Music Inputs
d_emond(at)mweb.co.za
PostPosted: Sat Apr 12, 2008 4:05 am    Post subject: Music Inputs Reply with quote
I had a music jack wired into my system. My audio panel is a Garmin 340. I
have a sonyericcson mobile phone with walkman capability. What I find is
that with the walkman at max volume output the sound through the headphones
is reasonable, engine off on the ground. However with the engine running at
cruise I can barely hear the music. Are there settings on the system I
should check ??
Dave Emond
earl_schroeder(at)juno.co
PostPosted: Sat Apr 12, 2008 5:54 am    Post subject: Music Inputs Reply with quote
Hi Dave, If you want to add a another 'device', I've used one described in the following link: http://www.boostaroo.com/ Earl
should check ??
Dave Emond
Martin Pohl
PostPosted: Sun Apr 13, 2008 1:58 am    Post subject: Re: Music Inputs Reply with quote
Earl, thank you for the great link. I was looking for exactly such a device. Do you know if there is any amplifier around with an additional volume control knob?
Martin
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
Martin Pohl
PostPosted: Sun Apr 13, 2008 2:07 am    Post subject: Re: Music Inputs Reply with quote
Just found this: http://www.minidisc.org/headbanger.html
Will try to get it running with my Harman Kardon Drive Play iPod Controller, Flightcom Intercom 403stereo and Lightspeed 3G headphones.
Martin
Martin Pohl
Zodiac XL QBK
dustinp(at)hughes.net
PostPosted: Sun Apr 13, 2008 3:35 am    Post subject: Music Inputs Reply with quote
Dave,
I just had this same question, after a recent discussion by Vern Little about the AMX-2 Audio Mixer Amplifier, and Vern was nice enough to send me the following information when I inquired about using the AMX-2 to solve this issue..
Apparently Garmin added a pre-amp for the music inputs on the 340 to help solve just the problem you describe, and that I also have.
They came up with a modification called Mod 2 first, in which you place in pin in the #15 position of the J-2 plug on the back of the GMA 340, and connect it directly to ground to activate this pre-amp.
Apparently sometime later they came out with the Mod 5, which allows you to install a wire and pin in the same #15 position, and connect it to a switch that is connected to ground so that you can have the pre-amp either off or on depending on whether what you have plugged into the music input needs further amplification or not. This switched ground also apparently helped eliminate the amplification of other "noises" in the system, by being able to turn it off when the pre-amp wasn't needed for the music input. The Garmin notes state this switch can only be installed in units with Mod 5.
So, you will need to find out if you have either of those Mods. Vern said that it was probably listed on a tag on the unit, but I was able to find it on some paper work that had come back with the unit after some factory repair work had been done, that showed my unit had the Mod 5 installed. Now I need to find a reasonable source for a high density pin crimper.
I have Steins 4-way indent crimper for the standard density pins, but not the high density.
I need a 15 pin high density connector for another Mod I need to make to get my 430W to talk nice to my GRT EFIS through my Approach Avionics Hub.
Stein has the HD pins, but not the 15 pin HD connectors I need.
So if anyone has a good ( read cheap ) source for the high density pins, 15 pin HD connectors, and tools, I'd like to hear about them.
If not, Approach will do the mods I need for a price that may be less than investing in the tools, but it would be nice to have the tools for future needs too.
Dustin Paulson
should check ??
Dave Emond
emrath(at)comcast.net
PostPosted: Sun Apr 13, 2008 12:56 pm    Post subject: Music Inputs Reply with quote
Check your installation. There is a "high music gain" feature that required
a grounding of Pin J2-15 and provide a lot of gain. I'm still building so
I haven't run the engine yet, but this greatly improved my volume. Also, I
have a ANC David Clark and for some reason turning on the ANC really
improved the sound quality and gave a boost to the low end!
Good Luck.
Marty
Time: 05:05:59 AM PST US
Subject: Re: Music Inputs
should check ??
Dave Emond
h&jeuropa
PostPosted: Mon Apr 14, 2008 4:30 am    Post subject: Re: Music Inputs Reply with quote
Dustin,
I used a D sub crimper similar to the one Stein sells on Hi Density D sub pins and it worked fine. The hi density pins are .050 in diameter (where the crimp takes place) while the standard pins are .075. But my crimper contracts to about .025 diameter. So I tried a couple and found the wire is nicely crimped. You do have to be careful to position the pin correctly in the crimper as they are different lengths. But to do a few crimps, a standard d sub crimper seems to work OK.
Jim Butcher
Europa N241BW
PostPosted: Tue Apr 15, 2008 2:59 pm    Post subject: Music Inputs Reply with quote
Thanks Jim.
I guess it's certainly worth a try, and see if they will pass the pull test, but I sure wouldn't want to be in hard IFR, and have my MP3 player all of a sudden be unhearable because of a poor crimp. ~( ;- )
Dustin,
to work OK.
Jim Butcher
Europa N241BW
