		reinkings(at)comcast.net Guest
				 Posted: Wed Apr 09, 2008 2:23 pm    Post subject: Really bad news....S |
				Have just read of another 601 crashing because of early witness accounts
 describing seeing it falling with it's right wing flapping alongside of
 the fuselage.   There have been numerous discussions, including one
 response from Mr. Heinz, regarding the 'too wide' spacing of the ribs
 (suggesting there should be several more added.   Additionally, there
 have been questions regarding the strength of the wing spar/to/fuselage
 attach points and their strength under even moderate loadings.
 Many respondants suggest pilot error (PIO, trying aerobatic manuevers,
 sudden control inputs for example).  As a newbie builder of the XL, I've
 decided AGAINST  proceeding with building the aircraft until some
 definite statements regarding structural integrety and perhaps even
 third party engineering tests and results on the airframe/wing systems
 are presented before continuing.
 Sadly, this certainly leaves a lot of builders and wannabes confused and
 concerned about the sudden increase in wing failures.
 My own thoughts are possibly installing 4 additional ribs on each wing
 and/or increasing the wing skins to ALL being .025 thickness rather than
 the .016 used in some locations.     Perhaps that and increasing the
 length of the center wing spar and spreading out the stress loads
 further along the attach points might help.
 Although an attendant increase in weight is forseeable perhaps the loss
 in 'useful load' would justify these or other considerations and at
 least provide the builder/pilot with a more secure appreciation for this
 beautiful little aircraft.    I, for one, would not be upset if the
 aircraft carried less fuel (in order to stay under the LSA 1320# rule
 knowing that this increased engineering would provide a larger margin of
 error while flying it.
 I am most interested in what the NTSP will report in it's findings.
 Further, I am very interested in any thoughts or ideas other
 builder/pilots are considering in these areas.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ernieth(at)gmail.com Guest
				 Posted: Wed Apr 09, 2008 2:43 pm    Post subject: Really bad news....S |
				Early witness accounts accounts are wrong very often. If you have a
 fuselage kit I will take it off your hands.
 On 4/9/08, John Reinking <reinkings(at)comcast.net> wrote:
		swater6
  Joined: 16 Dec 2006 Posts: 52 Location: Minnesota-KMIC/KANE
				 Posted: Wed Apr 09, 2008 2:50 pm    Post subject: Re: Really bad news....S |
				discussed offline
  _________________ 601 XL kit N596SW reserved
Tail, control surfaces and both wings complete. Now working on fuselage
www.scottwaters.com
		cndmovn(at)gmail.com Guest
				 Posted: Wed Apr 09, 2008 3:25 pm    Post subject: Really bad news....S |
				Yet another "I am not qualified to make this opinion, I am not an aeronautical engineer, I am going to make a remark that sounds like it has weight, but I really just want to spout my mouth....." opinion.
  I heard that TMZ.com is hiring....there you can speculate, make all the unfounded and un-fact based opinions you want...and get paid!
 Flame off.
 Paul
 On Wed, Apr 9, 2008 at 6:20 PM, John Reinking <reinkings(at)comcast.net (reinkings(at)comcast.net)> wrote:
  [quote]--> Zenith-List message posted by: John Reinking <reinkings(at)comcast.net (reinkings(at)comcast.net)>
  Have just read of another 601 crashing because of early witness accounts describing seeing it falling with it's right wing flapping alongside of the fuselage.   There have been numerous discussions, including one response from Mr. Heinz, regarding the 'too wide' spacing of the ribs (suggesting there should be several more added.   Additionally, there have been questions regarding the strength of the wing spar/to/fuselage attach points and their strength under even moderate loadings.
  Many respondants suggest pilot error (PIO, trying aerobatic manuevers, sudden control inputs for example).  As a newbie builder of the XL, I've decided AGAINST  proceeding with building the aircraft until some definite statements regarding structural integrety and perhaps even third party engineering tests and results on the airframe/wing systems are presented before continuing.
