		mwtucker
  Joined: 11 Mar 2008 Posts: 16 Location: Charlotte, NC area
				 Posted: Mon Apr 21, 2008 4:00 pm    Post subject: Rivet Gun Recommendation? |
				I'm looking for a recommendation on a pneumatic rivet gun...  I've searched the archives and see that the one from Harbor Freight appears a few times, but is "low cost"...  I read an article in Kitplanes that said to not skimp on the rivet gun and expect to pay $200 for a good one...
 Any feedback on this?
 Thanks in advance for your suggestions!
 Mike
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Awaiting delivery of RANS S-19 Empennage Kit |
		gfmjr_20(at)HOTMAIL.COM Guest
				 Posted: Mon Apr 21, 2008 4:16 pm    Post subject: Rivet Gun Recommendation? |
				Built my entire 601XL with the "cheap" Harbor Freight gun. Worked fine with just a drop of oil now and then.
  George May
  601XL 912s  200hrs
  	  | Quote: | 	 		   Subject: Rivet Gun Recommendation?
  Date: Mon, 21 Apr 2008 17:00:18 -0700
  --> Zenith-List message posted by: "mwtucker" <mwtucker(at)windstream.net>
  Mike
  http://forums.matronics.com/viewtopic.php?p=178305#178305
 More immediate than e-mail? Get instant access with Windows Live Messenger.  [quote][b]
		burbby
				 Posted: Mon Apr 21, 2008 4:42 pm    Post subject: Rivet Gun Recommendation? |
				I purchased mine from Northern Tool Company.   It was around $70 and it works fine.  I used the heads from the rivet gun from Zenith in it with no problems.   I think $200 is a little much and im sure you can get a real good one for that price but others can be had cheeper that will work fine.
 Gary
		zenith-list(at)steensland Guest
				 Posted: Mon Apr 21, 2008 4:52 pm    Post subject: Rivet Gun Recommendation? |
				I ended up getting the gun from ZAC.  I was going to go the harbor
 freight route, however I didn't want to hassle with manufacturing a nose
 piece for my gun.  I just spent the $80 and was done with it.
 george may wrote:
  	  | Quote: | 	 		   Built my entire 601XL with the "cheap" Harbor Freight gun. Worked fine
  George May
  601XL 912s  200hrs
  > From: mwtucker(at)windstream.net
  > To: zenith-list(at)matronics.com
  one...
  > Regards,
  > Mike
  Messenger.
  <http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refresh_instantaccess_042008>
 Lee Steensland
 601XL/Corvair (7637L reserved) Kit/Scratch builder 0.0% complete!
		kmccune
  Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
				 Posted: Mon Apr 21, 2008 4:53 pm    Post subject: Re: Rivet Gun Recommendation? |
				Mine is from HF too, it has not built an airplane , just a rudder and stab. But I could buy a number of them on sale for 200 bucks. Your will have to make the special machined head, very easy and about 5 bucks if you have the drill press ( or lath even better) already.
 Kevin
  _________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy  McCune |
				 Posted: Mon Apr 21, 2008 4:54 pm    Post subject: Rivet Gun Recommendation? |
				Harbor Freight.  29.95 on sale or $49.95 regular.  Works just fine.
		Andrewlieser
				 Posted: Mon Apr 21, 2008 5:09 pm    Post subject: Re: Rivet Gun Recommendation? |
				What PSI do you guys find best for pulling the rivets?  I set a few practice ones with my riveter from zenith at 90 and they back end didn't appear to pull tight enough?
  _________________ Andrew Lieser
S/N 6-7045
http://websites.expercraft.com/andrewlieser |
		macleod(at)eagle.ca Guest
				 Posted: Mon Apr 21, 2008 5:35 pm    Post subject: Rivet Gun Recommendation? |
				Andrew:
 I used 42 psi for A4s  and 60 psi for A5s with my excellent Zenith
 supplied rivet gun.  I didn't want the gun to pull too fast so that it had
 time to completely reshape the rivet head.
 Mike
 601 XL - Rotax FWfwd installation in progress
  Andrew Lieser
  http://forums.matronics.com/viewtopic.php?p=178324#178324
		PatrickW
  Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
				 Posted: Mon Apr 21, 2008 6:41 pm    Post subject: Re: Rivet Gun Recommendation? |
				I bought the green one in the ZAC toolkit.  Was not happy with it.  It's purely pnuematic, and "harsh".
 While visiting Quality Sport Planes in Cloverdale, I struck up a conversation about riveters with one of the airplane builders, and he let me pull a couple rivets on a 701 with his HF gun.
 Big difference.  You put oil in it.  I bought one on the spot, and have used it ever since.
