peteohms
Posted: Mon Apr 21, 2008 1:06 pm Post subject: Weight difference with grove gear |
I wonder what the weight gain or loss is on installing a grove gear on a Kitfox III.
Pete
Kitfox III 912ul
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
clint_bazzill(at)hotmail. Guest
Posted: Mon Apr 21, 2008 1:53 pm Post subject: Weight difference with grove gear |
Good question. I tried finding out informatin like that at Skystar and couldn't get it. Here is what I have.
I have a Model IV-1200 912 ULS
800-6 aircraft tires. Weight gain after installing spring gear (Hammerhead) 13.5 lbs, arm 1.875 inches. Should be close to what you are asking. I removed all the parts, weighed them and calulated the difference.
[url=http://en.wikipedia.org/wiki/United_States_federal_budget,_2007][/url]
Clint
Subject: Weight difference with grove gear
Date: Mon, 21 Apr 2008 15:03:32 -0600
[quote] I wonder what the weight gain or loss is on installing a grove gear on a Kitfox III.
Pete
Kitfox III 912ul
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
| [b]
peteohms
Posted: Mon Apr 21, 2008 2:23 pm Post subject: Weight difference with grove gear |
That's about what I needed. I presume that weight is just the difference between the stock gear and the Grove and doesn't take into account any other hardware. I don't want to have to weigh and balance the plane from scratch though I probably should. I bought my Kitfox III a couple weeks ago and I wouldn't swear to the logbook. Grove gear was already installed though I could find nothing in the W&B but the mod was entered into the logbook.
Pete
Kitfox III 912ul
Leander, TX
kirkhull(at)kc.rr.com Guest
Posted: Mon Apr 21, 2008 3:27 pm Post subject: Weight difference with grove gear |
If you are unsure I would weigh it. It will take less then 30 min and there are a # of spreadsheets out there that will do the calculations for you. If you do not have scales you can ask around and find some. A good place to start is you local EAA chapter. If you are near Kansas city chapter 612 has a set that they loan out.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Pete Christensen
Sent: Monday, April 21, 2008 5:21 PM
Subject: Re: Weight difference with grove gear
Pete
Kitfox III 912ul
Posted: Mon Apr 21, 2008 3:29 pm Post subject: Weight difference with grove gear |
I took all the parts off and weighed them. Then reassembled them and figured the new moment. Clint
[quote] From: apeterchristensen(at)sbcglobal.net
Date: Mon, 21 Apr 2008 16:20:34 -0600
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} That's about what I needed. I presume that weight is just the difference between the stock gear and the Grove and doesn't take into account any other hardware. I don't want to have to weigh and balance the plane from scratch though I probably should. I bought my Kitfox III a couple weeks ago and I wouldn't swear to the logbook. Grove gear was already installed though I could find nothing in the W&B but the mod was entered into the logbook.
Pete
Kitfox III 912ul
