		napeone
  Joined: 10 Jan 2006 Posts: 36 Location: Birmingham, Al.
				 Posted: Fri Apr 18, 2008 11:17 am    Post subject: Re: opinions: 360 hp vs. 400 hp |
				The PF was introduced as a high power engine version not a long life version, if you use the horsepower.
 But given the choice, I will take all the power I can reasonably get. I currently fly a Yak50 with the MP14 and a 260MT three blade.
 David H.
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Apr 18, 2008 11:33 am    Post subject: opinions: 360 hp vs. 400 hp |
				There is no question that if you increase the horsepower of an engine,
 it's lifetime will become less.  As you said, if you use that horsepower
 on a regular basis. With the PF, the choice is simply in your left hand.
 I own a YAK 50 also, with an M-14P and have flown it with more than a
 few props, except for the new MT FW-190 blades.  I'd take a PF engine
 over mine in a heartbeat.  Better yet, an M-9.
 Mark Bitterlich
		jland(at)popeandland.com Guest
				Anybody have a PF engine, or a core or prop striked engine that they want to
 sell?
 Thanks!
 Jay
				 Posted: Fri Apr 18, 2008 11:35 am    Post subject: opinions: 360 hp vs. 400 hp |
				Option 3.
 Why:
 1.  It will climb faster.
 2.  With the bigger blower, it will not only develop more power on the
 ground, it will also develop more power at altitude, meaning it will
 have a higher ceiling.  You might want to consider putting a different
 fuel system on it that allows leaning manually.
 3.  It will cruise at a faster speed with less RPM.
 4.  For those that decry the additional boost, remember that boost is
 simply a matter of how far you push the throttle forward.  You put a
 throttle stop on it and it becomes a P model.  More or less.  Mostly
 more, slightly less.  Remove the throttle stop and you have "WAR
 RESERVE".
 5.  More power means more options, especially when operating from higher
 altitude airports with short runways.
 I have an over 600 horsepower 68 Camaro.  It gets better fuel mileage
 than my 1998 Dodge Pickup with less than half that power, IF you keep
 your foot out of it.  Same thing can be said about any engine, including
 the P // PF comparison.
 6.  The PF usually comes with a standard SAE prop flange, which makes it
 compatible with more model props, at a slightly cheaper cost.
 7.  MT props will be cheaper if purchased used.  Why?  Most serious acro
 guys have to be on the leading edge with prop performance.  When MT came
 out with the thick root design blades, most of the serious guys
 immediately went out and purchased them, and the old ones are out there
 for sale much cheaper.
 8.  The selling price of PF model engines is climbing faster than P
 models, which of course makes it the more valuable engine to have.
 Brian, have you thought of taking the middle road and going with a "B"
 model?  I've thought about that a lot.  Take a "B" model, add Bill
 Blackwell's piston and cylinder mods, and you end up with a tough as
 nails M-14 with OVER 400 HP.
 Mark Bitterlich
		buddairbum(at)cox.net Guest
		napeone
				 Posted: Fri Apr 18, 2008 6:29 pm    Post subject: Re: opinions: 360 hp vs. 400 hp |
				By " Best way to go", I mean that I would prefer to port, polish, and fine tune the carburetion and ignition as a better way to go than increasing boost as the most reliable alternative. Using the additional boost only at altitude also makes a lot of sense. Those living at high MSL would also benefit
 David H.
		jan.mevis(at)informavia.b Guest
				 Posted: Sat Apr 19, 2008 1:05 am    Post subject: opinions: 360 hp vs. 400 hp |
				That depends upon who gives his opinion: the Russian inspectors that I know,
 always say that the Romanian engines are not as reliable. The Romanians of
 course say the opposite. I met a Romanian pilot in Germany, who ferried a
 beautiful Romanian YAK 52 tail dragger, with Romanian engine, and he was
 quite satisfied about it. I see no objective reason why the quality and
 finishing of a Russian engine should be very different from the finishing of
 a Romanian engine.
 Jan
		richard.goode(at)russiana Guest
				 Posted: Mon Apr 21, 2008 12:14 am    Post subject: opinions: 360 hp vs. 400 hp |
				Hi Brian-I would be interested to hear any  technical/practical views of pilot's experience of P v. PF Regards
  Richard
  Richard Goode Aerobatics
 Rhodds Farm
 Lyonshall
 Hereford
 HR5  3LW
 United Kingdom
  Tel:   +44 (0) 1544 340120
 Fax:  +44 (0) 1544  340129
 www.russianaeros.com
  [quote]   ---
		brian-1927(at)lloyd.com Guest
				 Posted: Wed Apr 23, 2008 3:45 pm    Post subject: opinions: 360 hp vs. 400 hp |
				On Apr 21, 2008, at 1:11 AM, Richard Goode wrote:
  	  | Quote: | 	 		   Hi Brian-I would be interested to hear any technical/practical views
 Well, I have been flying a Yak-52 with the -PF and see no difference
 in operation other than with the throttle full forward the MAP is
 higher and it had better acceleration and rate of climb.
 I would love to hear if there is enough experience with the engine to
 determine whether or not the working life is different.
 Brian Lloyd                         3191 Western Drive
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 — Antoine de Saint-Exupéry
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
