				 Posted: Sun Apr 13, 2008 2:50 pm    Post subject: Proposed changes to sport pilot regs. |
				Full doc here:
 http://www.faa.gov/regulations_policies/rulemaking/recently_published/media/
 29015.DOC
 AVweb has a short video here:
 http://www.youtube.com/watch?v=bU14MNLBlqU
 Personally for me the biggest proposed change is removal of the "10,000
 above MSL" restriction (#9). My home field (36U) is at 6300 ft and we have
 plenty of peaks over 10,000 ft.
 Summary:
 1. Replace sport pilot privileges with aircraft category and class ratings
 on all pilot certificates.
 2. Replace sport pilot flight instructor privileges with aircraft category
 ratings on all flight instructor certificates.
 3. Remove current provisions for the conduct of proficiency checks by flight
 instructors and include provisions for the issuance of category and class
 ratings by designated pilot examiners.
 4. Place all requirements for flight instructors under a single subpart
 (subpart H) of part 61.
 5. Require 1 hour of flight training on the control and maneuvering of an
 airplane solely by reference to instruments for student pilots seeking a
 sport pilot certificate to operate an airplane with a maximum airspeed in
 level flight with maximum continuous power (VH) greater than 87 knots
 calibrated airspeed (CAS) and sport pilots operating airplanes with a VH
 greater than 87 knots CAS.
 6. Remove the requirement for persons exercising sport pilot privileges and
 flight instructors with a sport pilot rating to carry their logbooks while
 in flight.
 7. Remove the requirement that persons exercising sport pilot privileges
 have an aircraft make-and-model endorsement to operate a specific set of
 aircraft while adding provisions for endorsements for the operation of
 powered parachutes with elliptical wings and aircraft with a VH less than or
 equal to 87 knots CAS.
 8. Remove the requirement for all flight instructors to log at least 5 hours
 of flight time in a make and model of light-sport aircraft before providing
 training in any aircraft from the same set of aircraft in which that
 training is given.
 9. Permit persons exercising sport pilot privileges and the privileges of a
 student pilot seeking a sport pilot certificate to fly up to an altitude of
 not more than 10,000 feet mean sea level (MSL) or 2,000 feet above ground
 level (AGL), whichever is higher.
 10. Permit private pilots to receive compensation for production flight
 testing of powered parachutes and weight-shift-control aircraft intended for
 certification in the light-sport category under §21.190.
 11. Revise student sport pilot solo cross-country navigation and
 communication flight training requirements.
 12. Clarify cross-country distance requirements for private pilots seeking
 to operate weight-shift-control aircraft.
 13. Revise aeronautical experience requirements at towered airports for
 persons seeking to operate a powered parachute or weight-shift-control
 aircraft as a private pilot.
 14. Remove the requirement for pilots with only a powered parachute or a
 weight-shift-control aircraft rating to take a knowledge test for an
 additional rating at the same certificate level.
 15. Revise the amount of hours of flight training an applicant for a sport
 pilot certificate must log within 60 days prior to taking the practical
 test.
 16. Remove expired ultralight transition provisions and limit the use of
 aeronautical experience obtained in ultralight vehicles.
 17. Add a requirement for student pilots to obtain endorsements identical to
 those proposed for sport pilots in §§61.324 and 61.327.
 18. Clarify that an authorized instructor must be in a powered parachute
 when providing flight instruction to a student pilot 19.  Remove the
 requirement for aircraft certificated as experimental aircraft in the
 light-sport category to comply with the applicable maintenance and
 preventive maintenance requirements of part 43 when those aircraft have been
 previously issued a special airworthiness certificate in the light-sport
 category.
 20. Require aircraft owners or operators to retain a record of the current
 status of applicable safety directives for special light-sport aircraft.
 21. Provide for the use of aircraft with a special airworthiness certificate
 in the light-sport category in training courses approved under part 141.
 22. Revise the minimum safe-altitude requirements for powered parachutes and
 --Craig
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		kmccune
  Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
		psm(at)att.net Guest
				 Posted: Sun Apr 13, 2008 6:03 pm    Post subject: Proposed changes to sport pilot regs. |
				Actually, this looks like a pretty good compromise to me.  They are
 letting the Cub and Champ fliers along with the PPC and Trike guys
 get by without any instrument training, but if a Sport Pilot wants to
 fly planes with the speed performance of a C-172 or Zodiac then he
 has to have a minuscule amount of instrument training.  It isn't
 enough to give them the skill to handle inadvertent IMC, but it is
 enough to warn them that instrument flying requires special skills.
 We should remember this only applies to real Sport Pilots.  Private
 Pilots who are limiting themselves to Sport Pilot privileges already
 need to know how to perform minimal instrument flight.  I hope most
 of the ones who have been flying for years can do a lot more than
 that on instruments.  Even in 1971 when I got my Private, you didn't
 need to do any night flying but my examiner made me spend a
 considerable amount of time on my check ride under the hood.
