Nick Leonard
Joined: 18 Jun 2007 Posts: 35 Location: Sacramento, CA
Posted: Thu Mar 27, 2008 10:14 am Post subject: IO-540 C2C Mounting Ears |
I have a IO-540 C2C (narrow deck, 250hp) engine and I'm short one mounting ear. This model has the larger hole for the Lord mounts and has the two alignment pins along with the four bolt holes. Does anyone have one available or know where I can find one?
Nick
_________________ Nick Leonard
RV-10 (40015) Flying |
Posted: Thu Mar 27, 2008 11:35 am Post subject: IO-540 C2C Mounting Ears |
If you mean the larger main hole, you have the wrong ears. In this
case you would need to get a full set of small-hole ears. The shock
mounts, whether they be the Lord mounts or the others that Van's is
now shipping with the FWF kit, they still need to go through the same
size hole in the engine ear. Send me a picture off-line and I will
let you know if they look like the right or wrong ears.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 27, 2008, at 1:14 PM, Nick Leonard wrote:
Nick
Nick Leonard
RV-10 (40015) Finish
http://forums.matronics.com/viewtopic.php?p=173067#173067
Nick Leonard
Posted: Thu Mar 27, 2008 12:54 pm Post subject: Re: IO-540 C2C Mounting Ears |
I ended up with the larger hole mounts (only three so far) because when I sent off for the Lord mounts (not Van's) specifying the IO-540 C2C, they said the right ones for the engine were the ones for the large hole. Shouldn't really matter other than I need to find one more.
Anyone know where I can find one?
Rhonda(at)bpaengines.com Guest
Posted: Thu Mar 27, 2008 1:14 pm Post subject: IO-540 C2C Mounting Ears |
I've got one Nick that is used serviceable and has passed NDT
inspection. It sells for $220 plus freight. Let me know if you'd like
it.
Ref the large hole mounts, versus the small hole. The large hole mount
was designed for engines that use a prop extension. It was designed to
move the focal point of the engine forward. The large hole mount is 28
degree rather than the 30 degree on the small mount.
Hope this information is helpful to you.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
Posted: Thu Mar 27, 2008 1:59 pm Post subject: IO-540 C2C Mounting Ears |
Nothing like a Lady that not only has great looks...but can talk engines as well!!
Rick Sked
40185
BPE fan, friend and customer
kdbelue(at)charter.net Guest
Posted: Thu Mar 27, 2008 2:40 pm Post subject: IO-540 C2C Mounting Ears |
Nick,
Sorry to say it, but the ears with large holes won't work with a standard
RV-10 engine mount. The angle and spacing is wrong. I had the large ears on
my engine and thought I could get the rubber mounts for this type of ear,
bit it wouldn't match the engine mount. The only way I could get it to work
is to buy the ears with small holes. They will bolt to the engine the same
as the large ears, but their angle matches the engine mount.
Kevin Belue
RV-6A
RV-10
Nick Leonard
Posted: Fri Mar 28, 2008 9:01 am Post subject: Re: IO-540 C2C Mounting Ears |
Thanks to everyone for their input. This certainly saved me a great deal of grief in the future. Easier to replace the mounts now and get the right ones than figure out why it wasn't fitting correctly later.
My appreciation to all of you for your help.
Nick
