		PLAV8R
  Joined: 22 Apr 2008 Posts: 30 Location: Prior Lake, Minnesota
				 Posted: Thu Apr 24, 2008 2:29 pm    Post subject: Re: CH601 Yuba City Photos Link |
				You guys are coming up with some valuable information.  What a knowledge base exist out there. It is greatly appreciated.
   My personal feeling is my brother picked the plane up just before AMD was going to Oshkosh that year.  I think they may have been in a rush to complete the plane.  Like I said in the Forum, There were issues right from the beginning.  When he was going for the check-out flight the pitot static system was not working. The brakes had low fluid and did not wore (had to be bled and filled).  The pitot static fitting to the auto pilot was cross-threaded.  I believe one of the fuel gauges did not work, so they pulled one from another airplane.
   When my brothers were flying to Minnesota from Eastman Georgia they had to disconnect the auto-pilot because it would make drastic changes.    When they got here (Lakeville, Mn) they replaced the auto-pilot with a new one.There was oil under the plane.  We looked around a bit and found that it was coming from the starter (a small hole in the back).  A piece of tape proved where the leak was.  He eventually received a new starter and the same thing occurred.  A magneto was also replaced.
   With the starter it was determined that there was excessive crankcase pressure (Continental O-200).  I believe they (an AP) replaced a cylinder and at that time they noticed a crack in the prop.  The AP check and found the wrong bolts (too long) were used for the prop and when torqued down to specs there must have been some play.  Maybe this created some harmonics of some sort during the previous 90 hours which may lead to fatigue (just a guess).
   My brother was also taking the LSA AP classes and received a certificate.  They looked at the plane during the class.  There was some mention of "smoking rivets" in the undercarriage.  To my best recollection AMD told him to maybe use "wet rivets" or something at the next annual.
   I had also been told that in some cases when putting the wings on that some people may have pounded the wing attach bolts to get things lined up during assembly, which I feel would create a stress riser.
 Hope this enlightens a little bit.
 IMPORTANT: It also has come to my attention that the A&P that discovered the cracked prop and torque problem, along with the instructor for my brothers LSA A&P are being litigated against.
 I hope to get someone at the NTSB to look at this forum and see all the valuable aids that may be here for their research.
 Thanks to every one of you,
 Don
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Donald J. Dennnehey Jr.
don.dennehey@gmail.com
Cessna 175  N7656M
Cessna 140  N90123 |
		tigerrick(at)mindspring.c Guest
				 Posted: Thu Apr 24, 2008 2:32 pm    Post subject: CH601 Yuba City Photos Link |
				 	  | Quote: | 	 		  > I hope the NTSB is thinking about these scenarios as much as we are. <<
 That's an understatement, Jim. Along with the NTSB sifting through the evidence with their fine toothed combs, you can bet that Zenith is also playing a big part in the determination of the causal factors.
 I just spoke with Sebastien at Zenith, and he did say that they're between a rock and a hard place in being able to release any of the specific findings of the investigation until the report is released by the NTSB.
 But, I can share what he told me. So far, the investigation into the California and Florida crashes hasn't turned any single "smoking gun" failure mode common to either one.  He assured me, that if they had found anything that implicated the airworthiness of the fleet, that there would be an immediate release about it.
 His own feeling is that there's just no way a 601 can suffer an in-flight breakup without encountering some massive G loads at some point in its past, overstressing the structure. As someone who has seen the cumulative effects of crack propagation in aluminum airframe structures (certified aircraft), I would tend to agree with him.
 So, I'll keep flying my 601 XL, but I will take a bit of extra time during the preflight, and check the main and rear spar attachments. I'll also take a very close look at all of the attach fasteners to make sure that they're not fretting, or torqued properly.
 Like everyone else whose butt is on the line every time they saddle up in a 601 (or any other aircraft), I'm looking forward to the day we have some concrete answers.
 But in the mean time, I'll exercise a little extra vigilance while inspecting the airframe.
 Rick Lindstrom
 N42KP
		Afterfxllc(at)aol.com Guest
				I think that is a bit unfair...  We don't see the details of other  planes crashes so we don't know if the wings were on them or not at the time of  impact. I know Van's had to retest their wing design because of some wing issues  and the test showed the wings were engineered correctly. Just as Zenith has  done. I have it on good authority that one of the 601's was seen on radar  ascending and descending 3 to 400 feet just before break up so what does that  tell us? The NTSB has no obligation to report or even examine a experimental  crash so we get less than great information. Someone from the EAA should get  together a team together and study crashes if no one else is doing it to our  satisfaction.
   	  | Quote: | 	 		  This was    my point from an earlier posting that no one commented on.  I counted    about 240 registered XL's in the US.  4 structural failures equals    1.7%.  That seems quite high to me.  I also looked at the NTSB    records for the top LSA's on the market and found zero structural failures and    very few fatalities.  Planes just don't break up at that rate.
 Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
		frankroskind(at)HOTMAIL.C Guest
				 Posted: Thu Apr 24, 2008 2:47 pm    Post subject: CH601 Yuba City Photos Link |
				Tort liability is among the reasons I neither fix airplanes, nor practice law anymore.  It seems to me that unreasonable standards of care will be applied by unknowledgeable juries and other finders of fact.
