georgerace
Posted: Sat Apr 26, 2008 3:14 pm Post subject: Jabiru 2200 Air Ducts |
I am at the point where I am ready to install the fiberglass air ducts supplied by Jabiru USA in my FWF kit.
Has anyone out there done this?
In reading the instructions and information it says that the fixed divider in the duct should fall between the spark plugs. I notice that there is a gap between the heads and wonder if that is where the divider/deflector should be falling. Mine, on both sides, falls between the rear cylinder spark plugs on both sides.
It appears that in this location, I am going to need to remove most of the divider/deflector.
As it was factory installed I am wondering where I am going wrong.
Any suggestions greatly appreciated.
George
CH701 N73EX (Reserved)
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
IFLYSMODEL(at)aol.com Guest
Posted: Sat Apr 26, 2008 3:26 pm Post subject: Jabiru 2200 Air Ducts |
Hey George: I have not done it on a 2200, but on my 3300, I had to make quite a cut on the rear divider to enable the ducts to fit properly. I also had to add (smaller) dividers over each of the other cylinders to get the proper cooling on my 3300 powered 601 HD.
Lynn Nelsen
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
