		brian-1927(at)lloyd.com Guest
				 Posted: Thu Apr 17, 2008 10:18 am    Post subject: opinions: 360 hp vs. 400 hp |
				I am getting ready to buy an engine for The Project. I am interested
 in opinions about desirability of an M14P vs. M14PF in a CJ6A. Here
 are my questions:
 1. Would you pay more for a CJ6A with an M14PF instead of an M14P?
 2. If so, how much more would it be worth to you?
 3. If you were looking at several different CJ6As, would 400hp attract
 you more than 360hp?
 Brian Lloyd                         3191 Western Drive
 brianl AT lloyd DOT com             Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
				 Posted: Thu Apr 17, 2008 11:37 am    Post subject: opinions: 360 hp vs. 400 hp |
				IMHO there is never too much power in an airplane.
 More power is going to be a deciding factor between airplanes.
 Yes, I would pay more for a PF vs a P equipped ANYTHING.
 What it would be worth to me is hard to estimate, but at least 5-10
 thou.
 I don't fit in a CJ so I don't look.  If it were a YAK-50, you're darn
 straight... I'd run and not walk to buy it.
 Mark Bitterlich
		NC69666(at)aol.com Guest
				 Posted: Thu Apr 17, 2008 11:56 am    Post subject: opinions: 360 hp vs. 400 hp |
				Too much Horse Power is almost enough.    Gary.
 Sent via BlackBerry by AT&T
		petervs(at)knology.net Guest
				 Posted: Thu Apr 17, 2008 12:05 pm    Post subject: opinions: 360 hp vs. 400 hp |
				More power is always better, but is it enough to really tell a difference.
 If you think about it in terms of power to weight, getting 11% more power is
 like the difference between the performance with and without a 200 lb
 backseater. In my experience the yak52 with 360hp and the paddle blade prop
 still out accelerates and out climbs the 400 HP CJ-6, but then cruise flight
 is another story.
 I think a lot will really depend on the engine prop combo and of course what
 you are going to do with the plane. You'll never have the performance of a
 SU29 in aerobatics.
 I've been led to believe that the PF engines require more maintenance and
 TBO is sooner, but I don't know that from personal experience.
 I'd say you probably can't go wrong with more power in the long run.
 Squatch
		buddairbum(at)cox.net Guest
				 Posted: Thu Apr 17, 2008 12:20 pm    Post subject: opinions: 360 hp vs. 400 hp |
				It's of any help, I have a brand new, 1999 M-14P with American wires and B &
 C pad, old style flange. It's never been unwrapped and has been in my hangar
 here in AZ since new. $25K.
 bd
 On 4/17/08 11:13 AM, "Brian Lloyd" <brian-1927(at)lloyd.com> wrote:
  are my questions:
		threein60(at)yahoo.com Guest
				 Posted: Thu Apr 17, 2008 1:00 pm    Post subject: opinions: 360 hp vs. 400 hp |
				Just remember, there's always that point of diminishing return.  No matter how much power up strap on.  Sooner or later you hit that point where cost per HP, doesn't make sense and  doesn't buy you anymore speed!!
   Where is that point on a CJ??  I'll leave that to the big dogs with deep pockets to find out.
 "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil> wrote:
   [quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E"
 thou.
 Mark Bitterlich
				 Posted: Thu Apr 17, 2008 1:17 pm    Post subject: opinions: 360 hp vs. 400 hp |
				It's a matter of perspective.  The difference in speed between a CJ with
 360 HP and one with 400 HP is going to be more or less minimal.
 However, it's impact on climb rate, short field performance, and a host
 of other things will always be impacted by more horsepower.
 Regardless, adding horsepower is most ALWAYS a matter of digging deep
 into ones pockets. Remember, Brian did not ask what the feasability,
 cost, or common sense was of ADDING the horsepower.  He asked if it
 would impact people when they looked at an airplane so equipped versus
 one not so equipped and that said... By how much?
 Pilots will always run to the airplane with the biggest motor.  Some may
 not, but the ones that don't usually are not the owners of YAKS and
 CJ's.
