		richard.goode(at)russiana Guest
				 Posted: Mon Apr 21, 2008 7:47 am    Post subject: M14P & M14PF engines |
				 - Since we have sold a lot more of these engines than anyone else I suppose we should have a view on the relative issues between them.
 - Our experience, drawn from over 250 engines, is that the PF is statistically somewhat more reliable than the P.
 - Remember also that many PFs are worked extremely hard in Unlimited Level competition Sukhois etc.
 - However to present an accurate picture, a much higher proportion of the PFs that we have sold have been 'new' rather than overhauled and I am sure this must affect the statistics.
 - The PF is not a recent engine - the first ones were being flown in 1984 and then sold from 1990 - I would guess that there are something like 200 in service so we have a large 'database' already.
 - I use a PF in my own Yak-18T, where apart from the obvious advantages of take-off distance; rate of climb, the aircraft is very significantly faster in cruise if you go up to 8/10,000 feet, and, I suspect, for many pilots this is where the real advantage might lie in long trips.
 - To get the performance advantage from a PF you must use the MTV 3-blade propeller.  The V-530 2-blade can only transmit about 350hp, beyond that it becomes inefficient.
 - To clarify the official overhaul times, the first overhaul for a new engine is 750 hours and then a further three overhauls at 500 hours each to give a life of 2250 hours.  These are the limits that we in Europe have to follow, although we recognise they are absurdly conservative.
 - I would be interested to hear of M14P or M14PF engines being operated in the US with over 1,000 hours since new/overhaul - I am led to believe that there are engines with well over 2,000 hours - is this true?
 - In terms of engine longevity the following are critical:
  - Careful warming up, and more importantly, careful cooling down.
 - Total avoidance of oil in the lower cylinders on start up.
 - The use of good quality - ie detergent, but not multigrade Western oil.
 - Pre-heating if starting below +5 degrees centigrade.
 Richard Goode Aerobatics
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 United Kingdom
 Tel:   +44 (0) 1544 340120
 Fax:  +44 (0) 1544 340129
 www.russianaeros.com
		jland(at)popeandland.com Guest
				 Posted: Mon Apr 21, 2008 8:34 am    Post subject: M14P & M14PF engines |
				Richard
  What problem have you found with multigrade oil in M14s?
  Thanks, Jay
  From: Richard Goode <richard.goode(at)russianaeros.com>
  Reply-To: <yak-list(at)matronics.com>
  Date: Mon, 21 Apr 2008 16:44:51 +0100
  Subject: M14P & M14PF engines
  Rhodds Farm
  Lyonshall
  Hereford
  HR5 3LW
  United Kingdom
  www.russianaeros.com <http://www.russianaeros.com>
  ail Forum -
  ">http://www.matronics.com/Navigator?Yak-List
  ;  - MATRONICS WEB FORUMS -
  matronics.com
  ;- List Contribution Web Site -
  ;                 -Matt Dralle, List Admin.
  ://www.matronics.com/contribution
				 Posted: Mon Apr 21, 2008 8:59 am    Post subject: M14P & M14PF engines |
				Vedenyeev have tried Western multigrade oils  and say that they are too thin.
  However,they do accept that a good Western  oil with detergent is significantly better than their oil.
  Richard
 Rhodds Farm
 Lyonshall
 Hereford
 HR5  3LW
 United Kingdom
  [quote]   ---
		petervs(at)knology.net Guest
				 Posted: Mon Apr 21, 2008 10:54 am    Post subject: M14P & M14PF engines |
				Hmmm, We have 4 yaks running Philips X/C 25W60 for Radial Engines for at least the last three years with no apparent problems yet.
 How do they quantify what too thin is?
 Squatch
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
  Sent: Monday, April 21, 2008 11:56 AM
  To: yak-list(at)matronics.com
  Subject: Re: M14P & M14PF engines
 Richard
  Rhodds Farm
  Lyonshall
  Hereford
  HR5 3LW
  United Kingdom
 ----- Original Message -----
 Sent: Monday, April 21, 2008 5:28 PM
 Richard
  Thanks, Jay
 From: Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
  Reply-To: <yak-list(at)matronics.com (yak-list(at)matronics.com)>
  Subject: M14P & M14PF engines    - Since      we have sold a lot more of these engines than anyone else I suppose we      should have a view on the relative issues between them.
  Rhodds Farm
  Lyonshall
  Hereford
  HR5 3LW
  United Kingdom
  ail Forum -
  matronics.com
     	  | Quote: | 	 		  |   href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c |
  dangerous content by http://www.invictawiz.com
  and is believed to be clean.
  -----------------------------------------------------------------------------       | 	  0123456789 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 	  0 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 	  1 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 	  2 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 	  3 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 	  4
		cjpilot710(at)aol.com Guest
				In a message dated 4/21/2008 11:48:32 A.M. Eastern Daylight Time,  richard.goode(at)russianaeros.com writes:
  I have 1,384 hours on my M-14P that I purchased from Aerostar new.
  At 438 hours, it started making metal and I found that the factory had  installed a scraper ring where the oil ring should have been on #3 piston.   At that point I scuffed the bores of all 9 cylinders, put in all new  rings and gaskets.
  At this annual I found #9 cylinder 46/80.  Found the top compression  ring busted.  Replaced all the rings on it from the original parts  that came with the engine from the factory. (I measured the end clearance of the  new rings and the old rings in the bore.  NO DIFFERANCE)
  I've had the mags rebuilt once (bearings and coil at 600 or 700hrs).
