Posted: Wed Apr 16, 2008 3:15 pm Post subject: Firestar project |
Bill S:
Based on your statement below, I feel you are getting into this way over your head.
Changing the length of the tailboom, shortening it, will change a docile Kolb into one that is nearly unmanageable.
Changing aerodynamics and control systems to suit your fancy for an airplane you have never flown, especially when you have never flown a Kolb and, I understand you are also a low time pilot who has not flown in nearly 40 years, is not recommended. As long as I have been building and flying Kolbs, I don't make changes in these areas, because I want to live to fly tomorrow.
Changing a Kolb "to suit your fancy" or "squeezing it down to fit the mission" may well quickly bite you in the ass. It is not "a broad playing field".
Probably be to your best interest to have a reliable individual with a lot of knowledge of building and flying Kolb aircraft carefully inspect your Kolb before you ever make a decision to commit aviation in it.
Good luck with your project,
[quote] To me, the basic current Kolb design is eminently suitable for modifications. You can make them lighter, shorter, streamlined, open cockpit, doors, control mods (Hi! Mike), shape wings and tail to suit your fancy, re-power easily, and you name it. Or, like me, squeeze it down to fit the mission. It's a broad playing field, all on the same design.
Bill Sullivan
_________________ John Hauck
Titus, Alabama |
Posted: Wed Apr 16, 2008 4:30 pm Post subject: Firestar project |
Not me, John! I was just speaking in general. Look at the differences in my Firestar, a stock FS, and the OAL on Jack's Firefly. Also my clipped wing set (not on the plane). And the difference in aileron length between old Firestars and new ones. I was merely trying to point out the incredible flexibility of the basic design. Look at all the modifications you guys have been doing. About all you could do on a Quicksilver is change the wheels. Maybe the powerplant, maybe. I was merely making a statement admiring the versatility of the basic "boom" design. I would not dream of doing anything original- I do not have the knowledge.
The factory has been able to use the pod and boom, pusher engine concept to the point that I have trouble identifying them from a side profile. No cue cards, and I wish there was an ID book.
There also seems to be a lot of leeway in individual assembly- tail design, for one. Nobody tinkers with the basic design inside the wings, but do update them to current standards- like the corner braces of a couple of weeks ago. Again, a flexible design concept. You don't have to replace the whole wing.
No, I don't get too many bright ideas in unfamiliar ground. I pump other people for information. I am very comservative, and expect my renewed flying habits to be the same way.
Bill Sullivan
Fs/KX/447
beauford173(at)verizon.ne Guest
Posted: Wed Apr 16, 2008 6:20 pm Post subject: Firestar project |
...I reckon that explains a lot, John.... been wonderin'.... truth is, dropped my Fly's tailboom when building and had to cut five inches off that sucker to get rid of the dent....tripped over my Bride's faggy little fuzzy-ass cat...same one that peed all over the roll of poly fiber just before I started covering... sure cleared the roaches out of the garage when the hot iron hit that stuff...
Anyway, that Fly's been unmanageable all right...especially that little Nazi 447... and speakin' of a lack of managability... there's the Formidable Mrs. Beauford...hadn't thought about the causal relationship until you brought it up, but it looks to me like she's gettin' shorter too... last ten year or so, anyways... lack of manageability creeps up on a man.
Gotta agree with you in principle about sawing off Kolb tailbooms, though... I think shorter ain't better except when you're building the trailer... W&B complications aside, shortening it changes all sorts of geometry with things like control authority in the rear end... makes fer BIG trim tabs... and (dare I mention it) VG's all over the tail feathers...
sigh...
pensive beauford
FF-076
Brandon, FL
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Wed Apr 16, 2008 9:56 pm Post subject: Re: Firestar Project |
capedavis(at)yahoo.com wrote: | Roger ,A kxp with a 503 aint that a great combo .Mine was a 1990 I finished it in 92 and flew it for 10 years ! a short ground roll and then straight up what a joy . Wish I still had her. Chris
It is a great combo! That is what I meant by hoping I'm still flying it at 60. I hope to have built a two seater by then, but don't want to give up the KXP. I want my KXP to last 'til I'm 60 and then some.