 Mark Bitterlich
		cpayne(at)joimail.com Guest
				 Posted: Thu Apr 17, 2008 3:31 pm    Post subject: opinions: 360 hp vs. 400 hp |
				Ah,opinions! No facts need obsure the logic. For my money, an M-14P can be tuned to deliver great performance without going to an increased supercharger gear ratio.
 On a CJ, airframe "adjustments" can lower drag and realize good MPG. After all, at speeds above 175KTS, the ailerons get stiff. If you want a Mooney, buy one. That said, a Yak really seems to benefit from more power as it's primary mission is acro practice.
 Craig Payne
		Dabear(at)damned.org Guest
				 Posted: Thu Apr 17, 2008 3:47 pm    Post subject: opinions: 360 hp vs. 400 hp |
				On Apr 17, 2008, at 2:14 PM, Bitterlich, Mark G CIV Det Cherry Point,
 MALS-14 64E wrote:
  with
  host
  may
  CJ's.
 Thanks to everyone who has responded.
 Just so everyone understands, I am making the decision to equip The
 Project with an engine. There is no difference in cost to install an
 M14P and M14PF other than the difference in engine cost. Prop is the
 same too. So there are two questions:
 1. Will I be able to get my money out of the airplane if I equip it
 with a Huosai?
 2. Will I be able to get my money out of the airplane if I equip it
 with an M14P?
 3. Will I be able to get my money out of the airplane if I equip it
 with an M14PF?
 4. Which of the above configurations will be easier to sell?
 BTW, the rest is up for discussion too but the airframe is first-rate.
 It is a 1967 airframe that has been totally disassembled and rebuilt
 from the ground up. It has Doug's 36gal wing center section aux fuel
 giving the aircraft 78 gal of fuel with stock wing tanks, more with
 bladders.
 So all I am trying to decide now is how to finish it out so that it
 will be most salable. If someone is looking for a like-new CJ6A
 tailored to their tastes, contact me now and I will be happy to equip
 the aircraft the way you want it. BTW, it will NOT have the old
 instruments or electrical system. These were removed and discarded.
 Electrical system and panels will be brand-new and modern.
 Likewise, since this CJ6A will be as light as it is possible to make
 it, it will also climb like a bat-out-of-hell. The big engine will
 also allow it to cruise effectively at the O2 altitudes when going
 cross-country.
 So, the next big decision is the engine and that is why I am asking
 you guys.
 Thanks.
				 Posted: Thu Apr 17, 2008 3:55 pm    Post subject: opinions: 360 hp vs. 400 hp |
				The PF engine is a question mark in some people's eyes. The P is not. Factor
 that into the equation.
 On 4/17/08 4:44 PM, "Brian Lloyd" <brian-1927(at)lloyd.com> wrote:
 > with
 > host
 > may
 > CJ's.
  with a Huosai?
  with an M14P?
  with an M14PF?
  bladders.
  cross-country.
  you guys.
  Thanks.
		dsavarese(at)elmore.rr.co Guest
				 Posted: Thu Apr 17, 2008 6:09 pm    Post subject: opinions: 360 hp vs. 400 hp |
				Brian,
 IMHO, here are my answers.
 1. Yes
 2. No
 3. No
 4. 1
 Dennis
				 Posted: Thu Apr 17, 2008 7:37 pm    Post subject: opinions: 360 hp vs. 400 hp |
				On Apr 17, 2008, at 7:06 PM, A. Dennis Savarese wrote:
  Brian,
  1. Yes
  2. No
  3. No
  4. 1
  Dennis
 Thank you for that succinct reply Dennis.
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 — Antoine de Saint-Exupéry
		napeone
  Joined: 10 Jan 2006 Posts: 36 Location: Birmingham, Al.
				 Posted: Fri Apr 18, 2008 5:17 am    Post subject: Re: opinions: 360 hp vs. 400 hp |
				Increasing the horse power in an engine simply by inceasing the boost is not the best way to go. Especially in an aircraft engine.
 David H.
		n395v
				 Posted: Fri Apr 18, 2008 5:42 am    Post subject: Re: opinions: 360 hp vs. 400 hp |
				Brian,
 I know absolutely nothing about Yaks, their values, performance, saleability but....
