clint_bazzill(at)hotmail. Guest
Posted: Thu Apr 24, 2008 11:26 am Post subject: KF2 Bungie connections |
When I was using bungies, would take a 1" X 1" X 2' board and bump the wraps together using a hammer. That would allow more room for the last 1 or 2 wraps. Worked very well for me. Clint
| Quote: | Date: Thu, 24 Apr 2008 08:01:02 -0700
Subject: Re: Re: KF2 Bungie connections
--> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
At 07:39 PM 4/23/2008, you wrote:
>Now the question: How exactly does a guys make six wraps of this
>thing? Four, easy... Five possible... Six?!? Does anyone have any
>tricks I could try?
Cory,
Check the archives again! This topic gets covered at least
once a year and there are innumerable methods. Mine is to get 4
wraps, then pull the slack to one end using channel-locks, then clamp
the 3rd wrap to the tube using vice grips and leather, then get two
more wraps, repeat until you get six. You can do it solo and with not
much cursing.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp==============
GONER752(at)aol.com Guest
Posted: Thu Apr 24, 2008 5:51 pm Post subject: KF2 Bungie connections |
Cory,
First, you'll need a copy of "The complete Longshoreman's guide to foul language", next needed is an act of Congress.....
Seriously, enlist a helper. One person inside, the other underneath. Tough to hold the turns with fingers, but is doable.(reference longshoreman's guide). Some guy's here have reported success holding the turns with zip(or cable)ties,or padded vice grips.Good luck.
Greg G
Macedon, N.Y.
23NK
n375KL
Mod such e, gt; - MATRONICS WEB FORUMS -
-> p; - List Contribution Web Site =========================
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
akflyer
Posted: Thu Apr 24, 2008 7:33 pm Post subject: Re: KF2 Bungie connections |
I dont understand the problems with the bungees. I just did mine on the Avid and it took 2 guys 5 minutes by hand. one inside one outside. We did 2 kitfox last year same way. I use a ratchet strap around the axle to hold the gear up then hook one side, pass it around and pull tight. While the guy on top holds the bungee over the truss, I pull though from the bottom and had back up. hell I had to take a wrap off last week cause we got it too tight just by hand. You want a challenge, try putting the bungees on a PA-12 without the proper tool.... that is just about a sure way to get a quick trip to the E.R. for stitches.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
corbob13
Posted: Mon Apr 28, 2008 5:37 pm Post subject: Re: KF2 Bungie connections |
Thanks for all the tips. With the combination of a few of your tips I was able to get it done. The first one was pretty bad, but after I got the technique down the second took like 15 minutes.
Cory
_________________ Cory
N903DB
Kitfox Model II, Rotax 582 |
