dstasch
Posted: Sun Apr 27, 2008 6:00 pm Post subject: Registration questions E-LSA |
Hello,
I'm planning to build a 601xl with my son but I'm a little confused about a couple of things that I'm hoping you all can help me to better understand.
Ideally, we would build the plane together then I could use it to teach him how to fly.
If I understand correctly, to use an LSA as a trainer plane, it must be registered as S-LSA. However, I believe for it to be S-LSA it must be factory built. (or meet guidelines of the ASTM? can't remember the acronym) Am I correct on this? It's not possible (or maybe practical)for us to build an S-LSA in our garage?
What about E-LSA. I seem to recall reading that an E-LSA can be used to train the owner. If this is true, perhaps we could be co-owners or I could just put it in his name from the beginning, but I don't think a zero hour 16 year old in a homebuilt aircraft will sound very good to an insurance agent. Do any of you have a similar situation with perhaps training your spouse or children to fly in an LSA that you can share your experience with me?
Thank you!
Take care,
Dave
DO NOT ARCHIVE
Posted: Sun Apr 27, 2008 6:19 pm Post subject: Registration questions E-LSA |
I believe you can receive instruction in any aircraft you have built,
regardless of its classification. The restrictions are on instruction in
planes for hire. Check with the EAA to be sure.
-- Craig
psm(at)ATT.NET Guest
Posted: Sun Apr 27, 2008 6:21 pm Post subject: Registration questions E-LSA |
Hi Dave,
I don't have all the answers you seek, but may be able to help get you started.
First, you can't build an S-LSA. That has to be factory
built. Theoretically you could build an E-LSA, but in practice that
can't really be done today either since no factories I know of offer
E-LSA kits. There is some way to convert an S-LSA to E-LSA, but that
starts with a factory built plane too.
If you build any plane from a kit, the only way to get it properly
licensed is using an Experimental-Amateur Built airworthiness
certificate. That means it can't be used for hire, but there are
some ways to allow flight training in an E-AB plane. I don't know
the details, but one of the serious restrictions is the instructor
must agree to teach in the particular plane. You should talk to a
couple of instructors (preferably ones you learn about at your local
EAA chapter who are familiar with this issue) and see what their
requirements are. I suspect you will find a need for functional dual
controls, dual brakes, and other equipment requirements.
About insurance, some more leg work on your part is in order. My own
experience is the insurance companies are pretty agreeable to
insuring Zodiacs, but they want a certain amount of experience by
each pilot listed to be PIC. I'm sure any insurance agent can give
you more information on the specific needs for training a student
pilot in an E-AB Zodiac.
Good luck,
Paul
XL fuselage
At 07:00 PM 4/27/2008, you wrote:
| Quote: | If I understand correctly, to use an LSA as a trainer plane, it must
rsteele(at)rjsit.com Guest
Posted: Sun Apr 27, 2008 6:53 pm Post subject: Registration questions E-LSA |
Your 601XL would have to be registered as an Experimental.
There are two ways an experimental can be used for training, and
neither probably apply to your situation.
If you are the owner, you can receive training in your own plane.
An Experimental can also be used for transition training. You must
get permission from the FAA for this on a case by case basis.
Transition training means you aren't training for a new certificate,
just familiarity with the plane.
Also, be aware that there is a 40 hour test flight period where no
passengers may be carried. This basically means that if you plan on
taking lessons in you own plane, you must get someone else to fly it
for 40 hours before you are permitted to even be a passenger. After
the 40 hours "fly off", you my receive training in your own plane.
There is lots of much more authoritative information at eaa.org.
There are a few schools that use the factory build 601xl SLSA where
it's possible to get training
Ron
On Apr 27, 2008, at 10:00 PM, dstasch wrote:
Hello,
better understand.
Thank you!