 I put an M14 PF on my plane. It was the 2nd Radial Rocket flying. The prototype has an M14P on it. In side by side trials I knocked the snot out of the prototype in Takeoff and climb. In cruise I can choose to burn more fuel and outrun them or I can throttle back and cruise along side the prototype at the same fuel burn.
 Maintenance is no different. The cost differential between the 2 was primarily adding the electric start.
 Since I built my plane 7 more Radial Rocket kits have been delivered ALL of them with M14 PFs. Not a single person considered the 360 hp  and happily paid the price differential.
 As far as increasing the boost "not being the best way to go" for additional HP I think the compression ratio is low enough and the engines robust enough that that is not an issue.
 This is a fairly penalty free HP increase and in my opinion will certainly make your plane more marketable and noticeably a better performer.
 The other thing I did to my engine was remove the pressure carb and put on an Airflow Performance Throttle body with manual mixture control.
 It has a half inch greater diameter barrel than the carb, is much simpler, eliminates the need for carb heat and allows me to control the mixture.
  _________________ Milt |
		shankeroid(at)verizon.net Guest
				 Posted: Fri Apr 18, 2008 8:05 am    Post subject: opinions: 360 hp vs. 400 hp |
				I've got the standard 285 in my  CJ and I love it.  But, its a stock CJ with "nothing special" other than it  runs great all the time.  I think the popular setup is a CJ with the M-14P  and 3 bladed prop.  It looks damn good and has to "power back" in formation  flight to allow everyone else to play (just ask Forrest.)  I think that's  "enough" power!
      The PF is a relatively unknown  entity at this time, but since you are building a "high end" project, it may  attract a "high end" buyer come sell time.  I think the middle-of-the-road  option (M-14P/MT prop) is the most bang-for-your-buck right  now.
      Brian, why are you already  thinking of selling "The Project"?  Once you get it tweaked just right, you  ain't never gonna sell!
  Jim Shanks
				 Posted: Fri Apr 18, 2008 8:35 am    Post subject: opinions: 360 hp vs. 400 hp |
				On Apr 18, 2008, at 6:17 AM, napeone wrote:
 Well, the proof of the pudding is in the eating. The M14PF has a good
 record for reliability. I suspect that the builders have done their
 homework.
				 Posted: Fri Apr 18, 2008 8:54 am    Post subject: opinions: 360 hp vs. 400 hp |
				On Apr 18, 2008, at 8:58 AM, Jim Shanks wrote:
  	  | Quote: | 	 		       I've got the standard 285 in my CJ and I love it.  But, its a
 There is never such a thing as too much power.
  	  | Quote: | 	 		       The PF is a relatively unknown entity at this time, but since
 OK.
  	  | Quote: | 	 		       Brian, why are you already thinking of selling "The Project"?
 Thanks for the input Jim. I have a fair amount of time in the CJ
 (about 800 hours) and in the Yak-52 (about 100 hours). I am pretty
 familiar with the aircraft. While I think that the CJ6A is a fantastic
 airplane, it no longer really meets my needs for the type of flying I
 am now doing.
 So, I want to build "The Airplane" for someone out there who wants one
 done "just right".
				 Posted: Fri Apr 18, 2008 11:01 am    Post subject: opinions: 360 hp vs. 400 hp |
				Please define what you mean by "the best way to go".  The word "best"
 needs to be qualified.  As in: "Best" from what exact perspective?  I'm
 curious as to your particular perspective simply because when money was
 no object at all, every engine designer that I've even known has used
 some type of external air compressor to pump more air and fuel into a
 given engine.  Across the board.  I've even seen a lawn mower engine
 with a blower on it.  That aside, please explain your statement since it
 tends to disagree with most every engine designer and builder and their
 products...that ever put their name on a sign post.  Most especially
 aircraft engine designers.
 Mark Bitterlich
				 Posted: Fri Apr 18, 2008 11:16 am    Post subject: opinions: 360 hp vs. 400 hp |
				A case of beer says that I will not even come close to being able to fit
 in it, let alone FLY it.
 Mark
 P.s.  I'd love to lose.
