Mitch Hodges
  Joined: 10 Jan 2006 Posts: 45 Location: Powder Springs, GA
				 Posted: Sun Apr 13, 2008 5:31 pm    Post subject: 601HDS:  Leading Edge Rivet Line Gone Bad |
				When marking the rivet line for nose rib S8 on the top of the left O/B wing, I apparently missed the mark.  The line starts correctly at the spar, but at the third rivet position has moved completely off the rib.
 Of course, I noticed this after drilling the pilot holes!
 Is it acceptable to drill the correct line, then backfill these holes with rivets and perhaps a backplate, or even fill them when painting?  Of course, these are over the LE tank so I'll have to watch the clearance there.  I really hate to have to get a completely new LE skin, given it is already attached on the bottom, and all the other ribs are correct.
 I've got a note into Zenith about this, but I'm sure it will be few days before I get an answer because of SnF.  Anyone else run into the same issue, and had a brilliant solution?
 Mitch Hodges
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Mitch Hodges
N601MH (Zenith 601HDS)
Builder Log at http://www.hodges.aero
Wings Under Perpetual Construction |
