dlm46007(at)cox.net Guest
Posted: Tue Mar 25, 2008 8:18 pm Post subject: Hartzel prop |
Any rpm restrictions for the 80” prop and the IO540 D4A5? [quote][b]
acs(at)acspropeller.com.a Guest
Posted: Tue Mar 25, 2008 9:08 pm Post subject: Hartzel prop |
HARTZELL APPLICATION GUIDE
159
Non-HPI Spinner: VAN'S Non-HPI Governor:
Ref. Radius 30
Reverse Angle:
Low Pitch Angle: 13.5 +-0.2
Startlock Angle:
Feather/High Angle: 31.0 +-1.0
Cwt Angle:
VAN'S AIRCRAFT IDS No.: 2049 5/6/2005
Model: RV-10
Trade Name:
Modifier:
Engine: LYCOMING IO-540-D4A5
Propeller Model: HC-C2YR-1BFP Power: 260 HP (at) 2700 RPM
Notes:
Prop Setup:
Aircraft T.C./STC: Experimental
Non-HPI Items:
Hartzell Approved Items:
Placard/Restr:
Prop Diameter: 80
Blade Model(s):
Date:
Propeller T.C.: P-920
Item Type Item Number Description Quantity Qty Per Comments
PROPELLER C2R00780 HC-C2YR-1BF/F8068/SM8 1 A/C
PROPELLER C2R00800 HC-C2YR-1BF/F8068D/SM8 1 A/C
PROPELLER C2R10800 HC-C2YR-1BFP/F8068D/SM8 1 A/C
BLADE F8068 BLADE UNIT, ALUMINUM [1,1,5] 2 Prop VIBE SURVEY ONLY
BLADE F8068D BLADE UNIT, ALUMINUM [6,1,5] 2 Prop
SPIN MTG KIT A-2476-8 SPINNER - MTG KIT 1 Prop
MTG BOLT/STUD A-2067 STUD, MOUNTING, 1/2-20 6 Prop
John 40315
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Wednesday, 26 March 2008 2:06 PM
Subject: Hartzel prop
Any rpm restrictions for the 80” prop and the IO540 D4A5? 0123456789
AirMike
Posted: Wed Mar 26, 2008 9:18 pm Post subject: Hartzel prop |
Sorry Mike, I meant to add a note for David's benefit that one of the places
that list any restrictions on a prop/engine combination is in the
application data.
Under the section, "placard/restr:" you will usually find data (if any)
relating to limitations on power settings and or rpm values and max time for
continuous operations at certain settings.
John 40315