  Sadly, this certainly leaves a lot of builders and wannabes confused and concerned about the sudden increase in wing failures.
  My own thoughts are possibly installing 4 additional ribs on each wing and/or increasing the wing skins to ALL being .025 thickness rather than the .016 used in some locations.     Perhaps that and increasing the length of the center wing spar and spreading out the stress loads further along the attach points might help.
  Although an attendant increase in weight is forseeable perhaps the loss in 'useful load' would justify these or other considerations and at least provide the builder/pilot with a more secure appreciation for this beautiful little aircraft.    I, for one, would not be upset if the aircraft carried less fuel (in order to stay under the LSA 1320# rule knowing that this increased engineering would provide a larger margin of error while flying it.
  I am most interested in what the NTSP will report in it's findings.    Further, I am very interested in any thoughts or ideas other builder/pilots are considering in these areas.
				 Posted: Thu Apr 10, 2008 8:14 am    Post subject: Really bad news....S |
				I certainly do accept your observations with genuine embaressment.   Am
 only a newbie builder/pilot trying to figure it out as well.   Am not an
 aeronautical engineer and like everyone else anxiously await the
 official explanation for what happenedd.    My wife and I extend our
 condolences to the family of this pilot.      I apologize to the list
 members.    Just thinking out  loud.   I'm really discouraged about all
 this.   Still eager to remain on 'our' list.
 P.S.   How does one 'take back' a posting they discover was wrong?
		ashontz
				 Posted: Thu Apr 10, 2008 8:21 am    Post subject: Re: Really bad news....S |
				Don't apologize, there's a bunch of people here who are thinking the same thing as you. I'm also interested in possibly beefing up the wing.
 No need to apologize for being reminded by 'by the book' types, that also don't have any experience, and are even less inquisitive, that only aeronautical engineers have brains and those brains are always 100% accurate at all times, and automatically trump anyone else who may happen to attempt to thing for themselves occasionally.   LOL
  	  | reinkings(at)comcast.net wrote: | 	 		  I certainly do accept your observations with genuine embaressment.   Am
 P.S.   How does one 'take back' a posting they discover was wrong? |
		Gig Giacona
				 Posted: Thu Apr 10, 2008 8:55 am    Post subject: Re: Really bad news....S |
				Andy, you are completely free to put as many ribs in your wings as you like. But until it has been proved that such a change won't NEGATIVELY effect the strength of the wing I think I'll stay with a AE's design and everyone else should as well.
601XL Under Construction
				 Posted: Thu Apr 10, 2008 9:21 am    Post subject: Really bad news....S |
				I guess
 fuel =0 stall spin
 But I am not an accident investigator I just play one on the Internet
 On 4/10/08, John Reinking <reinkings(at)comcast.net> wrote:
		frankroskind(at)HOTMAIL.C Guest
				 Posted: Thu Apr 10, 2008 9:50 am    Post subject: Really bad news....S |
				I doubt there are many pilots who do not understand that a stall/spin in the event of an engine stoppage is likely to be fatal, yet there are hundreds, if not thousands, of such fatal accidents on record, including the 601 that went down near Bryce, VA.  I would love to be able to say that I would have the willpower to keep the nose down in the event of an engine stoppage, but the record is replete with pretty good pilots who didn't.  We don't know that the fuel tanks were dry in this accident, although what little evidence is available to outsiders suggests that fuel exhaustion was a possibility, including reports of engine noise changes from witnesses, no fire after the crash, and the proximity of the crash site to a destination.  Even if the cause of this accident is not a stoppage due to fuel exhaustion, it still is good to remember that powered aircraft fly better when there is still fuel in the tanks, ergo, stretching range is not a good idea, and when the engine stops, the pilot needs to keep the plane from stalling, especially in a very light aircraft with relatively low momentum.