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
Posted: Thu Apr 17, 2008 1:19 am Post subject: Firestar project |
You can make them lighter, shorter, streamlined, open cockpit, doors, control mods (Hi! Mike), shape wings and tail to suit your fancy, re-power easily, and you name it. Or squeeze it down to fit the mission. It's a broad playing field, all on the same design.>>
Hi Bill,
I am sure someone with a lot more Kolb experience than me will guide you away from your chosen course.
I do have a bit of experience in other planes and I can only regard your `make it shorter, make it lighter philosophy` with concern. Sure there are things you can do. Doors, re engine etc., but messing with the basic design by changing the shape and size of flying surfaces and shortening the fuselage is playing with fire unless you have a good grounding in aeronautics. You may finish up with a plane which fulfils the parameters but it won`t be a Kolb. So instead of having a plane with a tried and tested history you will have a one off machine which may or may not be any good. Why reinvent the wheel?
.<< A lot of them (rules) are pure nonsense. For example, allowing 30 extra pounds for floats when a life jacket would do the same thing>>
I don`t think that the object of fitting floats is to support you in the water in the case of a crash. To equate a lifejacket with floats shows a tendency to confuse apples and oranges.
I realise that in the States you have a much more cavalier attitude to rules and regs than we rather `button down` Brits and I applaud that , but it seems that you are planning to take things a bit far.
The old building adage is `Measure twice and cut once` To that I would add `Think three times`
Good luck,
Cheers
Pat
rowedenny
Posted: Thu Apr 17, 2008 2:55 am Post subject: Firestar project |
Pat,
Please understand Bill is talking about all the variations in Kolb models (ie: Mk-3 to Slingshot to Kolbra to X-tra, or the many Firestar models to Firefly) as well as many of the listers slight departures from stock. NOT about doing all these mods to his personel plane.
John H and yourself are missing his point of how flexable the basic Kolb design has proven to be. As Bill stated more than once, he has no plans of doing any major changes to his own bird. He is only pointing out the obvious flexability of Homers creation.
Denny Rowe
Posted: Thu Apr 17, 2008 3:21 am Post subject: Firestar project |
Jeremy- My stainless steel cable brackets do not look like the ones in the pictures you sent. Mine have one hole in each end. I will replace, just in case.
Re: Tail boom length- mine is a foot shorter than a regular Firestar. With the original wings- about 25' 4", supposedly the handling was great. The former owner had nothing but praise for it. Somebody mentioned trim tabs- My original right wing has one, I think about 3" x 6",but I can't tell how much of a bend in it. No tabs on the tail.
I will have an opportunity to do a side by side check of both a Firefly and a Firestar. And also get the builder/pilots to do the same on mine. There are a couple of very experienced people at the club.
Here is where some of the fun comes in: Trying to guess what kind of handling performance it has, relative to a "stock" Firefly or Firestar. Anybody want to try for some experienced speculation? The length is 19'- shorter than either model. Wingspan is about 27' 4". Engine is what appears to be a stock 447, with a 2 blade Warp Drive prop, pitch unknown. The wings are located 2 1/2" farther to the rear than stock. Leverage on the controls appears to be stock.
Comments, anyone?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
Posted: Thu Apr 17, 2008 4:14 am Post subject: Firestar project |
Denny:
I may be missing Bill S's point in that one msg, but I consider relocating wings 2.5 inches aft of the prescribed position, and shortening the tailboom, major changes.
The second tailboom in my MKIII was shortened one foot. Luckily I did not have to fly it long before it was time to change to the correct standard length. I would never have thought that one change would affect the flight characteristics of my MKIII, but it did, adversely...
I'm not an aeronautical engineer, but seems to me that moving the wings back 2.5" and moving the tail section forward by what ever the tail boom was shortened, will drastically influence the flight characteristics of whatever model Kolb Bill S intends to fly.
[quote] John H and yourself are missing his point of how flexable the basic Kolb design has proven to be. As Bill stated more than once, he has no plans of doing any major changes to his own bird. He is only pointing out the obvious flexability of Homers creation.
