		John Williamson
  Joined: 10 Jan 2006 Posts: 146 Location: Arlington, TX
				 Posted: Mon Mar 24, 2008 5:08 pm    Post subject: The Numbers Don't Lie |
				All this speculation on what and how the Xtra does or will perform made me go flying today and get some numbers.
 Pressure Altitude: 2500 feet, 52 degrees F.
 5480 rpm: 90 kts
 5000 rpm: 80 kts
 4500 rpm: 70 kts
 4000 rpm: 57 kts
 The airplane is rigged to the factory specs.
  _________________ John Williamson
Arlington, TX
Kolbra, 912ULS, 1640 hours
http://home.tx.rr.com/kolbrapilot |
		ElleryWeld(at)aol.com Guest
				 Posted: Mon Mar 24, 2008 5:53 pm    Post subject: The Numbers Don't Lie |
				Thanks John W  that is the kind of info I  was looking for that will help me make my mind up if I can get more from someone  else to compare it with
   some day it might warm up here so I can enjoy a  day of  flying my self
  Ellery from Maine
   if you dont think America is falling apart   take a drive across Maine  it will change your mind real quick ,The roads  are terrible here
   In a message dated 3/24/2008 8:11:35 P.M. Eastern Standard Time,  kolbrapilot1(at)tx.rr.com writes:
   	  | Quote: | 	 		  -->    Kolb-List message posted by: "John Williamson"    <kolbrapilot1(at)tx.rr.com>
 5480 rpm: 90    kts
 5000 rpm: 80 kts
 4500 rpm: 70 kts
 4000 rpm: 57 kts
 do not    archive
 John Williamson
 Arlington, TX
 Kolbra,    912ULS, 1580    hours
 Read this topic    online    here:
 http://forums.matronics.com/viewtopic.php?p=172396#172396
 Create a Home Theater Like the Pros. Watch the video on AOL Home.
				 Posted: Mon Mar 24, 2008 7:10 pm    Post subject: The Numbers Don't Lie |
				Hey John W
 Not everyone knows that you fly a 100HP Rotax powered Kolbra. I assume the
 figures were in that bird. It would drive these guys crazy trying to match
 those numbers in a Xtra.
 Rick Neilsen
 Redrive VW powered MKIIIC
		John Williamson
				 Posted: Mon Mar 24, 2008 7:26 pm    Post subject: Re: The Numbers Don't Lie |
				Hi Rick and All,
 Of course those numbers are for my Kolbra!
 I tell everyone what I fly in my signature block on every post.
Arlington, TX
		Thom Riddle
				 Posted: Tue Mar 25, 2008 4:56 am    Post subject: Re: The Numbers Don't Lie |
				Before I bent the early FS, I had the following numbers.
 Early FS, no wheel pants, no streamlined struts, empty wt. 362 lb., 447, 40hp
 Power Fin, 2-blade, 62" long, pitched for 6500 rpm WOT S&L
 2000' Density Altitude
 Note these are Indicated Airspeeds with unknown TAS
 IAS(mph)/   RPM/                           Fuel Burn Estimate (gph)
 80/             6,500
 69/             5,700 (~75% power)/    3.0
 64/             5,600 (~65%)/              2.6
 59/             5,300 (~55%)/              2.2
 53/             4,900 (~45%)/              1.8
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		JetPilot
				 Posted: Tue Mar 25, 2008 5:59 am    Post subject: Re: The Numbers Don't Lie |
				Those are impressive numbers John,  I dont think a MK III will ever match that, just to much Xtra drag with the wide fuselage.
 Is 5480 Max Thottle ?  What RPM do you get on climbout ?   What are you stall speeds like ?
 BTW 90 KTS = 103.7 MPH !!!     How does it feel at that speed ?
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		travis(at)tnkolbaircraft. Guest
				 Posted: Tue Mar 25, 2008 6:33 am    Post subject: The Numbers Don't Lie |
				John, how are the tips configured now?  stock kolb or chopped end?
 We need apples to apples.  -Also a flat plate fence would be
 interesting.
 Good luck with the breezes.
