Doors coming off
Goto page 1, 2  Next
VHMUM(at)bigpond.com
PostPosted: Wed Apr 09, 2008 6:58 pm    Post subject: Doors coming off Reply with quote
Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames.
Are we sure that the door handles were closed properly and in the locked position?
Remember the tunnel heat problem, some have the problem but most do not.
I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ?
I am absolutely not saying there is no problem just need some facts
I have written to Vans to the engieering department to see what they say
regards Chris
Tim Olson
PostPosted: Wed Apr 09, 2008 7:14 pm    Post subject: Doors coming off Reply with quote
Chris, from what I've heard, MOST of the RV-10's with door issues
were caused by the rear pin not being in the frame. I think the
one being discussed currently (416EC) is the only one that this
is in question on, as far as I've heard.
position?
regards Chris
rv10(at)sinkrate.com
PostPosted: Wed Apr 09, 2008 7:26 pm    Post subject: Doors coming off Reply with quote
Vans did have an issue with a door early on with 410RV. I don’t know the specifics but I think John C might. Hopefully he will chime in. I don’t know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin.
Ben Westfall
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough
Sent: Wednesday, April 09, 2008 7:56 PM
Subject: Doors coming off
regards Chris
dlm46007(at)cox.net
PostPosted: Wed Apr 09, 2008 7:42 pm    Post subject: Doors coming off Reply with quote
One other idea we had was the placement of a knob on the door inside, back near the pin. this will allow complete control (two hands pulling) of positioning the door for closure.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall
Sent: Wednesday, April 09, 2008 8:24 PM
Subject: RE: Doors coming off
Ben Westfall
regards Chris
0 [quote][b]
AV8ORJWC
PostPosted: Wed Apr 09, 2008 8:11 pm    Post subject: Doors coming off Reply with quote
The original prototype door on N410RV incurred damage during a x-cnty airshow trip to Colorado. As I remember the canopy and door assemblies off N220RV were removed as a quick fix and integral completed “total unit” as a Second Iteration prototype build and used to repair N410RV. All of the early kits going back to Randy s/n 006 and John Nys s/n 047 were the 220RV Gen II type. I believe 416EC s/n 416 was still this same type. Since then, several improvements (alternations have been included) aftermarket which is the thrill of this group, the open discussion, the talent of the individuals and the desire to pursue excellence in build.
Tim did an excellent explanation on the Taper. I am opposed to what I believe is in the plans (that should be nothing new to anyone). The Strike plate idea is a corrective measure for the high likelihood that operators will try to close a door with the aft pin partially extended. My review of the 416EC pictures shows an alignment and strike issue with the Pilot’s plate. I believe that other than in Tim’s “safety locked” scenario this system might allow an opening or movement at a critical point in time. The Rack systems should not allow continued retraction of an engaged pin during flight. I believe the taper needs to be oriented to the interior never the exterior. I believe the pin needs to be “fully” engaged into the metal door pillar. I believe the UMHD is not adequate for a long term receptacle. The view of 416EC showed significant stress forces on the mounting hardware. I believe a handhold which pulls the door down and closed positively even with a door ajar “in-flight” is a wise design change.
Within this body of personal opinion are several quality improvements which need universal illumination. For those with the second generation door & latch (220RV). I would like to see 416EC the last RV-10 to ever suffer latch release and premature door departure in flight.
Pilots are human, mistakes happen, the door handle might not always get “safety latched” and remain so. The secondary latch on the leading edge or a boldly relocated hinge set like on Cirrus can sure get the discussion stirred.
Let’s keep the sharp eyes focused at SNF and less mud on the field. There is lots to learn. Think Safety, Fly Safe.
John C.
Ben Westfall
regards Chris
[/b]http://www.matronics.com/Navigator?RV10-List
http://forums.matronics.com[/b]
[b]http://www.matronics.com/contribution
Phil.Perry(at)netapp.com
PostPosted: Wed Apr 09, 2008 8:33 pm    Post subject: Doors coming off Reply with quote
I'm starting to think of a simple and inexpensive design. Like our co-builder Mr. Leffler, I'm still a ways away from reaching this point.
