bryanmmartin
Posted: Wed Apr 23, 2008 4:29 pm Post subject: Castellated Nuts. |
Seat belts aren't safety of flight items, control cable connections are.
Afterfxllc(at)aol.com wrote:
Quote: | Guys you don't use a castle nut on your seat belt attach or the canopy bolt
or a number of other places that you don't tighten the nut ...
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
n801bh(at)netzero.com Guest
Posted: Wed Apr 23, 2008 5:09 pm Post subject: Castellated Nuts. |
Ben Haas
N801BH
www.haaspowerair.com
-- Bryan Martin <bryanmmartin(at)comcast.net> wrote:
[quote]Seat belts aren't safety of flight items, control cable connections are
Gig Giacona
Posted: Thu Apr 24, 2008 5:22 am Post subject: Re: Castellated Nuts. |
They are designed to be "lock nuts" when torqued. When not torqued I'm not sure they are locked. I'm not an engineer and that is one of the reasons I generally follow the advice of the ACs and the designer.
msherman95632(at)yahoo.co wrote: | Gig.
I would have to disagree that a non-torqued lock nut is only slightly less likely to back off. Your kidding, right. That is the hole point of having a lock nut, so they don't back off.
601XL Under Construction
jmcburney(at)pobox.com Guest
Posted: Thu Apr 24, 2008 5:49 am Post subject: Castellated Nuts. |
If the problem with castellated nuts is cotter pins being worked loose (by
feet or something), I'd suggest using safety wire instead of cotter pins in
the castellated nuts. Put it through the nut, twist it, run through the
clevis, twist, turn the twist back through the clevis. Try it, you may like
it.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
frankroskind(at)HOTMAIL.C Guest
Posted: Thu Apr 24, 2008 6:11 am Post subject: Castellated Nuts. |
You may hold a repairman's certificate after you build, but if for any reason you are unavailable to perform the condition inspection required annually, the aircraft would have to be inspected by an Airframe and Powerplant rated mechanic. I, for one, would not risk my certificate on a castellated nut secured by safety wire.
[quote] From: jmcburney(at)pobox.com
Subject: Re: Re: Castellated Nuts.
Date: Thu, 24 Apr 2008 09:44:54 -0400
--> Zenith-List message posted by: "Jim McBurney" <jmcburney(at)pobox.com>
it.
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
In a rush? Get real-time answers with Windows Live Messenger.
nyterminat(at)aol.com Guest
Posted: Thu Apr 24, 2008 7:35 am Post subject: Castellated Nuts. |
Just use a bushing as suggested before and torque your nylon lock nut!!!!!!
Bob Spudis
Quote: | Quote: | --> Zenith-List message posted by: "Gig Giacona" <wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)>
ggower_99(at)yahoo.com Guest
Posted: Thu Apr 24, 2008 10:13 am Post subject: Castellated Nuts. |
In our 701 in the left Rudder pedal (with my best english) we broked twice the outer wire from the pin... The pin did not came off in either two of the events (was hold by the remaining wire. The first time we just changed the pin (in the prefight) and that was it.
The second time the wire of the pin broked (rubbing with the shoe, I think) we chosed to put a safety wire, it went inside the hole of the bolt and around the two strips and twisted in the back. Has worked perfectly (40 hrs to date since the change).
I think the material of the safety wire will resisit the job in this particular bolts.
Probably a photo is better, but until next sunday or monday.
Saludos
Gary Gower
701 912S (about 150 hrs) Cant remember exactly.
[quote] I know the regs but in the case of the foot pedal cables you can snag the pin with your shoe or pants and work it loose and when it rotates the pin can fall out allowing the nut to back off. Van's has about the same set up for the rudder cables and after a few pins came out they advised NOT to us castle nuts in that situation.
43-13 says that castle nut and cotter pins be used whenever the fitting is subject to rotation.
Steven Bornstein
475 E. North Broadway
Columbus, Ohio 43214
614 263-5819
In a message dated 4/23/2008 3:16:17 P.M. Eastern Daylight Time, amyvega2005(at)earthlink.net writes:
[quote]--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net>
not smart to NOT use castlenuts where there is motion, the motion could back out a noncastle nut. CAstle nuts need to be used where the is motion directly on the nut. such as the stering rods, control horns, etc. with the correct attachements of cotter pins there would not be problems with pins coming undone.
Juan
Gig Giacona
Posted: Thu Apr 24, 2008 10:59 am Post subject: Re: Castellated Nuts. |
Good a licenced A&P. Would you OK a lock nut in the same position?
frankroskind(at)HOTMAIL.C wrote: | You may hold a repairman's certificate after you build, but if for any reason you are unavailable to perform the condition inspection required annually, the aircraft would have to be inspected by an Airframe and Powerplant rated mechanic. I, for one, would not risk my certificate on a castellated nut secured by safety wire. |
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Thu Apr 24, 2008 11:10 am Post subject: Castellated Nuts. |
Since this thread is still continuing, let me add one more suggestion. There are self-locking castle nuts available from AS. They are number MS17825. I used them on my alieron cable connections at control pivot.
George May
601XL 912s
Quote: | From: frankroskind(at)HOTMAIL.COM
Subject: RE: Re: Castellated Nuts.
Date: Thu, 24 Apr 2008 10:07:58 -0400
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass body.EC_hmmessage {font-size:10pt;font-family:Tahoma;} You may hold a repairman's certificate after you build, but if for any reason you are unavailable to perform the condition inspection required annually, the aircraft would have to be inspected by an Airframe and Powerplant rated mechanic. I, for one, would not risk my certificate on a castellated nut secured by safety wire.
it.
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
In a rush? Get real-time answers with Windows Live Messenger. Quote: |
arget=_blank>http://www.matronics.com/Navigator?Zenith-List
p://forums.matronics.com
| In a rush? Get real-time answers with Windows Live Messenger. [quote][b]
Posted: Thu Apr 24, 2008 11:14 am Post subject: Castellated Nuts. |
No
[quote] Subject: Re: Castellated Nuts.
Date: Thu, 24 Apr 2008 11:59:01 -0700
--> Zenith-List message posted by: "Gig Giacona" <wr.giacona(at)suddenlink.net>
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=178992#178992
Spell a grand slam in this game where word skill meets World Series. Get in the game.
Gig Giacona
Posted: Thu Apr 24, 2008 12:34 pm Post subject: Re: Castellated Nuts. |
I didn't know they made those. That sounds like the best solution.
Thanks George.
gfmjr_20(at)HOTMAIL.COM wrote: | Since this thread is still continuing, let me add one more suggestion. There are self-locking castle nuts available from AS. They are number MS17825. I used them on my alieron cable connections at control pivot.
George May
601XL 912s
planecrazydld(at)yahoo.co Guest
Posted: Thu Apr 24, 2008 1:51 pm Post subject: Castellated Nuts. |
also, cotterpins becoming undone if installed correctly can usually be managed by reversing the direction of insertion of the bolt to result in the nut/cotterpin on the side away from the dragging interface.
Juan Vega <amyvega2005(at)earthlink.net> wrote:[quote] --> Zenith-List message posted by: Juan Vega
Juan