 Patrick
 XL/Corvair
 N63PZ (reserved)
		John75142
				 Posted: Tue Apr 22, 2008 3:54 am    Post subject: Rivet Gun Recommendation? |
				Look on ebay they have hundreds, bought one for $40 and have built over half
 of my 701 without any problems. Just add a little oil and maybe make an
 adjustment now and then.
 John (Scratch building 701)
 Kaufman, Tx
  _________________ John Short |
		Trainnut01(at)aol.com Guest
				 Posted: Tue Apr 22, 2008 6:09 am    Post subject: Rivet Gun Recommendation? |
				Andrew
  I use the Zenith gun and have found that the best pressures for me are 45#  for A-4s and 60 #s for A-5s. Get a real pressure regulator, that flow restricter  that they send with the gun doesn't work well. Be sure and keep the bolts in the  gun tight. The bolts in the case tend to work loose and if they get to loose the  housing will break. (I'm not going to tell you how I know).
  Carroll
 Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
		jmcburney(at)pobox.com Guest
				 Posted: Tue Apr 22, 2008 7:28 am    Post subject: Rivet Gun Recommendation? |
				Hi, Mike (and List),
 I built 75% of my 801 using the cheap HF gun, after the $80 one from Zenith
 blew apart.  Also, the HF unit fits into a lot of places that the Zenith
 unit won't.  I even pulled AS5 stainless steel rivets in my firewall with
 the HF gun!  I'm not a fan of Chinese goods, but they did a winner with that
 rivet puller.
 Blue skies and tailwinds
 Jim
 CH-801
 DeltaHawk diesel
 Augusta GA
 90% done, 90% left
				 Posted: Tue Apr 22, 2008 7:36 am    Post subject: Rivet Gun Recommendation? |
				One more comment:  Nosepieces from the Zenith gun will fit the HF gun.
 Jim
 CH-801
 DeltaHawk diesel
 Augusta GA
 90% done, 90% left
		n85ae
				 Posted: Tue Apr 22, 2008 8:37 am    Post subject: Re: Rivet Gun Recommendation? |
				I've built TWO planes with the same harbor freight gun, I oiled it once and
 keep the pressure up around 100 psi. I've dropped it a half dozen times
 and at this point if it falls apart I'll be happy for the use I got out of it.
 I'd buy another in a second.
 Jeff
		kmccune
		bryanmmartin
				 Posted: Tue Apr 22, 2008 4:18 pm    Post subject: Rivet Gun Recommendation? |
				If I was building airplanes for a living and pulled thousands of rivets
   every day, I would probably buy a professional quality, expensive
 rivet puller. For building one airplane and pulling a few thousand
 rivets total, the inexpensive Harbor Freight riveter worked just fine. I
 built the whole airplane with it with no problem and it still works fine.
 Bryan Martin
 Zenith 601XL N61BM
 Ram Subaru, Stratus redrive
  _________________ --
Bryan Martin
do not archive. |
		rhodes1
				 Posted: Tue Apr 22, 2008 4:41 pm    Post subject: Rivet Gun Recommendation? |
				Hi
 Do you know the price of the HF gun?
 Getting started 601 xl scratch builder
 Thanks Don
		mwtucker
				 Posted: Tue Apr 22, 2008 4:59 pm    Post subject: Re: Rivet Gun Recommendation? |
				Can someone give me the part number of the Harbor Freight gun?  Or do they only sell one?
		bryanmmartin
				 Posted: Tue Apr 22, 2008 5:01 pm    Post subject: Rivet Gun Recommendation? |
				They list three on their website:
 http://search.harborfreight.com/cpisearch/web/search.do?keyword=riveter&Submit=Go
 I think the one I have is the one listed for $34.99. I would have to
 check the model number to be sure. These riveters may be available at
 their outlet stores also, I mail ordered mine.
  Hi
  Thanks Don
 Bryan Martin
 Zenith 601XL N61BM
Bryan Martin
do not archive. |
		Mitch Hodges
  Joined: 10 Jan 2006 Posts: 45 Location: Powder Springs, GA
				 Posted: Tue Apr 22, 2008 5:04 pm    Post subject: Re: Rivet Gun Recommendation? |
				 	  | burbby wrote: | 	 		  I purchased mine from Northern Tool Company.   It was around $70 and it works fine.  I used the heads from the rivet gun from Zenith in it with no problems.   ...
 I can verify the Northern Tool one works great, with the Zenith heads. I also have Stanley MR77C manual rivet puller, with a 360 degree swiveling head that works great for tight spots or weird angles.  The heads also fit it.
 http://tinyurl.com/3wjqyv
  _________________ Mitch Hodges
N601MH (Zenith 601HDS)
Builder Log at http://www.hodges.aero
Wings Under Perpetual Construction |
