		jlno7(at)aim.com Guest
				 Posted: Fri Apr 04, 2008 7:47 am    Post subject: cross winds concerns |
				Does anyone know the maximum crosswind that a beginning student pilot can safely fly when taking lessons in a Kitfox 1?  Is there a guideline or is it just judgment?
  Jerry Novak
  Get the MapQuest Toolbar, Maps, Traffic, Directions & More!
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		n85ae
				 Posted: Fri Apr 04, 2008 8:04 am    Post subject: Re: cross winds concerns |
				Probably 5 or less if you are a student. I tried 15-20 on a gusty day
 as a non-student and did a sweet 270 right in front of the airport
 restaraunt at lunch time a couple years ago. Groundlooping is not
 fun.
 Jeff
		Guy Buchanan
				 Posted: Fri Apr 04, 2008 8:32 am    Post subject: cross winds concerns |
				At 08:44 AM 4/4/2008, you wrote:
  	  | Quote: | 	 		  Does anyone know the maximum crosswind that a beginning student
          Personally I would start out with something very near 0. (We
 get that reliably before 8am.) I would then work up. The upper limit
 is defined by comfort. One technique I use regularly is to set up the
 landing while on final. This is called the "slip" landing technique.
 It lets you know, worst case, whether your plane will fly the
 attitude required to land: whether you have enough rudder authority;
 whether a wing or other hardware is too low; etc. You have to be
 careful because in a strong crosswind you will be in a very strong
 slip and will therefore have to watch that you keep the speed well
 above stall. Note that I said worst case. The wind on the ground is
 nearly always much less than that at altitude, which means you can
 sometimes get in even when it looks, on final, like you won't; just
 be ready to go around.
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
		wingnut
				 Posted: Fri Apr 04, 2008 10:19 am    Post subject: Re: cross winds concerns |
				I asked my instructor the same thing when I was taking lessons in my Kitfox. His reply was that, lacking the rigorous testing that conventional airplanes go though to determine the safe cross wind component, a good rule of thumb is 20% of the stall speed. That's only 8mph in a Kitfox but keep in mind that this is only that component of the wind that is directly across the runway. So, if you have a wind that is crossing the runway at 30 degrees, then the cross wind component half the actual wind speed so 16mph is fine. Gusting is another issue. I'm personally not comfortable with gusts beyond +5.
  _________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
		n85ae
				 Posted: Fri Apr 04, 2008 10:40 am    Post subject: Re: cross winds concerns |
				Kitfox with the flaperons can land in enormously high crosswinds. More so
 than most certficated planes. The issue is you can also get yourself into
 deep "stuff", by doing that too much. Since it makes you braver than you
 should.
 I have a really big grass glider field nearby and have practiced 20 kt.
 crosswind landings in the series 5 before. It is doable, but I would not
 recommend it on a paved narrow runway.
 Stay close to zero is the best advice.
 Jeff
		Michel
				 Posted: Fri Apr 04, 2008 11:45 am    Post subject: cross winds concerns |
				 	  | Quote: | 	 		   From: n85ae [n85ae(at)yahoo.com]
 I agree that my model 3 flaperons give good roll control in gusty crosswind but the problem is to keep the plane from windvaning when the three wheels are on the ground.
 Cheers,
 Michel
 Norway
 Kitfox 3 - Jabiru 2200
 <pre><b><font size  color="#000000" face="courier new,courier">
		dave
				 Posted: Fri Apr 04, 2008 3:25 pm    Post subject: Re: cross winds concerns |
				I would keep X winds   at  90 degrees  to   5 knots or less.  This is where you get to hone in your directional control skills.  Once again look at my videos and look landing on one wheel or take offs on one wheel.  You should be competent in being able to one wheel your airplane down the runway to show yourself and instructor that you have good yaw authority
    Some one wheel action here  about  1 in 20 seconds into the movie     http://ca.youtube.com/watch?v=5j7aBw90n9U
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
