		zk-vii(at)rvproject.gen.n Guest
				 Posted: Mon Mar 24, 2008 12:51 pm    Post subject: B&C SD-20 and magnetic interference |
				Hi,
 We have been running for about 20 hours now chasing different problems.  One
 outstanding one is magnetic interference from the SD-20 / LR3 combination.
 We have a TSO'd vertical card compass (and yes it is a southern hemisphere
 model) mounted in the middle of the panel area (center/center).  We are dual
 alt / dual bus configuration.
 When the field wire is connected to the SD-20 (lower connection) we get up
 to 40 degree swing on the compass - it does vary in amount (from 20-40
 degrees) based on direction - south seems the worst.  Pulling the field
 breaker causes it swings back about 30 degrees, but the regulator / alt are
 still have an affect.
 B&C are saying some swing is 'normal' - but 40 degrees - I'm struggling!  I
 can't calibrate that much out (best effort so far is +- 15 degrees).
 I've tried changing the location / orientation of the regulator - no
 difference.  I've tried moving another wet compass around the panel /
 cockpit - it looks like same problem (although a bit hard to tell).
 I've tried running some grounded braid around the firewall forward side of
 the field wire - no change.  Same symptoms on ground, air, zero RPM and full
 power.  There may be a small movement (< 3 degrees) based on current draw
 from SD-20.  With SD-20 field disconnected and X-Feed in - no movement.
 Questions:
 	a) Have others got this / solved this?
 	b) Any suggested methods of screening the SD-20?
 Carl
 Carl Morgan - ZK-VII - RV 7A
 http://www.rvproject.gen.nz/
 Checked by AVG.
 15:03
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		nuckolls.bob(at)cox.net Guest
				 Posted: Tue Mar 25, 2008 3:17 am    Post subject: B&C SD-20 and magnetic interference |
				At 09:44 AM 3/25/2008 +1300, you wrote:
 <zk-vii(at)rvproject.gen.nz>
 Hi,
 Questions:
 Carl
     The problem is magnetic, not electrical.
     Had this problem on the Bonanza too. The SD-20
     (as do most alternators) has a considerable
     leakage of magnetic flux from the rotor winding.
     This isn't a problem for most installations
     where the alternator mounts on the front of
     the engine.
     Alternators hung on the rear of the engine
     are much closer to the instrument panel and
     more likely to be an issue with a panel
     mounted compass.
     In the Bonanza, we moved the compass off the
     glareshield to a location on higher on the
     windshield. Adding a magnetic shield around
     the SD-20 is a pretty busy task. The shield
     material would have to be magnetic and cover
     the rear and perhaps the circumference of the
     alternator. This has some issues with cooling,
     wiring egress and labor to implement it.
     The easiest fix is to increase distance between
     the compass and the alternator. Magnetic
     'radiation' is a weak propagator . . . a little
     distance really helps.
     Alternatively, an electronic compass with
     a remote sensor out in a wing is the best
     way to achieve the highest performance
     in a magnetic direction indicator. The
     case can be made that since you have
     3 sources of DC power, reliability of
     the electronic compass is assured. I would
     also hope that you carry a hand-held GPS
     in the flight bag too.
     I'm not sure I'd bother to install a
     whisky compass any more. Likelihood of
     ever needing one these days is about nil.
     Same thing happened to buggy whips. We
     were fortunate not to be plagued by the
     FHA (Federal Horsecart Administration)
     when the transition occurred. Hmmmm . . .
     maybe they didn't really go away . . .
     they just morphed into radio antennas.
     Let's be really clear about this condition.
     This is NOT a downside checkmark on the blackboard
     for the B&C SD-20. ALL alternators have a steel
     shaft that runs through the device parallel
     to the magnetic lines of force generated in
     the field windings. See:
 http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Internal_Fan2.gif
     This mechanical feature insures that EVERY
     alternator will present a strong external
     magnetic field. It's a system integration problem
     that seldom presents but has multiple solutions
     for maintaining flight-system reliability. The
     REAL problem is getting those-who-know-more-
     about-airplanes-than-we-do to join us in
     the 21st century.