However I've heard of a few RV-10's with handles that allow the door to be pulled down when you're sitting in the seat. I'm thinking of making this pull down strap out of some higher strength material and actually hooking it inside the cabin to a fixed point.
If it's done correctly, the handles will be functional and a open-door scenario could result in only a couple of inches worth of opening.
Sure it would be a distraction if you had to fly the plane with a door that was cracked open a few inches, but it sure beats having the door remove your Horizontal Stab and tear up your airplane.
It's cheap, simple, fool proof, and practical.
Phil
Sent: Wednesday, April 09, 2008 10:40 PM
Ben Westfall
regards Chris
1 [quote][b]
apilot2(at)gmail.com
PostPosted: Wed Apr 09, 2008 9:36 pm    Post subject: Doors coming off Reply with quote
410RV was right at 1000 hours last summer. Probably has a couple hundred more by now.
On Wed, Apr 9, 2008 at 7:55 PM, Chris and Susie McGough <VHMUM(at)bigpond.com (VHMUM(at)bigpond.com)> wrote:
[quote] Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames.
regards Chris
acs(at)acspropeller.com.a
PostPosted: Wed Apr 09, 2008 10:25 pm    Post subject: Doors coming off Reply with quote
Isn’t the idea of the taper to the outside, to ensure capture of the block and thereafter apply a leverage to firmly pull the door closed and into alignment?
John 40315
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Thursday, 10 April 2008 2:08 PM
John C.
Ben Westfall
regards Chris
  - The RV10-List Email Forum -http://www.matronics.com/Navigator?RV10-List
5
6
7
8
9[quote]
0[quote]
1[quote]
2[quote]
3[quote]
dav1111(at)erfwireless.ne
PostPosted: Thu Apr 10, 2008 3:32 am    Post subject: Doors coming off Reply with quote
I have a pull down strap mounted to the front lower part of the door which hangs down about 18 inches and allows me to pull the door down for closure. I also have a door handle mounted to the rear part of the door that I can grip and pull in the rear of the door with one hand while pushing the door handle closed which I find essential in getting both the front pin and rear pin sealed.
Under no circumstances would I ever consider any type of door pin that did not go all the way through the door frame. Essential to me is the ability to manually feel the door pin on the backside of the front and rear door frame to insure the pins are fully seated before I take off.
Russ Daves
N710RV - 200+ hours
dlm46007(at)cox.net
PostPosted: Thu Apr 10, 2008 4:35 am    Post subject: Doors coming off Reply with quote
As an addition to the standard setup I am going to use a steel set screw from Mcmaster Carr to thread inside the aluminum tube to cover the area of the tube carrying the shear load. I do agree that rear door handle will greatly assist in pulling in the door so that the pins insert correctly.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Thursday, April 10, 2008 4:25 AM
Russ Daves
N710RV - 200+ hours
AV8ORJWC
PostPosted: Thu Apr 10, 2008 6:27 am    Post subject: Doors coming off Reply with quote
I’m sure they will say Yes. Check any lockset or latchset for the logic of tapered pins on any door of a residential or commercial building. The only exception I can think of is an armory or bank vault door. I still stand my the logic for the taper to go opposite the plan. Oh yeh, and the pins to be fully retracted before a closure attempt. Just think of a deadbolt doing damage if not retracted.
John C
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne
Sent: Wednesday, April 09, 2008 11:23 PM
John 40315
John C.
Ben Westfall
regards Chris
[/b]--> http://www.matronics.com/Navigator?RV10-List
--> http://forums.matronics.com[/b][quote][b]Thank you for your generous support!--> http://www.matronics.com/contribution[b]
Tim Olson
PostPosted: Thu Apr 10, 2008 6:37 am    Post subject: Doors coming off Reply with quote
It's interesting that this thread is sticking around so long this
time...that's good, it breeds awareness.
First, in regards to the problem, those (I've read this a.m.'s
posts already) who are saying that the issue is an alignment
issue, are correct. The problem is, the door handle is forward
on the door, and when you pull in to close it, the front of the
door pulls in, but the back doesn't pull in as far. So, then
you go to latch it, and the back pin hits the nylon block or
the door frame.
Thinner door seals might help. I can't say I'm unhappy with
the ones that came with the kit though, because they seal very
well...never had a plane with such well sealed doors. But,
yes, with thinner seals this issue could be helped a bit.
