tgesele(at)optonline.net Guest
Posted: Wed Mar 26, 2008 6:29 am Post subject: ECI Oil Filter Adapter With B&C SD-20 Alternator |
I'm attempting to install the B&C SD-20 Alternator on a Mattituck TMX IO-540 with the ECI oil filter adapter that puts the filter at the 10 o'clock position. Has anyone installed this combination and, if so, what was required to resolve the interference issue?
Tom Gesele #40473 - FWF
bcondrey
Posted: Wed Mar 26, 2008 7:13 am Post subject: Re: ECI Oil Filter Adapter With B&C SD-20 Alternator |
I have the B&C angled oil filter adapter with the SD-20 and had to get a special adapter for the SD-20 which moved it aft about 1/2-5/8". Bill at B&C can tell you exactly what you need. As I recall it consisted of replacement studs for the vacuum pad (longer), a spacer and a replacement sheer coupling for the SD-20.
Bob