				 Posted: Tue Mar 25, 2008 12:45 pm    Post subject: B&C SD-20 and magnetic interference |
				Hi Bob,
 Removing the 'whiskey compass' could / will result in my aircraft being
 grounded.  I have been round the loop with the NZ CAA and the 'need' for a
 traditional compass, I already have a GRT EFIS with magnetometer, IFR GPS
 and still not enough.  At the moment it is going to be an up cliff paperwork
 struggle.
 Removing the SD-20 is a 'better' option from their perspective, but with a
 full FADEC I'm not comfortable with just dual battery, single alternator -
 and having got to this point where the engine is running great (or too well)
 removing the SD-20 isn't an option either.  Distance changing is going to be
 in the order of 1" difference, unless I mounted it in the baggage
 compartment.  What options can be used to reduce the magnetic impact - is it
 a luck of the draw with the SD-20 - ie. they all vary abit?  We are only
 taking 3-4 amps under normal operations.  I understand some interference
 coming out, but what is 'too much'?
 WRT:
  	  | Quote: | 	 		       This is NOT a downside checkmark on the blackboard
      the field windings.
 My biggest complaint is there is NO indication or warnings about this
 anywhere in the instruction / website information - I would have
 reconsidered the panel layout with this information, as it is I'm fixed
 without major rework and it is affecting my Autopilot backup and one of the
 few instruments the regulator is specifically interested in....
 How can I reduce this interference at the source - hopefully a small
 reduction will be enough to get calibration within spec.
 Carl
 [quote] --
		mprather(at)spro.net Guest
				 Posted: Tue Mar 25, 2008 3:07 pm    Post subject: B&C SD-20 and magnetic interference |
				Are _you_ concerned about the function of the whiskey compass?  If not
 (given the other equipment on board), do your best to come up with a
 calibration card for it and call it good.
 Side question..  I got the impression that your compass reads accurately
 when the field is turned off on the SD-20.  Can the SD-20 be used only
 when your main alternator is off line?  If so, the only time your compass
 will have a problem is if the main alternator fails.  I could live with
 that..
 Also, what's the wire routing of the output and field of the SD-20 (with
 respect to the compass?  Is it possible that the wire routing is
 contributing to the B-field generated by the SD-20?  Is the ground
 following a different route than the field and output wires?  I'm pretty
 sure Bob's assessment of the cause of your headache was correct, but I
 wonder if there might be additional factors...
 In a different direction, you can get a remote compass from Century
 Instruments:
 http://www.trade-a-plane.com/dispads/0000769074.pdf
 Kinda spendy at $500 for the kit..  And, I don't know if it actually
 satisfies the requirement.
 Matt-
  Hi Bob,
  paperwork
  struggle.
  well)
  be
  it
  WRT:
 >     the field windings.
  the
  Carl
				 Posted: Tue Mar 25, 2008 3:54 pm    Post subject: B&C SD-20 and magnetic interference |
				Hi Matt,
 Thanks for the ideas, I'm really not that concerned about the whiskey
 compass functionality - if I've lost all my other mag direction indicators -
 the engine has stopped, so I don't really care about direction    However
 the CAA so far is and the calibration card per regs has to be within 10
 degrees  .
 SD-20 off / disconnected - yes I think the compass reads right - but we are
 dual bus (two independent active buses), not endurance / essential bus - so
 both alts need to be running / working.
 Wire routing - the B lead and field goes aft from the SD-20 to the firewall,
 left across the top of the firewall, aft again through the firewall and back
 to a mid location for the regulator which is on a tray between the forward
 panel ribs (RV 7A Tipup).
 Remote compass - it could yet be the option - but I don't like to even think
 about the routing of the cables through the tunnel / spar / wing.....
 Carl
 [quote] --
		khorton01(at)rogers.com Guest
				 Posted: Tue Mar 25, 2008 5:21 pm    Post subject: B&C SD-20 and magnetic interference |
				There are type certificated aircraft where the whiskey compass is
 only accurate in a very particular electrical system configuration.
 For example, on the Cessna C550 (Citation II business jet), the
 whiskey compass is only useable if both generators are OFF.  This is
 quite acceptable to the FAA, Transport Canada, and I presume the NZ CAA.
