bbreckenridge(at)gmail.co Guest
Posted: Sun Mar 30, 2008 4:58 pm Post subject: Rivetting Bottom Skins |
For those that have completed the rivetting of the bottom skins of the wings, did you leave the wings in the cradle? or, did you do as the plans say (page 20-5, step 2) and lay them on the table?
Bruce
40018 Wings
Posted: Sun Mar 30, 2008 5:17 pm Post subject: Rivetting Bottom Skins |
Left them in the cradle.
Rick S.
40185
Posted: Sun Mar 30, 2008 5:45 pm Post subject: Rivetting Bottom Skins |
On the table.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 30, 2008, at 7:54 PM, bruce breckenridge wrote:[quote]For those that have completed the rivetting of the bottom skins of the wings, did you leave the wings in the cradle? or, did you do as the plans say (page 20-5, step 2) and lay them on the table?
Bruce
40018 Wings
| [b]
daveleikam(at)wi.rr.com Guest
Posted: Sun Mar 30, 2008 6:34 pm Post subject: Rivetting Bottom Skins |
I kept them in the cradles. Deems has some good photos on his site of the process using wire to hold the skins back while riveting. I found this method to work well.
Dave Leikam
40496
attaching tailcone
coop85(at)cableone.net Guest
Posted: Sun Mar 30, 2008 6:52 pm Post subject: Rivetting Bottom Skins |
Cradle – looks like 2:1 so far J
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bruce breckenridge
Sent: Sunday, March 30, 2008 7:55 PM
Subject: Rivetting Bottom Skins
Bruce
40018 Wings
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Sun Mar 30, 2008 7:16 pm Post subject: Rivetting Bottom Skins |
Yeah, I'm hoping "cradle" wins. My concern is that there's just the slightest sag at the center that pulls together when it's cleco'd. I may just use a ton of clecos and then support the leading edge better before taking the clecos out.
Go cradle!
Bruce
On Sun, Mar 30, 2008 at 7:49 PM, Marcus Cooper <coop85(at)cableone.net (coop85(at)cableone.net)> wrote:
Marcus
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of bruce breckenridge
Bruce
40018 Wings
012 34567 89
Tim Olson
Posted: Sun Mar 30, 2008 7:26 pm Post subject: Rivetting Bottom Skins |
Flat on the table. Just thought maybe Van's had a good reason, like
the way the wing would be stressed during riveting. Probably not,
but it did work well for me.
| Quote: | For those that have completed the rivetting of the bottom skins of the
Bruce
40018 Wings
drfred(at)suddenlinkmail. Guest
Posted: Sun Mar 30, 2008 7:38 pm Post subject: Rivetting Bottom Skins |
Table
2:2
Fred Williams
Bruce
40018 Wings
Checked by AVG.
rene(at)felker.com Guest
Posted: Sun Mar 30, 2008 7:43 pm Post subject: Rivetting Bottom Skins |
On the table. Worked great.
Rene'
801-721-6080
Posted: Sun Mar 30, 2008 8:00 pm Post subject: Rivetting Bottom Skins |
PS…..I had help on about 70% for each wing, did the rest solo…..
Rene'
801-721-6080
jeff(at)westcottpress.com Guest
Posted: Sun Mar 30, 2008 8:57 pm Post subject: Rivetting Bottom Skins |
In the cradle, by myself.
Jeff Carpenter
40304
Fuse Side Skins
Bruce
40018 Wings
| [b]
Posted: Sun Mar 30, 2008 9:24 pm Post subject: Rivetting Bottom Skins |
Well, it looks like it's about a tie. Do it however you feel best between the two methods. With the leading edge on and the fuel tank installed I don't think it would sag, but you never know until you try it. Some have done a lot of it themselves, but this is a job, IMHO, for a helper. It can go quickly (about 3-4 hours per wing) with a helper. Just make sure, either way you do it, to pad your bucking bar(s) nicely so when (not if) you drop it, it won't damage the wing.
Speaking of which, in case I haven't mentioned it before, the Tungsten bucking bar from Stein is fantastic! Thanks Stein.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Bruce
40018 Wings
| [b]
rv(at)thelefflers.com Guest
Posted: Mon Mar 31, 2008 2:24 am Post subject: Rivetting Bottom Skins |
I can’t offer an opinion on this one quite yet, since I’ll just be putting on the top skins in the next week or so.
I just had the local EAA chapter over to visit my project. One of the questions I was asked was why the RV-10 didn’t require the use of a wing jig. Anyone know the answer?
It appears to for the other RV models, building a wing jig and getting everything straight was one of their more frustrating tasks. The 3 or 4 builders that had completed both RV-7s and RV-8s were surprised that the instructions to build the RV-10 wing were just to clamp to the work bench.
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Mon Mar 31, 2008 4:44 am Post subject: Re: Rivetting Bottom Skins |
Cradle here.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
speckter(at)comcast.net Guest
Posted: Mon Mar 31, 2008 4:47 am Post subject: Rivetting Bottom Skins |
No Jig is needed and the wing is dead on because of the prepunch holes.
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Monday, March 31, 2008 6:18 AM
Subject: RE: Rivetting Bottom Skins
It appears to for the other RV models, building a wing jig and getting everything straight was one of their more frustrating tasks. The 3 or 4 builders that had completed both RV-7s and RV-8s were surprised that the instructions to build the RV-10 wing were just to clamp to the work bench. | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Bob:
We don't need a jig because of the matched holes and the accuracy of
placement on the parts. When they all line up, the wing is straight.
Probably _better_ than any jig we could build at home.
Fred Williams
Bob Leffler wrote:
work bench.
Checked by AVG.
rv10(at)sinkrate.com Guest
Posted: Mon Mar 31, 2008 6:46 am Post subject: Rivetting Bottom Skins |
Bruce,
My wife and I did them on the table. The first one took forever but the second one we did in about half a Saturday. We attribute the difference in speed to getting a tungsten bucking bar. You can borrow mine if you want. I will gladly come help you out with a few days advanced warning. I also have a couple different sets that work great around the flap attach brackets.
Some things to think about…
<![if !supportLists]>1) <![endif]>Have you planned your pitot location and tubing and wiring and if you use the gretz where you are going to mount the circuit board?
<![if !supportLists]>2) <![endif]>Have you run conduit for wiring up lights?
<![if !supportLists]>3) <![endif]>Have you run tubing for the AOA ports (if your using AFS’s AOA)?
<![if !supportLists]>4) <![endif]>Have you built your control rod tubing yet and fit it?
Ben Westfall
#40579
PDX
Sent: Sunday, March 30, 2008 5:55 PM
Bruce
40018 Wings