  Replaced the ignition harness and used the auto plugs (some 300 hours  now).
  I have ALWAYS used (from day one) a 10 micron oil filter.
  I have a pre-oiler and have always used 100w detergent oil (never multi  grade except in a pinch)
  I try to change the oil every 35 to 40 hours.  At this point  she uses about 1.75 qts/hr.
  On compression checks all air seem to be coming out the breather  only.  Average is 72/80.
  I normally cruise at 28imp and 2050 rpm.  During acro I set 2400rpm  and push and hold 32-34 imp.
  Plus I follow the items that Richard listed below.
  BTW keeping engines "Over Square" is not a pipe dream.  The M-14P may  not be as susceptible to same forces as the big engines (PW1830 or Wright  1820) but those same forces are there to some degree.  Believe if you had  were able to see ( I have ) the effects by not doing so (and paid for  it) you would never let the prop drive the engine.
  Jim "Pappy" Goolsby
   	  | Quote: | 	 		          - I would be interested to hear of M14P or      M14PF engines being operated in the US with over 1,000 hours since      new/overhaul - I am led to believe that there are engines with well over      2,000 hours - is this true?
 Rhodds Farm
 Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
		DANDMAZ(at)cox.net Guest
				 Posted: Mon Apr 21, 2008 1:15 pm    Post subject: M14P & M14PF engines |
				I have 890 hours on my CJ-6 Mp-14P that I  purchased from Carl Hays new in 1997.
  Have replaced the right mag coil,
  Like Jim same power in cruise and  acro.
  Last annual lowest cylinder compression 77/80.
  Have had a Champion (Ch48109)   oil filter since new.
  Used Aero Shell ( 100) and (120) for the first  300 hours then switched to Phillips X-C 25/60, here in Arizona (KDVT)  temperatures can run up to 50 celsius in the summer.
  Changed oil and filter every 35 to 45 hours,  burns 1/2 quart cruise and 1/2 to one quart during acro, oil tank  level 15 1/2 liters.
  Replaced the Ignition harness and spark plugs  with auto at 767 hours.
  Have heat pad on oil tank for low temperature in  winter.
  Plus I follow the items that Jim and Richard  listed.
   Don Andrews, N23YK
  [quote]   ---
		wlannon(at)persona.ca Guest
				 Posted: Mon Apr 21, 2008 6:29 pm    Post subject: M14P & M14PF engines |
				Hi Richard;
  There are no "detergent" oils certified for  aircraft engines. What you are referring to is an "ashless dispersant" additive  - quite different from automotive oils.
  The Russians probably tried Aeroshell W15W50 and  found it too thin. I agree with that.  IMHO the only acceptable multigrade  is Phillips X/C 25W60 (20W50 is also too thin). I have used 25W60 in  the R985, R1340 for about 25 years and in the Huosai and M14 for at least ten  years.
  Walt
  [quote]   ---
				 Posted: Tue Apr 22, 2008 1:23 pm    Post subject: M14P & M14PF engines |
				I concur with that too Richard.  I've run nothing but 25W60 in my stock
 YAK-50 for 9 years now.  Over 750 hours flown and the only issues I've
 had are mags going bad (both within 50 hours of each other) and leaking
 exhaust valves from lead build-up, now reduced greatly since I began
 running... Dare I say it?  MMO.
 Walt, just as a comment, there are indeed many brands of automotive oil
 that are "ashless dispersant".  An example is Valvoline Racing Oil.
 Same reason by and large.  The oil burns better without contaminating
 the plugs.  At least that is why I was led to believe by the factory
 rep.
 Mark Bitterlich
				 Posted: Tue Apr 22, 2008 6:14 pm    Post subject: M14P & M14PF engines |
				 	  | Quote: | 	 		   Walt, just as a comment, there are indeed many brands of automotive oil
  rep.
  Mark Bitterlich
 Mark;
 I had a conversation with a Shell rep many years ago about their new "W"
 ashless dispersant oil. As I recall they had experimented with detergent
 oils for aircraft but had determined that there was a danger of pre-ignition
 in air cooled cylinders due to the presence of super heated ash particles
 from the detergent. Apparently not a problem with liquid cooling.
 Perhaps racing engines are subject to higher temperatures and a similar
 problem with detergents.
 That was so many years back I may be totally out to lunch but that is what I
 remember.
 Cheers;
 Walt
		brian-1927(at)lloyd.com Guest
				 Posted: Wed Apr 23, 2008 3:52 pm    Post subject: M14P & M14PF engines |
				On Apr 21, 2008, at 9:56 AM, Richard Goode wrote:
  	  | Quote: | 	 		   Vedenyeev have tried Western multigrade oils and say that they are
  too thin.
 Yes, they are "thin". They are supposed to be. Have they done wear
 tests?
 At normal operating temperature 25W60 multi-vis oil has the same
 viscosity as 100W straight-viscosity oil. At maximum temperature 25W60
 has the same viscosity as 120W oil.
 Certainly the better pour-point and more rapid circulation of oil aids
 when the engine is cold and most prone to wear.
 So I come back to the question about wear tests.
 Brian Lloyd                         3191 Western Drive
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 — Antoine de Saint-Exupéry
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