 I am not worried about new requirements for at least one gyro
 instrument on LSA.  I wouldn't fly a plane without at least that much anyway.
 I am glad they addressed the silly 10,000 MSL issue.  I was planning
 on breaking that one anyway and citing the "PIC privilege to violate
 any rule if necessary for the safety of flight"  if challenged.  Out
 West, it makes a lot more sense to bust the 10,000 foot rule than fly
 into mountains.
 Paul
 XL fuselage
 At 05:46 PM 4/13/2008, you wrote:
  	  | Quote: | 	 		  This one kinda stands out, like they were giving something away and
 had to get something back   I hope this does not have a required
 additional  instruments clause piggy backed.
		ihab.awad(at)gmail.com Guest
				 Posted: Sun Apr 13, 2008 6:18 pm    Post subject: Proposed changes to sport pilot regs. |
				On Sun, Apr 13, 2008 at 7:01 PM, Paul Mulwitz <psm(at)att.net> wrote:
  	  | Quote: | 	 		    Actually, this looks like a pretty good compromise to me.  They are letting
  the Cub and Champ fliers along with the PPC and Trike guys get by without
  any instrument training, but if a Sport Pilot wants to fly planes with the
  speed performance of a C-172 or Zodiac then he has to have a minuscule
 There is another, similarly optimistic way to look at it. This is
 creeping morally closer to the idea that someone could exercise
 responsibilities similar to those of a regular Private Pilot without a
 Class 3 medical. Let's see....
 Ihab
 Ihab A.B. Awad, Palo Alto, CA
				 Posted: Mon Apr 14, 2008 1:25 am    Post subject: Proposed changes to sport pilot regs. |
				I have a very old friend and fellow CFI tell me about six months ago to:
 "watch out, the FAA will sneak up behind you and take away sport pilot
 privileges.  The FAA wants sport pilots out of the air, period.."
 I thought he was a little off base but now I think not.  We ll see..
 Steve W..
				 Posted: Mon Apr 14, 2008 1:51 am    Post subject: Proposed changes to sport pilot regs. |
				but help me understand the 2000 AGL rule....
 sw
				It amazes me.  I fly gliders ( no physical required. and can soar to
 18,000MSL.  Even go into class A airspace with prior notice.  The world
 record for altitude gain is 49,000
 That put the sailplane at 51,000 MSL
 Yet sport pilot can only go to 10,000 MSL.
 I dont get that rule..
 Steve W.
		kmccune
				 Posted: Mon Apr 14, 2008 4:16 am    Post subject: Re: Proposed changes to sport pilot regs. |
				Yes,  but 100mph! If they are flying daytime VFR only whats the point. Its not a terrible thing to have to do . But what if your plane goes 97mph (I hate knots      )  and you readjust the prop pitch and now your breaking the law. Or if its a type thing like I think I read, does this not matter.
 Sorry for my ranting.
 do not archive.
  	  | psm(at)att.net wrote: | 	 		  Actually, this looks like a pretty good compromise to me.  They are
  _________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy  McCune |
		Gig Giacona
				 Posted: Mon Apr 14, 2008 6:07 am    Post subject: Proposed changes to sport pilot regs. |
				I ve owned about 7 different aircraft over the years.  Seldom did I fly over
 9500 MSL.   The highest ( other than gliders ) was in my C 172.  To get to
 12.500 it took "forever"...
 Steve W
		Gig Giacona
		psm(at)ATT.NET Guest
				 Posted: Tue Apr 15, 2008 1:45 pm    Post subject: Proposed changes to sport pilot regs. |
				At 07:13 PM 4/13/2008, you wrote:
  	  | Quote: | 	 		  There is another, similarly optimistic way to look at it. This is
 Actually, this is already the case.  As an aging Private Pilot, I can
 exercise those privileges so long as I limit myself to VFR/Day and
 LSA.  I don't really consider the VFR/Day limits particularly
 limiting, and the LSA is a fair trade-off for the lack of a medical.
 I would like to see the class 3 dropped altogether, and then I could
 fly with full Private Pilot privileges including any aircraft, IFR,
 and night.  I expect that to happen some time, but not necessarily
 soon.  The notion that a Class 3 medical makes it OK to fly with a
 Private Pilot when nearly all the accidents on record come from pilot
 error is shaky at best.
 Paul
 XL fuselage
				 Posted: Tue Apr 15, 2008 2:23 pm    Post subject: Proposed changes to sport pilot regs. |
				OK heres my factoid.  .03%  ( point zero three ) of aviation accidents are
 medical related.
 Well that was in 2005.....
 SW
		jmaynard
  Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
				 Posted: Tue Apr 15, 2008 2:40 pm    Post subject: Proposed changes to sport pilot regs. |
				On Tue, Apr 15, 2008 at 02:42:21PM -0700, Paul Mulwitz wrote:
  	  | Quote: | 	 		   Actually, this is already the case.  As an aging Private Pilot, I can
 Personally, I'd like to be able to fly at night...
  	  | Quote: | 	 		   I would like to see the class 3 dropped altogether, and then I could
 Yeah. It's for that day, or the day when they significantly relax the
 requirements for a class 3 medical, that I specified a fully IFR-capable
 aircraft.