Take care,
Dave
DO NOT ARCHIVE
http://forums.matronics.com/viewtopic.php?p=179732#179732
bryanmmartin
Posted: Sun Apr 27, 2008 7:11 pm Post subject: Registration questions E-LSA |
If you are building a CH 601 XL, you will have to build it as an
experimental amateur built. An S-LSA must be factory built and the E-
LSA option is no longer available for this aircraft since the "fat
ultralight" exception expired this January. Even though you can't
register the airplane as any sort of LSA, as long as the aircraft
falls within the limitations of the LSA rules, it can still be
operated by a sport pilot under the LSA rules.
You can receive training in an E-AB, you can give training in an E-AB,
you can pay for instruction in an E-AB, you just can't rent out the
airplane itself for training. You can receive training in any aircraft
that you own, regardless of its classification, as long as the
instructor will agree to train in that aircraft. If you are a CFI, you
should have no problem teaching your son to fly in your 601 XL. As far
as insurance goes, I have no idea how that will be handled, it will
depend on the insurance company. Just tell your son not to crash into
anything expensive.
Hello,
better understand.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
dstasch
Posted: Sun Apr 27, 2008 9:06 pm Post subject: Re: Registration questions E-LSA |
Wow, thank you for all your quick responses!
There's no question that we want to build, and now that I understand we will be building under the E-AB category, I'll go through and read the regs again. It should be a little less inundating now that I know what we're building
I don't have an Instructor rating but I do have the required hours and I don't mind doing the CFI training for the opportunity to teach my son.
As for the 40 hour test flight period, my plan is (or was if it's not a good plan to find a 601xl at a nearby school to get acquainted with and do the flight testing myself. If there's not a 601 available locally, I'm not too from Missouri, so I could go there for some training at Zenith.
Finally, as for not having my son not crash into anything expensive, I've been working on this with his driver's license for the past six months and every time I look in the mirror, I try to convince myself that the new gray hairs are just a coincidence
Thanks again, this is a wonderful group!
Take care,
Dave
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Mon Apr 28, 2008 3:09 am Post subject: Re: Registration questions E-LSA |
Pretty cool Dad
This topic comes up quite a bit, how do we get the EAA to put up better info for first time builder? They have some info, but it is almost as confusing as the FAAs and not very complete. I read the EAAs info forwards and backwards but could not decide what I was building and what I could and couldn't do in it. Finally I emailed the EAA and asked here, took both to get it clear.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Posted: Mon Apr 28, 2008 11:53 am Post subject: Registration questions E-LSA |
If you are both Documented as the builder which you show proof with pictures and the log book, Have the DAR register you both as builders of the plane, then you can fly the 40 hours off together.
Juan
zenith601xl(at)gmail.com Guest
Posted: Mon Apr 28, 2008 12:12 pm Post subject: Registration questions E-LSA |
No passengers are permitted during the 40 hour test period, even if they are registered as a builder. Solo only.
Dennis
On Mon, Apr 28, 2008 at 2:49 PM, Juan Vega <amyvega2005(at)earthlink.net (amyvega2005(at)earthlink.net)> wrote:
[quote]--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net (amyvega2005(at)earthlink.net)>
Juan
Posted: Mon Apr 28, 2008 1:53 pm Post subject: Registration questions E-LSA |
I disagree, if you have two builders, and they are documented as both builders of the plane, you can both fly at the same time.
Juan
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Mon Apr 28, 2008 2:34 pm Post subject: Registration questions E-LSA |
The piloting of an experimental during the test phase is not based on who builds the plane. The regs indicate that only required crew may fly during the 40 hours of test. If it is deemed that both builders are the required crew they might be able to fly together, however, I doubt it. To be able to have both parties legally fly together as required crew it would need to be signed off by the local FSDO .
George May
601XL 912s
[quote] Date: Mon, 28 Apr 2008 17:50:14 -0400
To: zenith-list(at)matronics.com; zenith-list(at)matronics.com
Subject: Re: Registration questions E-LSA
--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net>
Juan
Posted: Mon Apr 28, 2008 2:39 pm Post subject: Registration questions E-LSA |
I disagree to disagree. SOLO Only...
Unless the "crew member" is essential for the flight.
dstasch