  Frank
  	  | Quote: | 	 		   Subject: Re: CH601 Yuba City Photos Link
  Date: Thu, 24 Apr 2008 15:29:59 -0700
  --> Zenith-List message posted by: "PLAV8R" <donald.j.dennehey(at)seagate.com>
  Don
  Cessna 175 N7656M
  Cessna 140 N90123
  http://forums.matronics.com/viewtopic.php?p=179037#179037
 In a rush? Get real-time answers with Windows Live Messenger.  [quote][b]
				 Posted: Thu Apr 24, 2008 2:48 pm    Post subject: CH601 Yuba City Photos Link |
				One more thing, there's a new letter from Chris on the Zenith site:
 http://www.zenithair.com/news/index.html
 Rick
				 Posted: Thu Apr 24, 2008 2:58 pm    Post subject: CH601 Yuba City Photos Link |
				Title 49 of the US Code does require the NTSB to investigate all civil aviation accidents:
  § 1132. Civil aircraft accident investigations
  (a) General authority.--(1) The National Transportation Safety Board shall investigate--
  (A) each accident involving civil aircraft
   	  | Quote: | 	 		    From: Afterfxllc(at)aol.com
 Date: Thu, 24 Apr 2008 18:25:24 -0400
 Subject: Re: Re: CH601 Yuba City Photos Link
 arget=_blank>http://www.matronics.com/Navigator?Zenith-List
 blank>http://www.matronics.com/contribution
  | 	  Back to work after baby– how do you know when you’re ready?  [quote][b]
		PLAV8R
				 Posted: Thu Apr 24, 2008 3:02 pm    Post subject: Re: CH601 Yuba City Photos Link |
				I want to reiterate.  I have great respect for Chris Heinz and his contributions to aviation.  If my father had any doubts of the integrity of the 601XL SLSA he would not have purchased one.  He also wanted the certified Continental.
 You people are the experts and I have nothing but admiration for each and every one of you.  I hope this gets figured out so I can go fly a 601XL again in the future.
 Sincerely,
 Don
Cessna 175  N7656M
Cessna 140  N90123 |
		purplemoon99(at)bellsouth Guest
				 Posted: Thu Apr 24, 2008 3:06 pm    Post subject: CH601 Yuba City Photos Link |
				If you've got a wind tunnel,or can get some one to test it I've a complete
 flying 601XL they can test.. Joe N101HD 601XL/RAM
		passpat(at)aol.com Guest
				 Posted: Thu Apr 24, 2008 3:15 pm    Post subject: CH601 Yuba City Photos Link |
				if everyone would say for now we (meaning anyone thinking of or buying a part or any kind of Zenair product connected to the 601XL) are not going to support any purchases or make any purchases until Zenair comments are made and supported we would get some action on thier part.
  Pat
				 Posted: Thu Apr 24, 2008 4:16 pm    Post subject: CH601 Yuba City Photos Link |
				Zenithair and Zenair seem to be very actively supporting the NTSB investigation.  If you can name one specific thing they should be doing, then do so, but to suggest a boycott is irresponsible.
  [quote]  To: zenith-list(at)matronics.com
 Date: Thu, 24 Apr 2008 19:09:09 -0400
 Pat
		PLAV8R
				 Posted: Thu Apr 24, 2008 4:30 pm    Post subject: Re: CH601 Yuba City Photos Link |
				I must agree.  I am not trying to point fingers.  I feel Zodiac has a lot of integrity and wants to resolve issues to a somewhat ambiguous set circumstances in a diligent manner.  I do hope they get all the support from any finding that may develop
Cessna 175  N7656M
Cessna 140  N90123 |
				 Posted: Thu Apr 24, 2008 4:45 pm    Post subject: CH601 Yuba City Photos Link |
				Jim, just for the record,I've always thought the rear spar attachment was
 the key to disaster I've thought every time I've removed or replaced a wing
 "That wing would twist up in a flash if the bracket or the bolt ever failed"
 I've thought that more than once. Time will tell.if I'am right or wrong. It
 doesn't matter to me what the problem is or whose fault it is ,I just want
 to see it found, and stop this losss  of life....  Joe N101HD 601XL/RAM
		jmaynard
  Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
				 Posted: Thu Apr 24, 2008 5:06 pm    Post subject: CH601 Yuba City Photos Link |
				On Thu, Apr 24, 2008 at 03:26:19PM -0700, Rick Lindstrom wrote:
  	  | Quote: | 	 		   So, I'll keep flying my 601 XL, but I will take a bit of extra time during
 How would you do this on preflight? Where would you look, and what would you
 do to make the places you're looking at accessible?
 Jay Maynard, K5ZC                   http://www.conmicro.com
 http://jmaynard.livejournal.com      http://www.tronguy.net
 Fairmont, MN (FRM)                        (Yes, that's me!)
 AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
  _________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
		jmaynard
				 Posted: Thu Apr 24, 2008 5:21 pm    Post subject: CH601 Yuba City Photos Link |
				On Thu, Apr 24, 2008 at 05:30:45PM -0700, PLAV8R - wrote:
  	  | Quote: | 	 		   I must agree.  I am not trying to point fingers.  I feel Zodiac has a lot
 I've given this a lot of thought. Basically, I've come to the conclusion
 that ZAC, Zenair, and AMD all want this resolved badly, and when a
 resolution is found, it's in their own interest to make sure the entire
 fleet is retrofitted with whatever the fix is found to be. The delay in
 releasing the results of the various accidents, and the delay in figuring
 out what a fix is, is not good for their business. I'm going back to the AMD
 factory next Monday, and will have this very conversation with John Degonia.
 In the meantime, I'm going to complete the purchase of N55ZC, and will fly
 it conservatively and stay well within its limits. If I happen to draw the
 short straw, I will at least have had the opportunity to own and fly my own
 aircraft - something I've wanted to do for a long time. Aviation is not
 without risks. As I've said here before, all we can do is mitigate them.
		n801bh(at)netzero.com Guest
				 Posted: Thu Apr 24, 2008 5:22 pm    Post subject: CH601 Yuba City Photos Link |
				I would expect nothing less from Zenith and Chris. They were outstanding in their sale and support of my 801 kit. Human nature dictates them being very concerned, probably bordering on "freaking out" with all thats happened. I pray for a timely and safe outcome to this matter and still have alot of faith in Zenith Aircraft....
 Ben Haas
 N801BH
 www.haaspowerair.com
 -- Rick Lindstrom <tigerrick(at)mindspring.com> wrote:
 --> Zenith-List message posted by: Rick Lindstrom <tigerrick(at)mindspring.com>
 Rick
				 Posted: Thu Apr 24, 2008 5:50 pm    Post subject: CH601 Yuba City Photos Link |
				I thought the same thing..... What could have caused that???   Joe N101HD
		steveadams
				 Posted: Fri Apr 25, 2008 2:43 am    Post subject: Re: CH601 Yuba City Photos Link |
				The problem as stated above is determining the sequence. Every structure has it's weakest links, and once overstressed it will fail in those areas regardless of the initial cause of the failure. Once the wing starts to go, it will subsequently overstress and fail at its' weakest points until it leaves the aircraft or is in a position in which it is no longer being stresed. Just saying "wow, look at the failure at x" tells you little unless you can determine the sequence. I wish I had an answer, because whether or not you fly an xl, just imagining that happening to any aircraft sends a chill down my spine.
		William Dominguez
				 Posted: Fri Apr 25, 2008 5:20 am    Post subject: CH601 Yuba City Photos Link |
				Can you tell us which of the incidents was the one seen in radar with the behavior you describe?
 William Dominguez
 Zodiac 601XL Plans
 Miami Florida
 http://www.geocities.com/bill_dom
  [quote] 	  | Quote: | 	 		    From: Afterfxllc(at)aol.com
  	  | Quote: | 	 		  | arget=_blank>http://www.matronics.com/Navigator?Zenith-Listp://forums.matronics.comblank>http://www.matronics.com/contribution |
  _________________ William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom |
		n85ae
				 Posted: Fri Apr 25, 2008 7:01 am    Post subject: Re: CH601 Yuba City Photos Link |
				If the wing attach was coming loose, or something else, it would not be
 unusual to see radar returns +/- a few hundred feet before the breakup.
 I don't know if the suggestion is that the pilot was climbing/diving, but
 it could well be they were fighting for control before the breakup.
 One more comment. Regarding the pic with the hinge with the missing
 part. I tested the A4/A5 rivets by making a box out of four piece's of
 1"x"4"x.025 6061. Two corners with A4's, an two with solids. I then
 used a hydraulic jack to pull the box apart.
 In all cases the A4's failed well before the solids, and in all cases the heads popped off. I repeated with A5's with the same results. The steel core
 makes them strong in shear, but once the structure bends they are very
 poor in tension.
 When I tested with Solids only, The structure itself failed by tearing
 around the rivet heads. The rivets did NOT fail.
 On my 801, I have replace all A4's and A5's on critical assemblies with
 solids. Were I building a 601 I'd definetly be attaching hinges with solids.
 That's not suggesting that was the failure, however EVEN if the the
 structure detached at impact - the rivets should NOT have failed. The
 metal should have torn away.
 I think the rivet system Zenith uses is basically good, however not for
 everything.
 Jeff
		thesumak(at)aol.com Guest
				 Posted: Fri Apr 25, 2008 7:16 am    Post subject: CH601 Yuba City Photos Link |
				Larry:
     You make some good points in your recent post, but with regard to your statement below, I respectfully disagree.  We have some very bright folks here and we are highly motivated to figure this out.  I have found the recent discussions which have centered around actual pictures of one of the accidents to be useful and for the most part reverent.
     601xl
     	  | Quote: | 	 		  Larry said: I really want to leave the debate on what happened here to structural engineers
 who have the training and experience necessary to back up any of their analysis.
  | 	  Plan your next roadtrip with MapQuest.com: America's #1 Mapping Site.
