dlm46007(at)cox.net Guest
Posted: Wed Mar 26, 2008 5:44 pm Post subject: fiberglass primer |
To protect the fiberglass parts (canopy, cowl and tail fairing) during the fly off, what paint has been used? [quote][b]
Deems Davis
Posted: Wed Mar 26, 2008 6:06 pm Post subject: fiberglass primer |
I've noticed that some folks haven't used anything. If you do decide to
do something you should check with your painter to make sure you're not
going to make life harder for them (and more expensive for
you).Polyfiber UV SmoothPrime is what a lot of folks use for pin-hole
and weave filling. it's also a UV barrier, and is compatible with almost
all paint systems. If you go this route, call me, and I'll give you a
name of someone who carries it in PHX. (It's NOT cheap)
Deems
David McNeill wrote:
rene(at)felker.com Guest
AirMike
Posted: Wed Mar 26, 2008 8:20 pm Post subject: Fiberglass primer |
i will probably wind up buying this stuff from Spruce, but has anyone found a Urethane topcoat-compatible primer that is cheaper.
Also, do I need more than one quart to do the RV10 top?
Thanks for your answers in advance
_________________ See you OSH '18
Q/B - sold. |
roadmaps
Posted: Thu Mar 27, 2008 4:27 am Post subject: fiberglass primer |
Mike,
I would not apply a primer until you know the paint system that your painter
will use. The primer should be part of the same system. The UV Smoothprime
is good under any paint system.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Painting
