kenatkinson(at)ktdinterne Guest
Posted: Thu Apr 10, 2008 2:46 am Post subject: Transponder antenna position |
I have just received my Filser TRT 800 mode S transponder and am pondering on where to position the antenna. Has anyone already successfully fitted, tested one.Also has it been approved?
Ken.
josok-e(at)ukolo.fi Guest
Posted: Thu Apr 10, 2008 3:52 am Post subject: Transponder antenna position |
I stuck a Bob Archer thing against the luggage bay bulkhead. First wrong way, it has to be horizontal. The radio stays clean, no ticking sounds from the transponder, and ATC sees me even in the steel hangar It's a nice transponder. and backs up as an altimeter with it's encoder built in. I am very happy with it.
Jos Okhuijsen
Visit - www.EuropaOwners.org
jimpuglise(at)comcast.net Guest
Posted: Thu Apr 10, 2008 8:01 am Post subject: Transponder antenna position |
Jos-
I installed the Bob Archer antenna back in the tailcone on a piece of balsa. However, I installed it vertically. Transponder antennas are vertically polarized, aren't they, or am I confused?
BTW, I have a new sailboat -- get over and try it.
Jim Puglise A-283
ator t [quote][b]
DuaneFamly(at)aol.com Guest
Posted: Thu Apr 10, 2008 9:14 am Post subject: Transponder antenna position |
Jim,
I just installed the Bob Archer Transponder ant. and, yes, it is supposed to go horizontally. The connector should be closest to the front of the aircraft with the opposite end (that containing the mass of the ant. copper element) should point towards the tail.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
In a message dated 4/10/2008 9:02:32 A.M. Pacific Daylight Time, jimpuglise(at)comcast.net writes:
| Quote: | Jos-
Jim Puglise A-283
ator t | Quote: |
f="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Planning your summer road trip? Check out AOL Travel Guides.
Posted: Thu Apr 10, 2008 11:14 am Post subject: Transponder antenna position |
Jim, sorry, i first installed the antenna, then i read the manual and changed the polarization. Now i don't remember what's up and down
But i do remember a great sailing trip, and agree it's worth suffering an other border security check by those black uniformed #¤/¤#¤%/.
But i am afraid it will take another year before it's possible, don't sell it yet!
Jos Okhuijsen
Posted: Thu Apr 10, 2008 2:42 pm Post subject: Transponder antenna position |
Jos
I thought transponder polarisation was vertical? I always put the Bob
Archer thing (excellent imho) with its two arms vertical and the feeder
from the BNC horizontal. Am I getting confussed ?
Graham
josok wrote:
Jos Okhuijsen
Posted: Thu Apr 10, 2008 7:42 pm Post subject: Transponder antenna position |
I think we simply have a semantics problem. I hope this drawing makes it intact. If not, I'll scan the last page of the install instructions and post it.
O----------------------------------------------.................
BNC Conn . .
<----------- Pilot ................ Tail -------------->
Mike Duane A207A
Redding, California
Jabiru 3300A
Sensenich R64Z N
topglock(at)cox.net Guest
Posted: Mon Apr 14, 2008 12:07 pm Post subject: Transponder antenna position |
According to the Archer manual, it's vertically mounted. Mine is just
behind the baggage bay, on the port side. Never a problem being seen...
Jeff - Baby Blue
396 hrs
Graham Singleton wrote:
<grahamsingleton(at)btinternet.com>
Jos
Graham
> Regards,
> Jos Okhuijsen
