dlm46007(at)cox.net Guest
Posted: Wed Apr 16, 2008 5:35 pm Post subject: door seals |
Just a heads up. My original door seals were light gray. Because one did not stick properly I ordered a new seal; had to purchase the 25 feet. OK. The new seals are light brown. Surprise.
Kelly McMullen
Posted: Wed Apr 16, 2008 6:03 pm Post subject: door seals |
From Vans or ? I thought some were using seals from aircraftdoorseals.com
On Wed, Apr 16, 2008 at 6:32 PM, David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] Just a heads up. My original door seals were light gray. Because one did not stick properly I ordered a new seal; had to purchase the 25 feet. OK. The new seals are light brown. Surprise.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Wed Apr 16, 2008 6:19 pm Post subject: door seals |
vans
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Wednesday, April 16, 2008 7:00 PM
Subject: door seals
davelammers(at)mchsi.com Guest
Posted: Wed Apr 16, 2008 6:42 pm Post subject: door seals |
David,
Other than color are there other characteristics that are different?
Dimensions, including thickness?
Stiffness? Etc?
Dave Lammers
Finishing--about to fasten door seals
Posted: Wed Apr 16, 2008 7:36 pm Post subject: door seals |
does not appear too be; be advised that this time we are using the same 3M super silicone sealant clear that is mentioned in the plans. Used a GE product first time, a silicon sealant rated 10 on the 10 scale bonding the seal to glass and one worked and the other did not.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Lammers
Sent: Wednesday, April 16, 2008 7:39 PM
Subject: Re: door seals
David,
Stiffness? Etc?
Dave Lammers