 Jay Maynard, K5ZC                   http://www.conmicro.com
 http://jmaynard.livejournal.com      http://www.tronguy.net
 Fairmont, MN (FRM)                        (Yes, that's me!)
 AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
  _________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
		Jeyoung65(at)aol.com Guest
				 Posted: Tue Apr 15, 2008 3:01 pm    Post subject: Proposed changes to sport pilot regs. |
				Do you really plan on flying IFR in a 601 or 701? Would think you would  bounce too much to enjoy the flight. Maybe I am getting too old but I would not  plan on a IFR flight and would land ASAP if I hit IFR condititon. Jerry of  GA
   In a message dated 4/15/2008 6:41:46 P.M. Eastern Daylight Time,  jmaynard(at)conmicro.com writes:
 aircraft.
 do not  archive
 It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
		kmccune
				 Posted: Tue Apr 15, 2008 3:24 pm    Post subject: Re: Proposed changes to sport pilot regs. |
				The only way I want to fly IFR is on NWA, and I'd rather drive! Now in the 701 (when it gets done) I want to see whats there! Of course thats why the 701 and  not a RV or Sonex or 601 ...
 Kevin
Dorothy  McCune |
		jmaynard
				 Posted: Tue Apr 15, 2008 3:28 pm    Post subject: Proposed changes to sport pilot regs. |
				On Tue, Apr 15, 2008 at 06:57:49PM -0400, Jeyoung65(at)aol.com wrote:
  	  | Quote: | 	 		   Do you really plan on flying IFR in a 601 or 701? Would think you would
 Well, I'm certainly not planning on flying hard IFR in it, but I do believe
 the instrument rating would allow me to fly on days that would be marginal
 for VFR flight but not all that bad for an instrument pilot.
 The AMD sales manager/test pilot tells me he's got 500 hours actual in
 Zodiacs; he commutes from home, an hour or so away by air, to the factory.
				 Posted: Tue Apr 15, 2008 3:38 pm    Post subject: Proposed changes to sport pilot regs. |
				Many aircraft are IFR "capable" but really should stay on the ground when
 IMC.....
 IMHO
 SW
				 Posted: Tue Apr 15, 2008 4:06 pm    Post subject: Proposed changes to sport pilot regs. |
				 	  | Quote: | 	 		  Many aircraft are IFR "capable" but really should stay on the ground
 when IMC.....
 Hi Steve,
 I agree with you completely.
 Still, in the real world real people who fly cross country fly into
 conditions where it is difficult to impossible to maintain control of
 their planes simply by outside visual reference.  In these inevitable
 situations it is a life saver to be able to perform simple control of
 the airplane solely by reference to instruments.  Needle, ball, and
 airspeed is enough.  With no gyros or no instrument flying skills at
 all the outcome of these incidents is nearly always fatal.  It just
 doesn't have to be that way.
 The skill and equipment I am describing has very little to do with
 IFR flight.  It is simple stick and rudder skill with instruments
 replacing the windshield for pilot orientation. In many ways, IFR
 flight is more about dealing with the "System" than the airplane.  It
 includes filing and following complicated flight
 plans.  Understanding, copying and reading back
 clearances.  Navigating without outside reference.  Dealing with air
 traffic controllers, vectors, and all the complicated radio out
 procedures.  On the airplane level, IFR flight includes doing things
 like zero/zero takeoffs, instrument approaches, and staying focused
 for hours while the whole world inside and outside your plane is
 trying to distract you.  And then there is the whole area of dealing
 with weather you can't see like ice and thunderstorms.
 Considering all that, single pilot IFR flight in a light small poorly
 equipped plane is not something I would want to do.  However, being
 able to survive brief periods of limited visibility and no clear
 horizon to stay oriented is an ability I think all pilots and planes
 should have.
 Paul
 XL fuselage
		Andrewlieser
				 Posted: Tue Apr 15, 2008 4:28 pm    Post subject: Re: Proposed changes to sport pilot regs. |
				I wouldn't even fly IFR with NWA!!!!  Joking of course, but in all honesty just because its "IFR" does not automatically mean the rides are crap and that you would be bouncing all over the place.  True this DOES happen but I've flown IFR days were the rides are better than that of a VFR day.  An example would be when there's a real stable air mass and visibility sucks, or there's a real low layer of stratiform clouds that top out at 5-6 thousand feet.  In both those situations the IFR / IMC would be usually very smooth and most likely easily handled by any aircraft including the 601!  Just my 2 cents on the IFR capabilities of a 601.
  _________________ Andrew Lieser
S/N 6-7045
http://websites.expercraft.com/andrewlieser |