 BB
 On 25, Mar 2008, at 10:05 AM, Travis Brown (Kolb Aircraft) wrote:
  <travis(at)tnkolbaircraft.com>
 > 5480 rpm: 90 kts
 > 5000 rpm: 80 kts
 > 4500 rpm: 70 kts
 > 4000 rpm: 57 kts
  > John Williamson
  John W:
  Ain't fair!
  How come my chubby little mkIII won't fly as fast as your skinny
  little Kolbra?
  Reckon my horizontal stabilizer is mounted upside down?
  Getting ready to do some more flying in the new X before the
  forecast winds arrive in London.  We are looking for 20 to 30 mph
  gusting to 40.  Maybe I can try some cross wind landings this
  afternoon.
  Testing is progressing.  We plan to mount the droop tips tomorrow.
  If I can get some calm air I can come up with some numbers without
  the tips.  This block of time has not been conducive to flying.
  Labhart Field, KY - 24F climbing through 31F
				 Posted: Tue Mar 25, 2008 7:52 am    Post subject: The Numbers Don't Lie |
  > BB
 Bob B:
 The wing section is 13 feet long and chopped off at the end.  It is the same
 length as the FSII wing section including the bowtip.  With the new droop
 tips, the wing section will be about 14 feet.
 I just landed from my morning flight.  Air is cold, 35F, and wind is brisk.
 The X has 20 and 45 degrees of flaps.  She stalled at 32 mph IAS and 30 mph
 IAS at 3,000 feet ASL.
 This airplane is more a rudder airplane than any other Kolb I have flown,
 yet it flies and handles much like all the other models.
 I did some maximum climbs this morning.  This airplane climbs at a near
 vertical attitude.  It feels and looks nearly vertical when it is screwing
 its way into the air.  At one point the engine quit while climbing.  I have
 never had this happen in a Kolb.
 I have a much better atttitude about this X than any of the others I have
 flown.  Might be because of changes between the models and the fact that I
 have assisted in tweaking this one to fly the way I like them.
 Labhart Field, KY
		Thom Riddle
				 Posted: Tue Mar 25, 2008 9:25 am    Post subject: Re: The Numbers Don't Lie |
				For those who care, here is one theoretical comparison of the Droop Tips vs. Hoerner style tips (a la Possums).
 http://selair.selkirk.bc.ca/aerodynamics1/Drag/Page8.html
 Go to the link and page down to see the brief bits on each.
 FWIW, I've owned airplanes with both types of wing tips. I've flown Cherokees with the standard Hershey bar wing and owned one with the Hoerner type wing tips. The Hoerner wing tips definitely made the slow speed handling a lot better in all respects including a little slower stall speed, at least in the air but don't know about in ground effect 'cuz I don't watch the ASI when in ground effect.
 I also owned a Titan Tornado with the droop tips and it would climb at incredible angles of attack, even with the short 20' wing with 80 hp Rotax. Its stall behavior was completely benign and quite slow speed for such a small wing.
 What I've read, but can't find now, is that both types will improve slow speed handling and reduce stall speed (increase critical angle of attack). In that same article I can't find now, it said the primary difference between the two is that typically the Droop Tips cause a more abrupt stall. That was not the case in my one airplane experience.
Buffalo, NY (9G0)
- Anonymous |
		John Williamson
				 Posted: Tue Mar 25, 2008 9:31 am    Post subject: Re: The Numbers Don't Lie |
				 	  | JetPilot wrote: | 	 		  Those are impressive numbers John,  I dont think a MK III will ever match that, just to much Xtra drag with the wide fuselage.
 Mike |
 Hi All,
 Yes 5480 rpm is full throttle, I couldn't prop it to hit 5500 rpm exactly.
 Climbout rpm is dependent on airspeed and angle of climb so it is not very relevant. Climb rate will vary from 500 fpm to 1400 fpm depending on what is in the pattern behind and in front of me.
 Stall speed is a good reference number for some I guess. The only three times I see the stall speed is accellerating thru it with the wheels on the runway, decelerating back thru it with the wheels on the runway and when actually doing stalls at least 1500 feet above the ground.
 I see 96 kts (110.4751 mph) on almost every flight. It feels like a Kolb.
 I also should have said that my speeds are calibrated airspeeds, not just indicated airspeeds. If you have an error in your IAS, you should adjust it out or make a calibration card to go beside your IAS indicator. For the folks that like TAS, I had included the PA and Temp so you can figure the TAS.
