thesupe(at)hotmail.com Guest
Posted: Mon Apr 21, 2008 7:20 am Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
Hi all, Just wondering where some of you have located your battery in your Kitfox 4? I'm sure the position will want to move depending if you have a 582 verses a Jabiru or 912, and even more with a Subaru. I know that the Avids tend to be a bit nose heavy, is this true also of the Kitfox? Is anyone on the list running a Jabiru engine in a Classic 1200? How is the performance? I have a 1500' strip with tall trees on the end and while I have no problem getting out of it with my Avid with a Jabiru, I've always done it with just myself in the plane and wouldn't concider it with a large passenger. I'm been looking at the fusaloge and thinking what all needs to be done before it can be covered and it would be a lot easier to put in a battery tray in the back now rather than later if it's possible it will be needed to balence t===============
Going green? See the top 12 foods to eat organic.
kitfoxpilot(at)msn.com Guest
Posted: Mon Apr 21, 2008 11:29 am Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
I just installed a larger battery in my Model IV 1200, I relocated it to behind the passenger seat. This will require a new W&B do to location and going from a 10lb battery to an 18lb battery.
Ray
| Quote: | From: thesupe(at)hotmail.com
Subject: Kitfox-List: Battery location in a Kitfox 4 Classic 1200 ???
Date: Mon, 21 Apr 2008 15:17:18 +0000
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass body.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Hi all, Just wondering where some of you have located your battery in your Kitfox 4? I'm sure the position will want to move depending if you have a 582 verses a Jabiru or 912, and even more with a Subaru. I know that the Avids tend to be a bit nose heavy, is this true also of the Kitfox? Is anyone on the list running a Jabiru engine in a Classic 1200? How is the performance? I have a 1500' strip with tall trees on the end and while I have no problem getting out of it with my Avid with a Jabiru, I've always done it with just myself in the plane and wouldn't concider it with a large passenger. I'm been looking at the fusaloge and thinking what all needs to be done before it can be covered and it would be a lot easier to put in a battery tray in the back now rather than later if it's possible it will be needed to balence t===============
Going green? See the top 12 foods to eat organic. | Quote: |
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
| Get in touch in an instant. Get Windows Live Messenger now. [quote][b]
Lynn Matteson
Posted: Mon Apr 21, 2008 11:33 am Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
How much difference is there between the Classic 1200, and a Model IV
Speedster?...besides the wingspan?
Lynn Matteson
flying w/490+ hrs
On Apr 21, 2008, at 11:17 AM, Jim_and_Lucy Chuk wrote:
| Quote: | Hi all, Just wondering where some of you have located your battery
Going green? See the top 12 foods to eat organic._-
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
clint_bazzill(at)hotmail. Guest
Posted: Mon Apr 21, 2008 12:11 pm Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
I have mine installed on pilots side as in instructions. Have added a lot of options since then and balance is fine. Do not believe in these huge batteries. I use standard motorcycle 14BS. I replace it every 2 years even though it appears perfect. If you are stalled somewhere because of battery, just go to your local auto store, put in the acid in the store and by the time you get back you are ready to fly. Battery is so light you can take it home with you. Kitfox Model IV-1200 1340 hours. Clint
[quote] From: kitfoxpilot(at)msn.com
Subject: RE: Battery location in a Kitfox 4 Classic 1200 ???
Date: Mon, 21 Apr 2008 19:26:28 +0000
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass body.EC_hmmessage {font-size:10pt;font-family:Tahoma;} I just installed a larger battery in my Model IV 1200, I relocated it to behind the passenger seat. This will require a new W&B do to location and going from a 10lb battery to an 18lb battery.
Ray
Get in touch in an instant. Get Windows Live Messenger now. | Quote: |
| [b]
kirkhull(at)kc.rr.com Guest
Posted: Mon Apr 21, 2008 2:25 pm Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
On my classic 4 with a Subaru the battery is in the tail as far back as it could go on a plate that drops down for access
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jim_and_Lucy Chuk
Sent: Monday, April 21, 2008 10:17 AM
Subject: Battery location in a Kitfox 4 Classic 1200 ???
Going green? See the top 12 foods to eat organic. | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Posted: Mon Apr 21, 2008 3:27 pm Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
How much does the battery weight? Clint
[quote] From: kirkhull(at)kc.rr.com
Subject: RE: Kitfox-List: Battery location in a Kitfox 4 Classic 1200 ???
Date: Mon, 21 Apr 2008 17:22:47 -0500
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal, .ExternalClass li.EC_MsoNormal, .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.EC_MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_EmailStyle19 {font-family:Arial;color:navy;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Going green? See the top 12 foods to eat organic. | Quote: | | http://www.matronics.com/contribution | 0
1[b]
Posted: Mon Apr 21, 2008 4:53 pm Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
Thanks Kirk and others who responded to my question. Kirk, do you have any pictures of your battery setup. Thanks, Jim Chuk Avids Kitfox 4 Mn
| Quote: | From: kirkhull(at)kc.rr.com
1 | Get in touch in an instant. Get Windows Live Messenger now. [quote][b]
Posted: Mon Apr 21, 2008 5:56 pm Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
I don’t have any handy but I will take some tomorrow when it go out to the airport
Sent: Monday, April 21, 2008 7:50 PM
Going green? See the top 12 foods to eat organic. | Quote: | | http://www.matronics.com/contribution arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.comblank>http://www.matronics.com/contribution |
Get in touch in an instant. Get Windows Live Messenger now. 0123456789 | Quote: | | http://www.matronics.com/contribution | 0 | Quote: | | http://www.matronics.com/contribution | 1 | Quote: | | http://www.matronics.com/contribution | 2 | Quote: | | http://www.matronics.com/contribution | 3 | Quote: | | http://www.matronics.com/contribution | 4 | Quote: | | http://www.matronics.com/contribution | 5 | Quote: | | http://www.matronics.com/contribution | 6 | Quote: | | http://www.matronics.com/contribution | 7 | Quote: | | http://www.matronics.com/contribution | 8 | Quote: | | http://www.matronics.com/contribution | 9
Posted: Mon Apr 21, 2008 6:04 pm Post subject: Battery location in a Kitfox 4 Classic 1200 ??? |
I don’t remember the weight I will have to check the logs and get back to you . it is a gel cell.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clint Bazzill
Sent: Monday, April 21, 2008 6:24 PM
Going green? See the top 12 foods to eat organic. | Quote: | | http://www.matronics.com/contribution arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.comblank>http://www.matronics.com/contribution | 0123456789 | Quote: | | http://www.matronics.com/contribution | 0 | Quote: | | http://www.matronics.com/contribution | 1 | Quote: | | http://www.matronics.com/contribution | 2 | Quote: | | http://www.matronics.com/contribution | 3 | Quote: | | http://www.matronics.com/contribution | 4 | Quote: | | http://www.matronics.com/contribution | 5 | Quote: | | http://www.matronics.com/contribution | 6 | Quote: | | http://www.matronics.com/contribution | 7 | Quote: | | http://www.matronics.com/contribution | 8 | Quote: | | http://www.matronics.com/contribution | 9
