helili(at)chahtatushka.ne Guest
Posted: Fri Apr 04, 2008 1:04 pm Post subject: Need NSI Subaru Operating Limitations |
Is anyone using a NSI Subaru (118hp) that would be willing to email me a copy of their Engine Operating Limitations? I have the incorrect engine book for my engine. I’d appreciate it very much.
John Hart
Kitfox Model IV
NSI Subaru Engine
Wilburton, OK
Fox5flyer Guest
Posted: Fri Apr 04, 2008 2:09 pm Post subject: Need NSI Subaru Operating Limitations |
John, is yours the standard EA81 or the SHO version? Which book are you using? Let me know and perhaps I can help.
Deke
kitfox(at)ida.net Guest
Posted: Fri Apr 04, 2008 2:34 pm Post subject: Need NSI Subaru Operating Limitations |
Let me know if Deke can not help and I might be able to do it. I have the wrong ones for mine but they might be the right ones for you.
Albert Smith
MudLake, Id
5TD,NSIT,CAP
Posted: Fri Apr 04, 2008 4:00 pm Post subject: Need NSI Subaru Operating Limitations |
Deke,
I don’t know for sure which version it is. It is normally aspirated. The data plate on the aircraft lists the engine as 118 HP. The tach is redlined at 6200 rpm. The guy I bought it from told me it was the 118 HP version. The book I have lists RPM 5600 as max allowable engine speed, and max continuous engine speed as 5500.
The engine uses the Ellison EFS-2 Throttle Body Injection instead of a carburetor. Are there any other ways to determine which version engine I have?
The manual I have has on the lower margin of each page the number MA-EAE01-01. The engine model this book applies to is EA81-0981 Under the “Description of Design” in Section 2.0
John Hart
Kitfox Model IV
NSI Subaru Engine
Wilburton, OK
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Friday, April 04, 2008 5:03 PM
Subject: Need NSI Subaru Operating Limitations
Deke
----- Original Message -----
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Friday, April 04, 2008 4:57 PM
John Hart
Kitfox Model IV
NSI Subaru Engine
Wilburton, OK [b]
Fox5flyer Guest
Posted: Sat Apr 05, 2008 5:47 am Post subject: Need NSI Subaru Operating Limitations |
John, I just checked my manual and it's the same as yours. The lower right on each page says "MAN-EAE01-01"
I think you're good to go.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
