John75142
Posted: Sun Mar 30, 2008 5:34 am Post subject: Fuel tanks |
Currently working on my tanks for the 701 and noticed the beads called for around the exterior perimeter. Does anyone know the purpose of the beads. I don't have immediate access to a bead roller and noticed the older tanks did not have this. Are they a necessity?
CREATIVE SIGNWORKS
1168 Byron Rd.
Kaufman, Tx 75142
John & Mindy Short
972-962-7464
Cell: 214-240-3815
www.creative-sign-works.com
creativesigns(at)embarqmail.com (creativesigns(at)embarqmail.com)
_________________ John Short |
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Mar 30, 2008 6:05 am Post subject: Re: Fuel tanks |
John,
I think those beads are to add some rigidity to spread the loads along the seam, otherwise the loads would get concentrated at the center. Instead of purchasing a fancy set of beading rollers I made wooden form blocks and squeezed the beeds into the metal. See the link below.
By the way I haven't finished my tanks yet, but the beeding blocks worked well.
Dan Dempsey
http://daniel.dempseyfamily.us/zodiac/fuel/beedblocks.htm
_________________ Scratch building XL with Corvair Engine |
Posted: Sun Mar 30, 2008 6:59 am Post subject: Fuel tanks |
Hi John,
Tanks are usually welded at a mating raw edge. This type of weld is
inclined to be weakest when fuel pushes at the end and bulges the
sides. This is what puts a focus on
bending and stress at the edge weld. If you turn the ends around flange
inward and place them inside the wrap portion of the tank, leaving
3/16-inch radius out, a weld placed at the wrapper and bend will be
easier to make and have more weld area to resist bending. Putting
indent reinforcement is always good for large areas to eliminate drumming
and flexure.
http://www.macsmachine.com/images/headertank/full/tankbends.gif
John Short wrote:
| Quote: | Currently working on my tanks for the 701 and noticed the beads called
CREATIVE SIGNWORKS
1168 Byron Rd.
Kaufman, Tx 75142
John & Mindy Short
972-962-7464
Cell: 214-240-3815
www.creative-sign-works.com <http://www.creative-sign-works.com>
creativesigns(at)embarqmail.com <mailto:creativesigns(at)embarqmail.com>
John75142
Posted: Sun Mar 30, 2008 8:32 am Post subject: Fuel tanks |
Thanks for clearing that up, and all the good ideas. This list is the
greatest, just goes to show you don't have to know everything (or much at
all) to build a plane. All you have to do is ask and somebody out there will
know the answer.
Thanks guys
John (Scratch building 701)
Kaufman, Tx
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sun Mar 30, 2008 9:29 am Post subject: Re: Fuel tanks |
Amen to that!
Kevin
| John75142 wrote: | Thanks for clearing that up, and all the good ideas. This list is the
know the answer.
Thanks guys
Kaufman, Tx
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
ashontz
Posted: Mon Mar 31, 2008 8:40 am Post subject: Re: Fuel tanks |
So do the beads really need to be along the edge, or would an X pattern in the center of the large panel be sufficient, kind of like on the side of a WWII Jeep fuel can?
| larry(at)macsmachine.com wrote: | Hi John,
and flexure.
CREATIVE SIGNWORKS
1168 Byron Rd.
Kaufman, Tx 75142
John & Mindy Short
972-962-7464
Cell: 214-240-3815
www.creative-sign-works.com <http>
creativesigns(at)embarqmail.com <mailto>
Posted: Mon Mar 31, 2008 9:56 am Post subject: Fuel tanks |
Hi Andy,
If you were to retain the turned-out edge-weld, then the bead parallel
with the weld would be an advantage. This would keep stresses from
concentrating
at the center of each straight section edge weld. If the welds were
done flange in, there is little advantage to having more than long
diagonal dimples to
constrain drumming. To X across isn't wise either as drumming can focus
stress at the center of the X and make cracking more likely at center of X.
ashontz wrote:
> Hi John,
> and flexure.
> Larry McFarland 601HDS at www.macsmachine.com
ashontz
Posted: Mon Mar 31, 2008 10:25 am Post subject: Re: Fuel tanks |
Thanks. I'm doing flange out edge welds. I welded the long flange so far. I guess I'll go back and try to put a bead along the edge.
| larry(at)macsmachine.com wrote: | Hi Andy,
concentrating
diagonal dimples to
ashontz wrote:
> Hi John,
> and flexure.
Ron Lendon
Posted: Mon Mar 31, 2008 6:34 pm Post subject: Re: Fuel tanks |
I found putting the beads in before welding to be much easier. Also found it best to tack weld the entire seam around the whole tank, ends and length before welding the tank closed. YMMV
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
ashontz
Posted: Tue Apr 01, 2008 3:22 am Post subject: Re: Fuel tanks |
I was debating which way to go on that, bead first or after that fact, or not bead at all. Seems to be good reasons for beading so I'll do that. Right now I have a practice tank half constructed. I'll probably finish this one, see what I can learn from it, then make the two real one's after that.
| Ron Lendon wrote: | | I found putting the beads in before welding to be much easier. Also found it best to tack weld the entire seam around the whole tank, ends and length before welding the tank closed. YMMV |
