Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Sat Apr 26, 2008 1:58 am Post subject: Position of trailing edge - Flaps/Aileron |
Hi Don & George
Just for confirmation: The LEADING upper edge of the flaps is approx. 3-4 mm (0,15 inch) higher than the trailing upper edge of the wing (at the rear spar, piano hinge is a the bottom of the wing).
The TRAILING edge of the flaps should be at the same position as that of the ailerons. If the flap's trailing edge is positioned higher than that of the ailerons, a stall could develop first at the wing tip rather than at the wing root, leading to uncontrolled quick movements of the plane around the longitudinal axis.
Could please somebody confirm (or disprove) my thoughts.
Cheers Martin
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
planecrazydld(at)yahoo.co Guest
Posted: Sat Apr 26, 2008 3:19 am Post subject: Position of trailing edge - Flaps/Aileron |
I agree. I was going to post a reply but got buried and forgot.
Martin Pohl <mpohl(at)pohltec.ch> wrote:[quote] --> Zenith-List message posted by: "Martin Pohl"
Hi Don & George
Cheers Martin
Martin Be a better friend, newshound, and [quote][b]
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Sat Apr 26, 2008 9:23 am Post subject: Position of trailing edge - Flaps/Aileron |
Martin--
Page 6-W-00 (edition 12/01) indicates that the flap extends 3mm above the rear wing spar and 2-3mm below the bottom of the wing.
George
George
| Quote: | Subject: Position of trailing edge - Flaps/Aileron
Date: Sat, 26 Apr 2008 02:58:03 -0700
--> Zenith-List message posted by: "Martin Pohl" <mpohl(at)pohltec.ch>
Hi Don & George
Cheers Martin
Martin Pohl
Zodiac XL QBK
http://forums.matronics.com/viewtopic.php?p=179302#179302
Spell a grand slam in this game where word skill meets World Series. Get in the game. [quote][b]
psm(at)ATT.NET Guest
Posted: Sun Apr 27, 2008 12:14 pm Post subject: Position of trailing edge - Flaps/Aileron |
At 02:58 AM 4/26/2008, you wrote:
| Quote: | Could please somebody confirm (or disprove) my thoughts.
One thing to consider is the twist built into the ailerons. This
creates a washout which is intended to prevent the tips stalling first.
Paul
XL fuselage
