subpanel pics
flywrights(at)yahoo.com
PostPosted: Sat Mar 29, 2008 7:50 pm    Post subject: subpanel pics Reply with quote
Trying to get ideas on how the rear on my panel/subpanel area should or could look. Please share any pics you may have so that I can get my brain in gear on what it will eventually look like back there!
Rob Wright
#392
Canopy with smoothprime and Doors !
">No Cost - Get a month of Blockbuster Total Access now. Sweet deal for Yahoo! users and friends. [quote][b]
jesse(at)saintaviation.co
PostPosted: Sun Mar 30, 2008 5:16 am    Post subject: subpanel pics Reply with quote
Rob,
Your panel layout will be the first starting point for the subpanel layout. What do you have in your panel and how it is organized? Contact me off-list and I would be happy to dialog a little bit on this.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
Rob Wright
#392
rene(at)felker.com
PostPosted: Sun Mar 30, 2008 6:08 am    Post subject: subpanel pics Reply with quote
Rob, here is how I did it….
First, Stein built my panel and he used his alternate, 3 section one. (picture attached)
I did not rivet the forward section onto the fuselage and thus was able to mount the panel in the forward section on the work bench. From there I decided what had to be cut out and where to place everything. It was easy to mark locations and do the cutouts and then test fit…..many times. I attached everything on the sub-panel with screws and nutplates so that it would be easier to install in the airplane. I also installed a shelf, using nut plates, between the sub-panel and the firewall to hold the AHRS and in the end I mounted on more item to the bottom (dimmers). I found it hard to fit everything in a convenient place and thus had to make another shelf type extension for the relays, terminal board and manifold pressure sender. In the end it is not to much of a maintenance nightmare, I had to test that theory twice so far. Test number three is coming up next week………..going to change some wiring in the GRT and 430.
Rene'
801-721-6080
 Filesize:  435.1 KB
 Viewed:  242 Time(s)