Arlington, TX
  Last edited by John Williamson on Tue Mar 25, 2008 10:20 am; edited 1 time in total |
		JetPilot
				 Posted: Tue Mar 25, 2008 9:37 am    Post subject: Re: The Numbers Don't Lie |
				[quote="travis(at)tnkolbaircraftI did some maximum climbs this morning.  This airplane climbs at a near
 Labhart Field, KY[/quote]
 That is incredible, but what caused the engine out ?  Could it be that the climb was so steep that it the fuel in the carb bowls was to far from level, or the fuel moved back in the tank away from where it is picked up ?
 Mike
				 Posted: Tue Mar 25, 2008 10:49 am    Post subject: The Numbers Don't Lie |
 Mike B:
 First question:  Probably fuel starvation from the floats closing the float
 valves.
 Flew again later and could not get the X to climb like it did early this
 morning.  Climbed like any other Kolb, stick full back, climbing until the
 prop started cavitating, but still climbing.
 Labhart Field, KY
				 Posted: Tue Mar 25, 2008 11:14 am    Post subject: The Numbers Don't Lie |
				 	  | Quote: | 	 		   I have a much better attitude about this X than any of the others I have
  Labhart Field, KY
   John,
    You crack me up!!  You're sounding like the guy that just got back from test-driving
  a 2009 Pickup.....and saying "hey, can I get this in metalic silver.   5 more minutes, and you're hooked!!
  You may as well make a $12,000 donation to TNK right now!   ha ha ha ha!   (Don't be mad at me, I'm just
  funnin' ya!)
    I have a little favor to ask of you.  Since you get the impression that this new MkIIIXtra fly fairly well, would it be possible for you to take a reading of the main wings' and the hor. stabs incidences, and the boom tube.  No need to go to any elaborate measures, just a quick reading of the bottom of the wing, and the top of the stabs, and the boom tube.  That way, I can set my boom tube to your reading, and then set my incidence the same the plane you're flying.  I'll bring you a cold beer at Monument Valley.  Thanks
  Mike Welch
 Watch “Cause Effect,” a show about real people murce=text_watchcause' target='_new'>Learn more.  [quote][b]
		dhkey(at)msn.com Guest
				 Posted: Tue Mar 25, 2008 2:42 pm    Post subject: The Numbers Don't Lie |
				Sorry I found that photo on John's site but it doesn't look like his plane.  [quote][b]
		John Williamson
				 Posted: Tue Mar 25, 2008 2:58 pm    Post subject: Re: The Numbers Don't Lie |
				 	  | dhkey(at)msn.com wrote: | 	 		  | Sorry I found that photo on John's site but it doesn't look like his plane.  |
 That photo is one I took looking directly up the tail of a Titan with the fuselage blocking the sun.  Hence, one of many of my favorite photos I have taken.
Arlington, TX
		ez(at)embarqmail.com Guest
				 Posted: Tue Mar 25, 2008 6:11 pm    Post subject: The Numbers Don't Lie |
				Don't click this link if you want to see a kolbra.
 On Mar 25, 2008, at 6:34 PM, David Key wrote: 	  | Quote: | 	 		  Don't click this link if you have dial up.
 Here's a great photo of JohnW's skinny plane
 http://home.tx.rr.com/kolbrapilot/index_files/IMG_0530.JPG
  	  | Quote: | 	 		  http://www.matronics.com/Navigator?Kolb-List
		John Bickham
  Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
				 Posted: Tue Mar 25, 2008 6:30 pm    Post subject: Re: The Numbers Don't Lie |
				One of my most favorite things is flying XC trips with John Williamson.  Always fun and always learn something new.  The only negative is, while I'm peddling as fast as I can, he and the Kolbra are zooming and diving all over the place.  He can make a pit stop on a 2 hour leg and still climb back up with me in a matter of minutes.
 Still fun, just a little aggravating in a good way.
  _________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators.  There is a distinct difference that I have the greatest respect for. |
		JetPilot
				 Posted: Wed Mar 26, 2008 6:20 am    Post subject: Re: The Numbers Don't Lie |
				John Willamsons Web Site and videos are great.  Even if you have a slow connection, its worth the time it takes to load the pictures and watch the videos.
 Mike
