No takers?
tdawson-townsend(at)auror
PostPosted: Wed Mar 26, 2008 5:53 am    Post subject: No takers? Reply with quote
No nibbles on this question from the other day?
For the folks who are flying:
How about an update on the nose gear axle spacers? Are installations
with the "new" aluminum spacers working well as designed, or are
supplemental measures to ensure the spacers can't rotate still
warranted?
Inquiring minds want to know . . .
TDT
Tim Dawson-Townsend
Aurora Flight Sciences
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
orchidman
PostPosted: Wed Mar 26, 2008 5:58 am    Post subject: Re: No takers? Reply with quote
They must all be snowed in and can't get the hanger doors open Mr. Green
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
flysrv10(at)gmail.com
PostPosted: Wed Mar 26, 2008 6:17 am    Post subject: No takers? Reply with quote
Tim, I got the updated spacer and still had shimmy problems. I filed a flat spot on the axel and installed two set screws on the spacers. This helped a lot but I still experience shimmy. I learned on this site to push the stick forward to stop the shimmy and it works for the most part. You still go through some shimmy before you stop it.
My nose wheel is nice a tight without any slop. I cannot figure out why I still experience some shimmy. I have done (at least I think) everything that has been published. The set screws did make a remarkable difference.
Rob.
warranted?
TDT
Tim Dawson-Townsend
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
Tim Olson
I know I've seen people with the new ones that the aluminum
formed a taper in that bearing inner race. Given the
idea that it can loosen up, I'd think the safe thing to
do is to prevent the rotation altogether as a preeptive
step so you don't have a problem.
*For the folks who are flying:*
*How about an update on the nose gear axle spacers? Are
installations*
*with the "new" aluminum spacers working well as designed, or are*
*supplemental measures to ensure the spacers can't rotate still*
*warranted?*
*Inquiring minds want to know . . .*
*TDT*
jesse(at)saintaviation.co
OK, I'll bite. In the retrofits I have done I have had to shorten the axle a little bit on the lathe to make it a tight fit so the spacers don't spin. I think on the new setups the length of the whole system is better, but I don't know for sure.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
warranted?
TDT
Tim Dawson-Townsend
pitts_pilot(at)bellsouth.
PostPosted: Wed Mar 26, 2008 7:06 am    Post subject: No takers? Reply with quote
The axle rotation won't have anything to do with shimmy, defined as the shopping cart wobble back and forth. Fix that by tightening the nut on the nose gear tube. A 25-30 pound pull on the wheel axle (off the ground of course) should make the nose gear shimmy free.
As for wheel hop ..... an up and down vibration ..... tire balance or an out-of-round tire will cause that. Bearing preload is a contributing factor ..... less than one rotation of the tire when spun by hand should be good.
Now, a caveat here .... my info comes from adjusting my AA-1B which has a similar castering nosegear. Should work for an RV-10.
Linn
Rob Kermanj wrote:
[quote]Tim, I got the updated spacer and still had shimmy problems. I filed a flat spot on the axel and installed two set screws on the spacers. This helped a lot but I still experience shimmy. I learned on this site to push the stick forward to stop the shimmy and it works for the most part. You still go through some shimmy before you stop it.
Rob.
warranted?
TDT
Tim Dawson-Townsend
http://www.matronics.com/Navigator?RV10-List blue; text-decoration: underline; ">http://forums.matronics.com style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
robin1(at)mrmoisture.com
PostPosted: Wed Mar 26, 2008 7:43 am    Post subject: No takers? Reply with quote
Rob,
  I don’t think pushing forward on the stick is the proper way to resolve the shimmy. It may help but my guess is that that is a mask for the real issues. In all my RV flying experience on never wants to add more weight / forces to the nose wheel. In my 6A we keep the wheel off the ground as long as we have authority and then the stick is back in my lap the entire time I taxi. Same is true when I took a demo ride with Mike Seager in the factory 10. He starts the 10 with the stick full back and does not release it till Run Up. Same with his taxi back. Now the A model Vans are known for their less than Cessna like gear durability but properly flown there should never see a problem. Adding greater forces by pushing the stick forward is not a solution to the shimmy.
Good luck,
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters
Sent: Wednesday, March 26, 2008 9:03 AM
Subject: Re: No takers?
Linn
Rob.
warranted?
TDT
Tim Dawson-Townsend
http://www.matronics.com/Navigator?RV10-Listblue; text-decoration: underline; ">http://forums.matronics.comstyle="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
http://www.matronic - MATRONICS available via the Web href="http://forums.matronics.com">http://forums.matronics.com===================[/b]http://www.matronics.com/c=[/b] [b]
PostPosted: Wed Mar 26, 2008 8:07 am    Post subject: No takers? Reply with quote
I agree Robin but I am at the end of my rope. If I relax or take the weight off the nose wheel, the shimmy get more aggravated.
Rob.
On Mar 26, 2008, at 11:38 AM, Robin Marks wrote:
Rob,
Good luck,
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of linn Walters
Linn
Rob.
warranted?