 [quote] Date: Thu, 10 Apr 2008 13:18:10 -0400
  Subject: Re: Really bad news....S
  --> Zenith-List message posted by: ernie <ernieth(at)gmail.com>
  I guess
  fuel =0 stall spin
  > --> Zenith-List message posted by: John Reinking <reinkings(at)comcast.net>
 More immediate than e-mail? Get instant access with Windows Live Messenger.
		psm(at)att.net Guest
				 Posted: Thu Apr 10, 2008 10:05 am    Post subject: Really bad news....S |
				Hi Frank,
 Thank you for the astute analysis of the recent incident.  While it
 doesn't reach the level of "Fact" it certainly sounds like a reasoned
 and reasonable analysis.
 I have been following the incidents with the XL very closely since I
 expect to get mine in the air soon.  One aspect that sticks out for
 me is the recent sale of now two of the planes.  Until your comments
 I could not think of why this is important, but I also could not
 ignore the correlation between the unusual accidents with the also
 unusual sales.  A similar event occurred with John Denver when he
 purchased a home built plane and suffered a fuel starvation
 accident.  Perhaps the fact that a new owner of a questionably
 documented home built plane might not have a good handle on fuel
 consumption, fuel management, and flight planning for that plane is a
 significant issue.
 Paul
 XL fuselage
 At 10:46 AM 4/10/2008, you wrote:
  	  | Quote: | 	 		  I doubt there are many pilots who do not understand that a
		jmaynard
  Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
				 Posted: Thu Apr 10, 2008 10:19 am    Post subject: Really bad news....S |
				On Thu, Apr 10, 2008 at 11:01:58AM -0700, Paul Mulwitz wrote:
  	  | Quote: | 	 		   Perhaps the fact that a new owner of a questionably documented home built
  plane might not have a good handle on fuel consumption, fuel management,
  and flight planning for that plane is a significant issue.
 This is one reason I plan to spend several hours with CFIs at the AMD
 factory before flying off with my new plane.
 Jay Maynard, K5ZC                   http://www.conmicro.com
 http://jmaynard.livejournal.com      http://www.tronguy.net
 Fairmont, MN (FRM)                        (Yes, that's me!)
 AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
  _________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
				 Posted: Thu Apr 10, 2008 10:21 am    Post subject: Really bad news....S |
				Stall Spin from lack of fuel...???... NOT!
 I fly sailplanes often without fuel and it only spins when I make it...  go
 figure..
 SW
		MHerder
  Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
				 Posted: Thu Apr 10, 2008 10:25 am    Post subject: Re: Really bad news....S |
				Paul,
 I agree with your statement about the unusual circumstances of the sale, but just wanted to point out that this aircraft was manufactured by Czech Airworks I believe.  Also... To Frank, thank you for your well thought well stated input as well.
 I am concerned about the situation, however I remain confident that if there is any problem Zenith will address appropriately.  I'll ask again, does anyone have info as to whether or not the elevator mod was installed?
  _________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
		William Dominguez
				 Posted: Thu Apr 10, 2008 10:30 am    Post subject: Re: Really bad news....S |
				 	  | psm(at)att.net wrote: | 	 		  Hi Frank,
 ... Perhaps the fact that a new owner of a questionably
 documented home built plane ....
 Paul
 XL fuselage
 The plane in question was factory built. Here is the web site advertising the sale of the plane:
 http://www.nowakfamily.com/airplane.htm
  _________________ William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom |
		Gig Giacona
				 Posted: Thu Apr 10, 2008 10:31 am    Post subject: Re: Really bad news....S |
				And without a doubt flying sailplanes has made you a better pilot. BUT most pilots don't have any experience flying sans engine and it is the most natural thing in the world to pull back on the stick when the plane is loosing altitude no matter what your speed is. It is something that has to be trained out of you.
  	  | notsew_evets(at)frontiern wrote: | 	 		  Stall Spin from lack of fuel...???... NOT!
 figure..
 SW
		Iberplanes
  Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
				 Posted: Thu Apr 10, 2008 11:07 am    Post subject: Really bad news....S |
				Why  don´t we stop all this rumors and guessing once and for all and hire an
 independent engineer to check the plane and the design really hard.
