		currydon(at)bellsouth.net Guest
				 Posted: Mon Mar 24, 2008 7:26 pm    Post subject: DME/Transponder Suppression |
				When a KT-76A transponder and a KN-63 DME are installed in an aircraft, and
 the two units are connected via suppression circuitry built into both units,
 is it necessary to comply with the requirement for there to be 6-foot
 spacing between the two antennae?  I can't find an exception to this rule in
 the install manual for either unit, yet I understand the suppression circuit
 is designed to keep each unit from receiving the other unit's transmission.
 So, why should it matter how close the antennae are to eachother?
 Don
		nuckolls.bob(at)cox.net Guest
				 Posted: Tue Mar 25, 2008 3:23 am    Post subject: DME/Transponder Suppression |
				At 11:14 PM 3/24/2008 -0400, you wrote:
     Transponders and DME use frequencies very close to each other
     and there's risk of receiver overloading in one device due to
     the very strong signal from the other device. This is mostly
     mitigated electronically via the suppression system but the
     6' rule gave the engineers and marketing types a warmer set
     of fuzzies. Give it a try doing the best you can. It will
     probably be fine.
     Have you considered a GPS receiver in lieu of DME? DME works
     with a hand full of ground stations while GPS will give you
     distance to any point on the surface of the earth. DME
     is one of those electronic buggy whips that needs to be
     moved to the museum.
         ( . . .  a long habit of not thinking   )
         ( appearance of being right . . .       )
         (                  -Thomas Paine 1776-  )
		BobsV35B(at)aol.com Guest
				 Posted: Wed Mar 26, 2008 1:35 am    Post subject: DME/Transponder Suppression |
				Good Morning Don and 'Lectric Bob,
  I imagine you are both aware of this, but just in case some others may not  be, the GPS is a legal substitute for any published IFR DME function.  The  GPS must be in an IFR approved installation configuration, but it does not have  to be approach approved, just enroute and terminal approved.
  The substitution is approved in the entire US National Airspace system and  in many other countries as well.
  Happy Skies,
  Old Bob
  AKA
  Bob Siegfried
  N3977A
  Downers Grove, IL
   In a message dated 3/25/2008 6:25:57 A.M. Central Daylight Time,  nuckolls.bob(at)cox.net writes:
   	  | Quote: | 	 		  Have you    considered a GPS receiver in lieu of DME? DME works
     Bob . .  .
 Create a Home Theater Like the Pros. Watch the video on AOL Home.
