2008 9:48 am Post subject: Contest: Identify this instrument.... |
A while back I tried to research the origin and original installation of this instrument. No luck. (Yes, I Googled... I haven't tried recently. )
I will gladly send one like it, (I have more than one) to the person who can provide the most accurate information, such as age and what type of aircraft (if any) it was originally used in, for the cost of shipping only...a couple bucks at the most.
Web references will be a plus.
It is a high-quality instrument, about a 1/2 pound or so, and very sensitive to pitch change on its longitudinal axis. The attached pictures show it both caged and uncaged.
The pointers are adjustable via the knob in front, caging is done at the rear.
Just to keep the post KitFox related, let me say that I plan to (temporarily) replace my VSI with one just to see how it behaves in flight.
Steve
84KF
KF5\912UL
Description: |
Filesize: |
620.99 KB |
Viewed: |
737 Time(s) |
Description: |
Filesize: |
619.98 KB |
Viewed: |
684 Time(s) |
Description: |
Filesize: |
641.29 KB |
Viewed: |
643 Time(s) |
Description: |
Filesize: |
615.16 KB |
Viewed: |
712 Time(s) |
akflyer
Posted: Tue Mar 25, 2008 11:15 am Post subject: Re: Contest: Identify this instrument.... |
Steve, that is an inclinometer that is used as an early stall warning device. If you do go past a certain angle of attack you don't fall out of the sky. It was first used in under powered birds that did not have a power to weight ratio worth a whooey. (the kitfox has a much better power to weight ratio)
I will pm my address to you LOL
do I get a prize for first answer pulled directly from my... uh .. uh... behind?
edit... I pulled the above from my butt, however here is a link... I was basically right lol
http://airex.org/aeronautica01.html
edit #2... I just noticed the serial number... the one you are holding in your hand is the one shown in the link above.... guess you already knew about the link huh.. your getting good at making me look dumb LOL
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
greg(at)case-assembly.com Guest
Posted: Tue Mar 25, 2008 11:21 am Post subject: Contest: Identify this instrument.... |
Take a look at http://forgottenfield.com/amg/instrument/
Fourth from the bottom. I believe it may be a B17 nose pitch gauge.
Greg
N42001 KF-IV in refurb
N81774 PA-32-301 Saratoga
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Mar 25, 2008 11:54 am Post subject: Re: Contest: Identify this instrument.... |
greg(at)case-assembly.com wrote: | Take a look at http://forgottenfield.com/amg/instrument/
Greg
That picture is a match. What is the purpose of such an instrument? I'll take a wild guess at something to do with glider towing.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
avidfox
Posted: Tue Mar 25, 2008 12:16 pm Post subject: Contest: Identify this instrument.... |
"I believe it may be a B17 nose pitch gauge"
I realize that the following link is not an "original picture", and does not represent all models produced, buI don't see the instrument installed.
http://b17panels.com/id13.html
And leni....go wash your hands...please.
Steve
84KF
Float Flyr
Posted: Tue Mar 25, 2008 3:53 pm Post subject: Contest: Identify this instrument.... |
Certainly looks like some sort of attitude indicator just wondering if the
two flat head screws on the back adjust the two bugs on the front dial.
Also is there an electrical connection on the back below where the picture
ends?
I don't think I'd use this instead of a VSI but it could be fun getting your
attitude right for landing.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
msm_9949(at)yahoo.com Guest
Posted: Tue Mar 25, 2008 5:30 pm Post subject: Contest: Identify this instrument.... |
I'll take a stab.
I've seen some like it on e-bay. It's a WWII vintage (1943) inclinometer. Could have been used in any number of warbirds from that era but I'm sure I've seen them in B-24 panels.
avidfox <avidfox(at)gmail.com> wrote:
[quote]--> Kitfox-List message posted by: "avidfox"
It is a high-quality instrument, about a 1/2 Be a better friend, newshound, and [quote][b]
avidfox
Posted: Tue Mar 25, 2008 6:55 pm Post subject: Re: Contest: Identify this instrument.... |
"I don't think I'd use this instead of a VSI but it could be fun getting your
attitude right for landing."
Noel, (and all)
Pitch attitude\landing...My thinking exactly...(in combination with PROPER airspeed )
Here is a few pics of the instrument I will "try" in flight next. It has BOTH inclinometer and VSI function.(meters per second)
Same size mounting, metric installation screw threads. The vertical tube contains amber colored liquid, somewhat viscous, for dampening the movement. The flecks behind the glass don't show up under normal lighting.
The only person who will get this one is the first single blond (female..., female, Leni ) who shows up at my doorstep with a Porsche.
Still waiting for confirmation on the Jeager instrument.
"Confirmation....I need confirmation."
(Tora Tora Tora)
Steve
84KF
Description: |
Filesize: |
355.84 KB |
Viewed: |
649 Time(s) |
Description: |
Filesize: |
330 KB |
Viewed: |
672 Time(s) |
Mo
Joined: 29 Jan 2006 Posts: 14 Location: Massachusetts
Posted: Tue Mar 25, 2008 7:09 pm Post subject: Contest: Identify this instrument.... |
Looks like a pitch versus the horizon meter, a precursor to the angle of
attack meter.
Maurice
Kitfox 7A, 912S, IVO GA, building
Jim Shumaker
Posted: Tue Mar 25, 2008 8:03 pm Post subject: Contest: Identify this instrument.... |
Rate of climb and Pitch on the same meter. Where is that used?
Jim Shumaker
_________________ Jim Shumaker |
