CGS Prop blades Loose (my blade departure)
kitfoxjunky(at)decisionla
PostPosted: Mon Apr 07, 2008 12:53 am    Post subject: CGS Prop blades Loose (my blade departure) Reply with quote
Noticed my name mentioned with respect to this topic. My blade departure was caused by a stress riser in the hub...at least that was what materials engineer I hired to look it over said. In plain English that means there was a groove in the hub that had a 90 degree corner. The Warp drive composite blade was still in good shape, even after it sliced into the float and creamed the metal nose gear retract mechanism. The details are still available on my web site at www.decisionlabs.com/kitfox if you are interested. The actual link to the folder is...
http://www.decisionlabs.com/QuickPlace/kitfox/Main.nsf/h_Toc/A91718C0319B5F8C85256F280057A2C3/?OpenDocument
Here is the picture that people were referring to. I wish I had taken one when it was sitting on the ramp with the cowls on, but I believe at the time I was looking for a stiff drink and a change of underwear.
Gary Walsh
KF IV Anphib 912S
C-GOOT
 Filesize:  93.77 KB
 Viewed:  356 Time(s)
Lynn Matteson
PostPosted: Mon Apr 07, 2008 5:01 am    Post subject: CGS Prop blades Loose (my blade departure) Reply with quote
From your experience, Gary, I was prompted to install an engine-
restraining cable on my Kitfox. I recall you saying that your engine
was restrained by the battery cable and partly by the cowl if I
recall correctly. Thanks to this list and some unfortunate
happenings, we are all a little safer, I hope.
Lynn Matteson
Grass Lake, Michigan
flying w/480+ hrs/down for annual
underwear.
Gary Walsh
Lynn
Kitfox IV-Jabiru 2200
N369LM
dave
PostPosted: Mon Apr 07, 2008 2:06 pm    Post subject: Re: CGS Prop blades Loose (my blade departure) Reply with quote
Posted: Mon Apr 07, 2008 9:01 am Post subject: CGS Prop blades Loose (my blade departure)
Lynn Matteson
Lynn, I have the same on mine, I think it should be mandatory for all.
I think i have posted pics here before on this old topic.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
