		Dana
				 Posted: Sun Apr 13, 2008 9:22 am    Post subject: Ultrastar drive belt |
				The drive belts on my Cuyuna powered Ultrastar are a pair of 280J10 poly-v
 belts.  These are no problem to obtain, of course, but using a pair of
 belts like that isn't always the greatest idea unless they're exactly
 matched, preferably from the same production lot.  It occurs to me that a
 single 280J20 belt (same belt, twice as wide) might be a better choice...
 it's harder to find but it IS available.  The original US manual refers to
 two belts, though...  I wonder why?  Could it be just availability?  Or
 some other reason?  There's no real difference; the belts are manufactured
 very wide and slit to the required width.
 A 220J20 belt is $23, while 220J10's are $19 each... though I have an open
 account with McMaster, who stocks the 10's but not the 20's...
 -Dana
   +REAL+ programmers use EDLIN to create Windows apps
				 Posted: Sun Apr 13, 2008 9:43 am    Post subject: Ultrastar drive belt |
				In industrial usage (back when I worked for a living) I found that
 cog or notch style belts
 were more efficient and outlasted plain Vs. Would something like this
 be available for your
 application?
 BB
 On 13, Apr 2008, at 1:16 PM, Dana Hague wrote:
  poly-v belts.  These are no problem to obtain, of course, but using
  a pair of belts like that isn't always the greatest idea unless
  they're exactly matched, preferably from the same production lot.
  It occurs to me that a single 280J20 belt (same belt, twice as
  wide) might be a better choice... it's harder to find but it IS
  available.  The original US manual refers to two belts, though...
  I wonder why?  Could it be just availability?  Or some other
  an open account with McMaster, who stocks the 10's but not the 20's...
  -Dana
				 Posted: Sun Apr 13, 2008 10:40 am    Post subject: Ultrastar drive belt |
				I talked to Homer Kolb last summer about my VW belt drive. He told me he had
 a tool that measured belts. He had to pair up the belts from a shipment of
 belts to make sure that the belts were the same size.
 When I changed from cog belts to the serpentine belts I currently use there
 was some loss of power but the serpentine belts don't transmit the nasty
 harmonics the way cog belts do. Well worth the trade off.
 Rick Neilsen
 Redrive VW powered MKIIIC
		herbgh(at)nctc.com Guest
				 Posted: Sun Apr 13, 2008 12:22 pm    Post subject: Ultrastar drive belt |
				Rick
     At the flyin...did you say that your plane would fly on one
 belt?  Have you replaced the belts and how much do they cost?  Herb
 At 01:37 PM 4/13/2008, you wrote:
 <NeilsenRM(at)comcast.net>
 me he had a tool that measured belts. He had to pair up the belts
 from a shipment of belts to make sure that the belts were the same size.
 use there was some loss of power but the serpentine belts don't
 transmit the nasty harmonics the way cog belts do. Well worth the trade off.
 Rick Neilsen
		Dana
				 Posted: Sun Apr 13, 2008 12:37 pm    Post subject: Ultrastar drive belt |
				At 01:40 PM 4/13/2008, robert bean wrote:
  	  | Quote: | 	 		  In industrial usage (back when I worked for a living) I found that
 application?
 Mine's the poly-v, sometimes called a serpentine belt (though "serpentine"
 correctly refers to how a long belt is routed on a car, not the belt type
 itself).  Any other type of belt would require different pulleys.
 -Dana
   Lie ? Me ? Never!  No, no, no, the truth is far too much fun!
		Dana
				 Posted: Sun Apr 13, 2008 12:42 pm    Post subject: Ultrastar drive belt |
				At 02:37 PM 4/13/2008, Richard & Martha Neilsen wrote:
  	  | Quote: | 	 		  I talked to Homer Kolb last summer about my VW belt drive. He told me he
 had a tool that measured belts. He had to pair up the belts from a
 there was some loss of power but the serpentine belts don't transmit the
 If by cog belts you mean timing belts (synchronous belts), then yes you can
 get vibrations.  Same thing with a gear drive, which is why a gear drive
 often has some kind of slip clutch or harmonic dampener.  A friction belt
 (either a classic V-belt or a poly-v flat belt) lets it slip a bit,
 dampening out the power pulses.
 Of course too much slip and the belt wears prematurely.
 One other advantage of the poly-v belt is that unlike a timing belt, it
 rarely fails suddenly... ribs start to disappear and it's quite obvious
 during preflight, but it will still transmit power.  When a timing belt
 goes, a bunch of teeth come off and you better have a landing spot handy.
 -Dana
				 Posted: Sun Apr 13, 2008 1:17 pm    Post subject: Ultrastar drive belt |
				Herb
 Yes. That's what they say. I have never tried just one belt and don't plan
 on it. They sent me used belts so that I would be able to fly to Oshkosh
 last summer with out having to play with run in adjustments. I have put only
 47 hours on them since then. I don't have a clue of the cost.
 Rick Neilsen
 Redrive VW Powered MKIIIC
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Mon Apr 14, 2008 6:19 am    Post subject: Re: Ultrastar drive belt |
				Yikes......$19.00 each ?!!!!!!!
 Try this out instead at $4.44
 http://kscdirect.com/item/PIX%2B280J10/280J10_J-POLY-V_BELT_28%2522_10_RIB
 Its what I am using on mine.
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
