dpremgood(at)aim.com Guest
Posted: Fri Apr 11, 2008 7:44 am Post subject: CGS Prop blades Loose |
Good day all,
Just before the posts on the GSC prop blades, I took my 2 blade GSC off
my J3 Kitten. I wanted to buy a third blade in order to hang a 3 blade
prop. (I already have the 3 blade hub).
The folks at GCS offered to inspect my 2 blades and build the 3rd blade
to balance with the other 2.
Their inspection of my 2 blades showed that the blades were over
torqued in the past. ( I bought this plane used) They were right since
there was no gap between the hub halves.
GSC offered to return my blades, but recommended that I get new ones
because the blade's fibres at the roots were probably crushed and
therefore weakened.
I was a little disappointed that I would need a new prop, but safety
does come at a price.
Speaking of price, the good folks at GSC offered me a substantial
discount on 3 new blades, so now I am a proud new owner of a 3 blade
GSC prop for my J3 Kitten.
BTW, my Kitfox Classic IV is still in progress, I am building the spray
booth in my garage and will start painting when the weather is warmer.
Also, I am still looking for a prop. (ROTAX 912)
Any suggestions?
Doug Remoundos
Montreal, Canada
peteohms
Posted: Fri Apr 11, 2008 10:03 am Post subject: CGS Prop blades Loose |
I like the looks of a 2 blade wood prop. Isn't a 2 blade more efficient?
Pete
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
propellerdesign(at)tele2. Guest
Posted: Fri Apr 11, 2008 10:46 am Post subject: CGS Prop blades Loose |
No not necessarily.
If you need 3 blade that is better, a 2 blade will be larger in diameter or
chord, higher tip speed and lower aspect ratio isn't always better.
Look is one thing, vibes is other, and ground clearance.
Jan
ElleryWeld(at)aol.com Guest
Posted: Fri Apr 11, 2008 5:05 pm Post subject: CGS Prop blades Loose |
I find the 2 blade prop is more efficient but the next guy will say that three is better its your own preference
Ellery in Maine
In a message dated 4/11/2008 2:04:49 P.M. Eastern Daylight Time, apeterchristensen(at)sbcglobal.net writes:
[quote]--> Kitfox-List message posted by: "Pete Christensen" <apeterchristensen(at)sbcglobal.net>
Pete
----- Original Message -----
Sent: Friday, April 11, 2008 9:40 AM
Subject: RE: CGS Prop blades Loose
[quote] --> Kitfox-List message posted by: dpremgood(at)aim.com
Good day all,
therefore weakened.
Any suggestions?
Doug Remoundos
Montreal, Canada
Float Flyr
Posted: Fri Apr 11, 2008 7:13 pm Post subject: CGS Prop blades Loose |
Most efficient is a single blade... Very few of those out there. They are
mostly used on motor sailplanes which have retractable engines of limited
power. I agree that a nice carved laminated wood prop is a thing of beauty!
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Fri Apr 11, 2008 7:41 pm Post subject: Re: CGS Prop blades Loose |
My experience with a 68 inch three blade GSC versus a 72 inch two blade Warp on a 503, with a 3:1 C reduction box on a Classic 4 is the three blade was smoother...the two blade better climb and faster cruise.
I need every ounce of thrust I can get from the 503 so for me the two blade is the prop of choice.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Sat Apr 12, 2008 4:24 am Post subject: CGS Prop blades Loose |
Tom,
That's very interesting.
I fly a J3 Kitten with a 503 B gearbox, 2.58 :1
My biggest concern is ground clearance... the 72 inch just wouldn't be
possible for me.
How does the prop inertia compare between the Warp and the GSC?
Doug
Tom Jones
Posted: Sat Apr 12, 2008 6:37 am Post subject: Re: CGS Prop blades Loose |
| dpremgood(at)aim.com wrote: | Tom,
possible for me.
Doug
Doug, I don't know the specific inertia numbers for the props. The three blade GSC came with the engine when I bought it from Skystar in 1994. later I wanted to maximize the performance so called Warp and told them the application.
The Warp guy discussed some other props with me until I mentioned the gear box was a 3:1 C then he immediately said the 72 inch two blade was the way to maximize performance for that little engine. The sturdiness of the gear box along with the gear reduction was the Key I think.
My kitfox is draggy. No fairing on the wing struts. Cruise speed is slow...75 MPH at 5800 RPM with the WARP, about 70 with the GSC.
Classic IV
Ellensburg, WA |