Denny Rowe
Titus, Alabama |
Posted: Thu Apr 17, 2008 8:10 am Post subject: Firestar project |
John- The tail boom was made that way- 1' shorter- by the original builder. I didn't know it until the other day. The 2 1/2" wing mount was ok'd by TNK, and mounted according to their recommendations. Weight and balance checked out. I can't find the work sheet I used, but it fell in the bracket. With a heavier pilot, I imagine it would be nose heavy.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
by0ung(at)brigham.net Guest
Posted: Thu Apr 17, 2008 8:35 am Post subject: Firestar project |
With a shorter boom tube, you will have a shorter moment arm for the horizontal stabilizer and elevators, reducing their effectiveness. With a shorter moment arm you will need to provide more force to do the same amount of work, thus requiring a larger control surface, or more speed. Opps there goes the gentile handling kolbs are known for. If the stabilizers stall at 10 ft, the nose will drop as will the plane, just another set of bent landing gear or worse. And with the wings moved back 2 ½ inches,,, that will make the problem even worse.
Just my 2 cents worth, and food for thought,,,, gravity does not care who did the mods,,, you or the original builder,,, its still the boss.
Boyd
Bill Sullivan
Posted: Thu Apr 17, 2008 11:28 am Post subject: Firestar project |
Boyd/all
You are right. Kolbs are more forgiving of this kind of change but be careful.
In the early days of this list people were doing this to correct a aft CG issue. I tried to convince them that this was the wrong way to do it but.... It reduced the weight on the tail wheel so it must fix the problem. Go figure. There are others out there that did the same.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Thu Apr 17, 2008 2:24 pm Post subject: Firestar project |
You all may be right about somebody changing aft CG. This this came through with a box of bent LG legs.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
Posted: Thu Apr 17, 2008 2:32 pm Post subject: Firestar project |
John and company- I do understand the implications of changes to the basic design. I will keep that in mind during flight tests. I have a brother-in-law who is qualified all the way up to a B-52, and he is itching to flight test it. I will make sure he reads all of this. Thank you. When it does fly, I will report on it. Probably 2 weeks.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
Posted: Thu Apr 17, 2008 3:42 pm Post subject: Firestar project |
Bill S:
Don't know that aft cg bends gear legs. Was more prone to believe that was a pilot's responsibility.
Bill Sullivan
Titus, Alabama |
Posted: Thu Apr 17, 2008 3:47 pm Post subject: Firestar project |
Bill S:
That's great!
How much time does he have in a Kolb?
Don't know that a B-52 pilot has much in common with a Kolb pilot.
These are the guys that usually have all the qualifications, but end up breaking the Kolb.
Good luck.
[quote] I have a brother-in-law who is qualified all the way up to a B-52, and he is itching to flight test it.
Bill Sullivan
Titus, Alabama |
Dana
Posted: Thu Apr 17, 2008 5:06 pm Post subject: Firestar project |
At 07:19 AM 4/17/2008, william sullivan wrote:
Quote: | My stainless steel cable brackets do not look like the ones in the
The Ultrastar has the brackerts with one hole in each end. You make the
cables up with three washers under each bracket, then you remove washers as
necessary to align the surfaces and tension the cables.
Quote: | Trying to guess what kind of handling performance it has, relative to a
Obviously you MUST make sure the balance is correct, relative to the
wing. Then, it'd guess it might be a bit livelier in pitch and yaw than a
stock plane, and you may have less elevator and rudder authority. Also it
may need greater wing incidence, or lower tail incidence, to fly hands off
at the same trim speed.
-Dana
A common mistake that people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete fools.
Dana
At 06:30 PM 4/17/2008, william sullivan wrote:
Quote: | I have a brother-in-law who is qualified all the way up to a B-52, and he
But how much ultralight and/or Kolb time does he have?
My brother in law used to fly F-15's and F-106's, and now flies GA and
trains people to fly L-39's on the side. I would NOT let him fly my
Ultrastar without some ultralight dual time.
-Dana
Posted: Thu Apr 17, 2008 5:32 pm Post subject: Firestar project |
John- Brian (my brother-in-law) has flown just about everything. I am almost certain he has never flown a Kolb. I do know that he has experience on light (if not ultralight) aircraft, and at least keeps his private ticket up. I don't think you can rent a B-52 for any reasonable hourly rate. I do know he is about the most conservative pilot I've ever met. I do know, it won't be me- experience. I'm not proud- I'll let somebody else try it. You volunteering?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
John Hauck <jhauck(at)elmore.rr.com> wrote:
[quote] Bill S:
That's great!
Good luck.
[quote] I have a brother-in-law who is [quote][b]
Re: Bent gear legs. Yup. Probably the pilot. Second thought: Kolb Drop.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
Posted: Thu Apr 17, 2008 5:39 pm Post subject: Firestar project |
Titus, Alabama |
