Ignition switch replacement
wingnut
PostPosted: Tue Apr 22, 2008 3:12 pm    Post subject: Ignition switch replacement Reply with quote
I lost the keys to my Kitfox so I checked Aircraft Spruce for prices on ignition switches. I was a little surprised to find that the cheapest switch was $80. Does that sound right or am I looking in the wrong place?
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
avidfox
PostPosted: Tue Apr 22, 2008 8:57 pm    Post subject: Re: Ignition switch replacement Reply with quote
Mr. Wingnut,
Is this what your looking for? It's a "start" only, (momentary 'on') no mag switching function.
If it is, I'll let ya have it for say.......... nothing. I'll never use it. (famous last words eh?)
Still in sealed bag.
Just a thought here.... maybe the key(s) fit your existing switch, in which case you could then get a copy made and send the unit back.
Problem solved?
Steve
84KF
 Filesize:  285.43 KB
 Viewed:  671 Time(s)
wingnut
PostPosted: Wed Apr 23, 2008 4:30 pm    Post subject: Re: Ignition switch replacement Reply with quote
Thanks Steve. I found a tractor ignition at tractor supply that worked perfectly. The whole thing with two keys costs less than getting a key made.
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
NC_Bluesmoke
PostPosted: Fri May 23, 2008 4:50 am    Post subject: Re: Ignition switch replacement Reply with quote
Hi Steve,
I just recently acquired a Kitfox model 2 that is not yet flying - and it had no keys with it .... would your ignition switch with keys still be available ?
Thomas
Thomas Barnes
160 Falcons Way
Pittsboro, NC 27312