One of the big improvements would be to have a pull handle
centered on the door, or a secondary pull handle on the aft
part of the door. The problem there is that, while I'm
a chunky monkey, I'm still under 40, and yet it isn't
super easy to twist around with the seat in the way, to
pull a handle in. So you're still going to have to take
care.
In short, this problem exists because of the way you pull
the door shut, and requires that you pull it shut nicely
before you try to engage the pins. To me, if you still
have all of the OTHER components left the same, you're
still going to have a hard time regardless of if you use
the rivethead pins or the standard, because you NEED to
get the alignment good before you try to latch, or the
pins hit the block and you get a nasty noise. This is
NOT a dig on them, because I see benefits to their system.
But, the video that was originally put out, where they
dropped the door in place and latched it, is a little
misleading, because if you have nice tightly sealed
door seals, latching it won't be as easy as pictured.
I'd love to fly in a plane with alternative door seals to
see how tight they seal, and then perhaps I'd consider
them, but I am thus far happy with the standard ones
because of the sealing.
John A, thanks for your description of the installation.
Very much appreciated. I'm still not 100% comfortable
with having the threaded area anywhere near the spot
that if cracked, would cause the major failure, but at
least it gives me a little more comfort. Ideally, to me,
those pins would be very long and done before you build
the door completely. But, I would have a harder time
installing those anyway.
John C, I appreciate your discomfort with the taper, but
really, I think the pins at least need a bullet nose to
aid in centering. The taper is probably overkill, but I
don't think an opposite taper would do any more than cause
more damage...a bullet tip is probably the ideal. Certainly,
without the taper I have now, given the standard install,
I would not have had good luck with an opposite taper...I
would have even worse paint chip issues.
Wayne H, You're right on with the reasons...good job.
Now, a couple other topics....
1) RE: front hinges. Not a bad concept. But, I think
it would be much harder to design a robust strong and
light door with strong enough hinges, and you'd have
to be really careful when the door sags or you could crack
it. Better? From a door flying off standpoint, sure, but
it definitely would require more care, and a totally overall
stronger design, more expense, and all that. So I can see
why Van's opted for what they did.
2) Re: Closing Doors. Personally, other than my wife, I
try never to ALLOW anyone else to close and latch my doors.
On one of my earlier flights, a co-worker reached up, grabbed
the door, and SLAM! Slammed it down...thinking it was auto
latching like a car door. That sent shivers down my spine,
so after that I decided to inconvenience my passengers and
insist on me latching it. Also, one of the nice things I
did during the build was go real slow in trimming that drip
edge on the sides of the door. What this did for me is
make the side gap almost NOTHING if the door is closed
tightly. So, in my plane, it's ABSOLUTELY visible by
a quick glance if you have the door in the proper position
to latch, and it's closed tight. If the pin is out of the
hole, you'd have a HUGE gap. So yeah, some really
sloppy door checks are what caused the door departures.
3) Latching: The latching mechanism itself I'm plenty
happy with. If someone wanted to add a secondary latch,
fine, not a bad idea for the most part. Ideally I'd
rather see a vertical pin in the door bottom as a 3rd
latch point, that latches along automatically with the
other points. But, as I said before, if you have a
positive "click" latching system, and you latch it right,
you should be good to go.
For what it's worth, once mine is latched, I don't detect
any for/aft or other movement. They're just tight.
The latching is positive and I have zero worries of a
properly latched door being released because of the
handle being pulled.
Whatever you do, try to use your utmost craftsmanship when
you do the door latches. From time to time I see RV-10's
where you can tell they didn't take the care on some of
the glass-related items. But the doors, try to do a
great job at least on the latches.
discussion stirred.
Tim Olson
PostPosted: Thu Apr 10, 2008 7:08 am    Post subject: Doors coming off Reply with quote
I don't see the point, in a plane. yeah, I get your
point on an auto-latching house door latch....you HAVE to
have the taper inward to push in the latch when you close
it. So sure, there it makes perfect sense.
On the RV-10, the taper helps correct slight misalignment
and bring the door tighter....that's not a bad thing.