 Given that you have an EFIS with a remote flux valve that acts as
 your primary source of magnetic heading, you don't need the whiskey
 compass to read accurately most of the time.  I wonder if it might be
 acceptable to put a placard by the whiskey compass that said "SD-20
 Alternator must be OFF to use compass".  Then make a compass
 correction card that is only valid if the SD-20 is OFF.
 Kevin Horton
  Hi Matt,
  indicators -
  However
  within 10
  degrees  .
  but we are
  bus - so
  firewall,
  and back
  forward
  even think
  Carl
				 Posted: Wed Mar 26, 2008 3:33 am    Post subject: B&C SD-20 and magnetic interference |
				At 12:51 PM 3/26/2008 +1300, you wrote:
 Hi Matt,
 degrees  .
    If you have a cross-feed, then just about every individual who knows-
    more-about-airplanes-than-we-do will accept a fall back position for
    dealing with failures that might present other limits as well.
    Assuming that all other "normal" methods for pointing the nose in
    the right direction are no longer available, then shutting the SD-20
    OFF, closing the cross-feed contactor, reducing total loads to that
    of the main alternator and flying with a now acceptable performance
    from the antiquated pointing device is a perfectly valid 'plan-B'.
  	  | Quote: | 	 		  Wire routing - the B lead and field goes aft from the SD-20 to the firewall,
    The B-lead comes into the cockpit? Where are your batteries? The
    B-lead can and should be well away from the instrument panel and
    tie to fat-wires through a small ANL or MAXI fuse. I presume that
    you're seeing maximum effect with the engine at idle while doing
    the Mexican hat-dance at the compass rose. These are the conditions
    where current in the b-lead is least . . . perhaps even zero while
    current through the field is maxed out. The regulator is hollering
    down to the engine room for "more power Mr. Scott . . . I need
    MORE power". Of course, at low engine RPM, the regulator isn't
    going to get what it wants to see and field current and associated
    external effects are at their maximums.
  	  | Quote: | 	 		  Remote compass - it could yet be the option - but I don't like to even think
    Then consider the special ops protocols for getting the whisky
    compass to live in the real world of a highly capable, failure
    tolerant electrical system. Perhaps some day, those-who-know-
    more-about-airplanes-than-we-do will allow us to relegate the
    once venerable magnetic direction indicator to the function of
    hood ornaments.
				 Posted: Wed Mar 26, 2008 3:52 am    Post subject: B&C SD-20 and magnetic interference |
				. . . a luck of the draw with the SD-20 - ie. they all vary abit?  We
   are only taking 3-4 amps under normal operations.  I understand some
   interference coming out, but what is 'too much'?
    WRT:
        "This is NOT a downside checkmark on the blackboard
        the field windings."
   this anywhere in the instruction / website information - I would have
   fixed without major rework and it is affecting my Autopilot backup and
   one of the few instruments the regulator is specifically interested in....
      It wouldn't hurt to drop B&C a note suggesting that their
      install literature be appropriately enhanced. But in their
      defense, this is not a common occurrence . . . you COULD
      be having a similar problem by routing some fat wire too
      close to the compass . . . or some other system integration
      problem like installing one of the older DC motor driven
      turn indicators too close and having interference from
      its internal magnets.
      It's unfortunate that after all the work you've put
      into the airplane (and being so VERY close to finished)
      that this problem should become the longest pole in your
      tent. Welcome to the real world of aviation products design
      and qualification! 95% of my services to clients on the
      TC side of the house right now involve chasing $100
      rats from multi-million dollar airplanes . . . with
      those-who-know-more-about-airplanes-than-we-do holding
      the type certification hostage until the flight system
      is pest-free.
      A well considered and easily demonstrated low-risk
      plan-B for making the compass readings fall within specs
      is the no-hardware, no hammers-n-saws approach to
      getting your machine blessed until it's legal to move
      the "hood ornament" out onto the cowl.
      Interestingly enough, I recall sometime in the past
      seeing a compass installation that was on a bracket
      just outside the windscreen. I think it was put there
      to get outside the cage of a day-vfr, rag-n-tube
      machine that was too badly magnetized to allow
      calibration of the compass when installed in it's
      normal position within the cockpit.