 Is that so hard to do? We´ve invested good money on the kits, and now what?
 cant we afford a couple of u$s and get answers to our questions and fears?
 Come on !!!
 Alberto Martin
 Iberplanes IGL
 http://www.iberplanes.es
 Igualada - Barcelona - España
  _________________ Alberto Martin
601 XL - Jabiru 3300
Igualada - Barcelona - Spain |
		lwhitlow
  Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
				 Posted: Thu Apr 10, 2008 12:00 pm    Post subject: Accuracy, Discussions, and Risks (Re: Really bad news....S) |
				In response to a number of threads regarding the structural integrity of the 601XL;
 Perhaps you might want to review the plans and assembly manual before you make a recommendation about skin thickness
 I just walked out to my shop to be sure but my 601XL plans (August 2005) and my kit (November 2005) specify and have .025 wing skins. IRRC that change was made a number of years ago, after a number of builders noted difficulty in not damaging the .019 skins. As far as I know, this has been the spec for a number of years.
 Remember on the internet "nothing ever goes away". By posting bad information and the resultant suggestions on how to "strengthen things", you can easily wind up doing far more harm than good.
 A open an honest discussion between people who are willing to listen to others ideas and comment constructively about the issues is much more likely to have productive results.
 I look forward to flying my 601XL in less than a year. And if I need to make any modifications, that Zenith recommends then I will.
 I respect many people's desire to have a independent design engineer look at the design. It could shed some useful insight, or it could produce nothing more than " the wing/spar design meets the specifications for the aircraft", in which case we would still be left with an number of un-answered questions.
 Lets face reality here, most GA accidents cannot have a root cause determined with 100% accuracy. With only the crash remains, and the absence of a Flight Data Recorder, many times the most likely scenario is the final determination.
 Build these airplanes to the designers specifications. Operate them within the designers specifications. Thats the key to safety.
 There will always be risks. The Wright brothers took risks, but they reduced them as much as possible, and then accepted the rest. No machine built by a man is immune to failure.
 If you can do something that will reduce your risk, do it, but don't do something that is nothing more that security theater. A rib here. a thicker skin there, if your a loads engineer it might be a good choice, if not security theater.
 If your not ready to accept the risks of flight, then don't fly
 If your not ready to accept the risks of flying an aircraft that you built, then don't build one.
 If your looking for a 100% failure proof aircraft, realize your wait might be a long one.
 Its time to turn the key, pull the chocks, and explore the sky
 Larry Whitlow
 601XL 75% done 85% to go
 Northwest Indiana
  	  | reinkings(at)comcast.net wrote: | 	 		  Have just read of another 601 crashing because of early witness accounts
 /// SNIP ///
 builder/pilots are considering in these areas. |
		Gig Giacona
				 Posted: Thu Apr 10, 2008 12:11 pm    Post subject: Re: Accuracy, Discussions, and Risks (Re: Really bad news... |
				 	  | lwhitlow wrote: |
 Worth repeating.
		Jaybannist(at)cs.com Guest
				 Posted: Thu Apr 10, 2008 12:42 pm    Post subject: Really bad news....S |
				True - and worth repeating again and again!!!
 "Gig Giacona" <wr.giacona(at)suddenlink.net> wrote:
 Worth repeating.
 W.R. "Gig" Giacona
		Joemotis(at)aol.com Guest
				 Posted: Thu Apr 10, 2008 12:43 pm    Post subject: Really bad news....S |
				In a message dated 4/10/2008 9:59:41 A.M. Pacific Daylight Time,  wr.giacona(at)suddenlink.net writes:
   	  | Quote: | 	 		  | I think    I'll stay with a AE's design and everyone else should as  well |
  Who died and left you in charge of the design and modifications on the  Experimental aircraft that I am building????
  It is called Experimental for a reason, Gig.
  Joe Motis
  Do not archive.
 Planning your summer road trip? Check out AOL Travel Guides.