TDT
Tim Dawson-Townsend
http://www.matronic   - MATRONICS available via the Web href="http://forums.matronics.com">http://forums.matronics.com===================http://www.matronics.com/c=
[/url]
blue; text-decoration: underline; ">[url=http://forums.matronics.com]http://forums.matronics.com
Tim Olson
PostPosted: Wed Mar 26, 2008 8:27 am    Post subject: No takers? Reply with quote
Sorry Rob....I have bought a tire balancer that I've been intending
to use and do a write up on, but I'm just apologizing for it taking
me months over the winter. I'll let you know if it helps a lot.
I'll possibly replace my tires this spring too...now that I've hit
325 hours. I got better ones this time than the standard ones.
Wish I could try Scott's fancy goodyears though. Smile My guess is
that tire roundness and balance could be affecting you if it's
that bad....or at least that your side to side axle yoke preload
is too loose, or your axle bolt is too loose. My only shimmy
seems to happen between 35 and 40kts. Except I do think I get
some main gear shimmy that I'm hoping can be taken care of by the
balance and tires. This spring I'll report back. Nothing I
have right now though is severe or overly concerning.
Rob.
> Rob,
> Good luck,
> Robin
> *From:* owner-rv10-list-server(at)matronics.com
> <mailto:owner-rv10-list-server(at)matronics.com> [mailto:owner-rv10-list-server(at)matronics.com] *On
> Behalf Of *linn Walters
> *Sent:* Wednesday, March 26, 2008 9:03 AM
> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
> *Subject:* Re: No takers?
> Linn
> Rob.
> *How about an update on the nose gear axle spacers? Are installations*
> *warranted?*
> *TDT*
> Tim Dawson-Townsend
> tdt(at)aurora.aero <mailto:tdt(at)aurora.aero>
> *http://www.matronics.com/Navigator?RV10-List*
> *blue; text-decoration: underline; ">http://forums.matronics.com*
> *style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution*
> <http://www.matronics.com/contribution>
> ** <http://www.matronics.com/contribution>*http://www.matronics.com/Navigator?RV10-List
n212pj(at)gmail.com
PostPosted: Wed Mar 26, 2008 8:31 am    Post subject: No takers? Reply with quote
It's almost as if you have a harmonic going on, onset perhaps by an out of round tire? Which I'm sure you've already checked. Too light a tire? If everything else is as it should be, I'd be looking for something inherent in the wheel or tire. Does it shimmy with pants on and off? Just fishing here.
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Wednesday, March 26, 2008 9:04 AM
Rob.
Rob,
Good luck,
Robin
As for wheel hop ..... an up and down vibration ..... tire balance or an out-of-round tire will cause that. Bearing preload is a contributing factor .... less than one rotation of the tire when spun by hand should be good.
Linn
Rob.
warranted?
TDT
Tim Dawson-Townsend
[/url]
1[b]
PostPosted: Wed Mar 26, 2008 8:49 am    Post subject: No takers? Reply with quote
Thanks again. It is incredible how much experience and tips people provide on this list!
I had not looked into the tire or the wheel pants. I will do both soon.
Rob.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kermanj
Rob.
Rob,
Good luck,
Robin
Linn
Rob.
warranted?
TDT
Tim Dawson-Townsend
[/url]
1blue; text-decoration: underline; ">http://forums.matronics.com
PostPosted: Wed Mar 26, 2008 8:53 am    Post subject: No takers? Reply with quote
My situation seems to be exactly like yours: low speed, not severe
and manageable. I had someone on the ground check the vibration and
they told me that it is definitely from the nose wheel.
I also have really nice lateral fit on the axel and nothing is loose
at all. If you do your balancing and get good results, let me know.
What kind of balancer do you have?
Rob.
> Rob.
>> Rob,
>> Good luck,
>> Robin
>> *From:* owner-rv10-list-server(at)matronics.com <mailto:owner-rv10-list-server(at)matronics.com
>> > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
>> *linn Walters
>> gear shimmy free.
>> Linn
>> before you stop it.
>> Rob.
>> installations*
>> *warranted?*
>> *TDT*
>> Tim Dawson-Townsend
Tim Olson
PostPosted: Wed Mar 26, 2008 9:20 am    Post subject: No takers? Reply with quote
The balancer I have is a motorcycle tire balancer that I got
with the proper sized cones for these tires. I'll have to
dig up pictures for the write up. Vic bought one that was
slightly different that also would do just as well. I think
it was around $100 but don't quote me on that.
Also, as others mentioned wheel fairings....I did actually
balance at least my nose fairing. I balanced a ziplock
bag of lead shot taped to the nose when I first made them,
and then I poured the lead into the inside of the nose cap
and epoxied it in place. Probably should have left it in
the ziplock and epoxied the whole thing in place.
Anyway, I balanced the nose. I don't think I did the mains
but some day this spring maybe I'll do that just for
good measure.
Rob Kermanj wrote:
My situation seems to be exactly like yours: low speed, not severe and
manageable. I had someone on the ground check the vibration and they
I also have really nice lateral fit on the axel and nothing is loose at
Rob.
