582 Cabin Heat. Was Re: skis
patreilly43(at)hotmail.co
PostPosted: Thu Mar 27, 2008 5:33 pm    Post subject: 582 Cabin Heat. Was Re: skis Reply with quote
Len, OK, Thanks for your advice. I will keep the idea of fabricating a heat muff in mind in this rebuild.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Subject: 582 Cabin Heat. Was Re: skis
Date: Thu, 27 Mar 2008 17:36:32 -0700
--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
If you fly in the winter at the temps we do, the heater core WILL NOT produce enough to keep the windshield clear. I did not get cold as I had on my full snow machining gear but not having forward vis was a little problematic. They have been running heat muffs since the beginning of time in cubs etc. I will take my chances with that and continue to enjoy flying year round.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid &quot;C&quot; / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=173155#173155
&g==========
avidfox
While I stand by my previous view of my heater while in flight, I must say that during the ( long) time I am waiting for oil temp to rise to an acceptable temp for takeoff, the heater does tend to take the chill out cockpit. It is kind of nice to have a sytem that does not rely on fast foward motion and exhaust temp to supply at least a bit of comfort.
It's just the opposite of my C-172L, where you just want to get flying as quick as you can just to get some heat forced through the ducts.
(No,I don't have an oil thermostat either.)
I'm just a stupid mechanic\pilot, but wouldn't a combination (installation) of both systems be the best of both worlds??
Steve
84KF
KF5 \ 912UL
avidfox
PostPosted: Thu Mar 27, 2008 6:27 pm    Post subject: Re: 582 Cabin Heat. Was Re: skis Reply with quote
Forgive me if someone has mentioned this in the past, but has anyone tried to use, for cabin heat, the type of device that is used on (at least) a C-172L to collect hot air for carburetor heat?
It is a simple, foward facing, open-ended stainless box,with small tabs top and bottom, and is attached to an exhaust header with 2 stainless hose clamps. Must weigh all of 3-4 oz's. Airflow in flight forces hot air radiating the pipe to flow to the carb.
This is the best picture I have, but if you zoom in you can see it attached to the rear exhaust header feeding hot air to the carb air box.
Simple, cheap, lightweight, ....and available pre-fabricated.
Just a thought....
Steve
 Filesize:  329.41 KB
 Viewed:  662 Time(s)
Float Flyr
PostPosted: Thu Mar 27, 2008 11:40 pm    Post subject: 582 Cabin Heat. Was Re: skis Reply with quote
Yes.. that's the heat muff. Sometimes people have also stuffed them with
stainless steel Brillo pads to help heat conduction to the air. When using
this type of heater a CO detector is a must!
I have also seen a system on a Rotax 503 where there was a duct taken off
the cooling air for the head and run forward to the cabin of a Challenger.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
