eatherton(at)rushmore.com Guest
Posted: Sun Apr 20, 2008 8:51 am Post subject: Large Baggage Pod |
I am working on a Model III and would like to have the large baggage pod. Anyone have one to get rid of? Or the details on the additional structure to add to the fuselage. I saw some drawings posted on another site showing the drop tank style unit.
I am getting to the point where I am close to finishing the cowl work and fuselage and this issue will start to hold up progress. Any help you can give is greatly appreciated.
Jason Eatherton
wingnut
Posted: Sun Apr 20, 2008 11:30 am Post subject: Re: Large Baggage Pod |
My model 4 is fitted for the factory built, torpedo shaped baggage pod. Is that what you're talking about? I didn't realize they came in different sizes. I'd be happy to take careful measurements of my brackets so you can continue with the building while you look... Actually, as I write this, it occurs to me that the specifications should be mentioned somewhere in the construction records and plans that came with the airplane. Only helps you though if we're talking about the same pod.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Posted: Mon Apr 21, 2008 4:37 am Post subject: Large Baggage Pod |
Actually the one I'm looking for is not the torpedo style. I hear lots of
people describing it as a style on the Cesna Caravan or 206, but it straps
up to the far fore and aft float connections and then has a slot that the
gear can cycle through. Your also right about the manual but I dont have
the sheets that describe it.
Jason Eatherton