I think a bullet tip is even better, but you're never
going to be able to pull the door TOO far in, so the
taper on the inside of the pin will never assist you
in doing anything.
So I guess we disagree here. The taper itself isn't
an, or THE issue....the issue is you NEED to have plenty
of pin sticking through the door frame...and you would
want at least some of the pin captured by the frame
to NOT have a taper on it, so you have the full
strength of a complete round section of tubing. If it
weren't for the fact that the alignment would suck,
a square cut tubing piece would work ok too...and would
probably be ideal. A solid round rod, like a dead
bolt.
So I guess I don't think the taper is something to
make an issue of, other than to keep it fairly short
so you have plenty of length of full-strength tubing.
John C
speckter(at)comcast.net
PostPosted: Thu Apr 10, 2008 4:06 pm    Post subject: Doors coming off Reply with quote
How about a bungee? LOL
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Thursday, April 10, 2008 12:31 AM
Phil
Ben Westfall
regards Chris
ricksked(at)embarqmail.co
PostPosted: Thu Apr 10, 2008 5:49 pm    Post subject: Doors coming off Reply with quote
LOL...sure Gary....how bout we just slip a prefabricated rope loop between the door handles, installed after the doors are down and ummmm.... Smile locked.
Rick Sked
wayne.e(at)grandecom.net
PostPosted: Fri Apr 11, 2008 4:58 am    Post subject: Doors coming off Reply with quote
After reading all the posts on doors coming off I went to the hangar yesterday to recheck mine to be sure they were doing what I thought they were. I have installed the Rivet Head conversion and I read someone saying that bullets don't go past the guide into and past the door frame. On mine they are going through the guide and through the door frame. Ok there.
I also heard several post say to reach back and feel that the pin has gone through the door guide. If you have a full interior, like I do, you obviously can't do that because the area is covered. I have the door warning lights installed and I check religiously to be sure the light has gone off after the door is closed. I also will not let passengers close the door. I usually stay outside the plane until the passenger is buckled in and then I close the door.
I can and would highly recommend the Rivet Head type of conversion. I think Steven DiNieri also has this type of conversion as well as Rivet Head.
Boy the damage done to the latest door off incident surely gives you the incentive to double check that the doors are closed properly before takeoff.
Wayne Edgerton N602WT
AV8ORJWC
PostPosted: Fri Apr 11, 2008 7:22 am    Post subject: Doors coming off Reply with quote
Wayne, with your beautiful paint job, that extra degree of respect for passenger and aircraft are a smart Checklist item.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Friday, April 11, 2008 5:54 AM
[quote] [/b][/b][/b][/b]http://www.matronics.com/Navigator?RV10-List[/b]http://forums.matronics.com[/b]http://www.matronics.com/contribution [b]
rene(at)felker.com
PostPosted: Fri Apr 11, 2008 7:52 am    Post subject: Doors coming off Reply with quote
Question? How much does the door bow outward in flight. I am going flying in about 30 minutes and will check mine, but just wondering if any of the other flyers have tried to measure the flex. I have looked at it in flight before and do not remember any noticeable increased gap in the door. The reason I am interested is that I did cut my rods down to have the pins be just long enough to go through the AL blocks. With the tight fit of the doors, I do not think that a racking motion could pull the pin out of the block, outward flex of the door could have some affect.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
james.k.hovis(at)gmail.co
PostPosted: Fri Apr 11, 2008 10:15 am    Post subject: Doors coming off Reply with quote
Being a lurker, I've read this thread with interest. Just to make a
general comment, for good structural "retention" of the door, I feel
the best set-up is for the door pins to pass completely through the
opening frame on the fuselage. Of course, I'm basing this on the
pictures I've seen so far. How does the warning light system "sense"
full locking with the "blueprint" set-up for the door? Seems to me it
would be a simple matter to add a couple micro-switches to the back
side of the door frames so they light up (or better turn off a light)
when the pins are fully engaged into the frames therefore indicating
proper lock.
close the door.
Tim Olson
PostPosted: Fri Apr 11, 2008 10:43 am    Post subject: Doors coming off Reply with quote
That's what the door sensors van's provides do...they're magnetic
sensors, and there are magnets in the tips of the pins.
proper lock.
Goto page 1, 2  Next
Page 1 of 2
