701 and 601 landing gear
jhausch
PostPosted: Mon Apr 14, 2008 2:52 am    Post subject: 701 and 601 landing gear Reply with quote
Jerry,
You wrote: “I bent my own 701 landing gear with a 20 ton jack and a die set I made.”
I’m not a builder, just a list lurker.
I’ve been wondering if it would be possible to gun-drill passages for brake fluid prior to bending?
I am imagining a process whereby one has a blind hole gun drilled from each end to a point which would be under the fuse; cross-drill holes near each end; tap all of them; plug the one on the end; then use the cross-drilled holes for fluid passages.
I have no idea how that would work, but just speculating.
Jim
wjones(at)BRAZORIAINET.CO
PostPosted: Mon Apr 14, 2008 5:07 am    Post subject: 701 and 601 landing gear Reply with quote
Hey Jerry ,I am in the planning process of bending my own gear for a 601XL .Could you send me any pictures or information that might help me .wjones(at)brazoriainet.com (.wjones(at)brazoriainet.com)  Thanks
Wade Jones South Texas
601XL plans building
Cont. 0200
ch701builder
PostPosted: Mon Apr 14, 2008 5:25 am    Post subject: 701 and 601 landing gear Reply with quote
Jim,
Grove makes that type of gear for the 701 (expensive). Kitfox's use that type of gear. I have thought about that method when I get to that point of putting gear under my 701.
(The Lizard 701, has the landing gear from Grove. He is the one with 31" tires)
http://www.zenithair.com/stolch701/7-photo88.html
Keith
N 38.9947
W 105.1305
Alt. 9,100
Jim Hausch wrote:
Jerry,
Jim
ttp://www.matronics.com/Navigator?Zenith-List
ics.com
.matronics.com/contribution
************************************* BestFit Clean Clean false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
Keith Ashcraft
ITT Industries
Advanced Engineering & Sciences
5009 Centennial Blvd.
Colorado Springs, CO
    80919
(719) 599-1787 -- work
(719) 332-4364 -- cell
keith.ashcraft(at)itt.com (keith.ashcraft(at)itt.com)
keith.ashcraft1(at)us.army.mil (keith.ashcraft1(at)us.army.mil)
This e-mail and any files transmitted with it may be proprietary and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT Corporation. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mail.
ggower_99(at)yahoo.com
PostPosted: Mon Apr 14, 2008 11:14 am    Post subject: 701 and 601 landing gear Reply with quote
Is just one of the Several points in favor of the Zenith designs that Mr Chris Heintz got in his "Design Goals Formula" to give it a name; talking mainly about the 601 XL but includes all the models:
The ability to land in (almost) any kind of landing strip (dirt, grass, asphalt, etc), this with the plus of lower (in their each class and type) landing speed, this comes by hand with their good handling, both in their lower (near stall) and higher (cruise) speeds.
Yes I know, they are not the perfect airplane, each one of the 1,000īs of designs available in the world has their own design goals and requirements, but the Zenith airplanes are very good in the envelope * their were designed in.
* (pilot experience: easy for the new pilot) ,this include the needed proficiency, landing experience (most "not perfect"), hrs per year flying practice, cost (mantanance and longevity), type of construction. Builder skills and experience, even cero experience in building, (from plans built to Fast built Kits), etc. All this pointed towards the normal week end fly for fun, sport type pilot.
"Normal" also means, in my personal opinion, not "rich" but also not "cheap" pilot/builder.
Yes, I am convinced by this Company and Yes, did my homework (lots of it) prior to buying my kits.
There are a very few minor things that I am not completly pleased about them, (as in every airplane, of course) But will not talk about it.... As my Grampa used to say: "If you talk bad things about your horse, you will never sell it when you need to..." Smile Smile .-)
Saludos
Gary Gower
Flying from Chapala, Mexico
701 912S (~170 hrs and counting)
Building 601 XL Jab 3300.
Yes, this post was intended ON list Smile Smile Smile
Jerry Shepard <jshep00(at)centurytel.net> wrote:
