Fuel in wings
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV12-List
Jim Cone
PostPosted: Mon Apr 28, 2008 8:19 am    Post subject: Fuel in wings Reply with quote
It is not possible to use the wing for fuel. Unless you want to design your own plane, you will have to build it like it was designed. I have completed one wing and only have the tip to install on the other one.
Jim Cone
4-peat offender, two 6A’s, a 7A, and a 12
Checked by AVG.
4/28/2008 7:18 AM
- The Matronics RV12-List Email Forum -
http://www.matronics.com/Navigator?RV12-List
Jim Cone
3-peat offender
2 RV-6A's & 1 RV-7A
EAA Tech Counselor
EAA Flight Advisor
aslsa.rng(at)gmail.com
PostPosted: Mon Apr 28, 2008 2:00 pm    Post subject: Fuel in wings Reply with quote
Jim, You're right on this one, and you're wrong, too. There are two ways to put tanks in your wings.
One, get a letter of authorization from Van's allowing the change. The letter must mention your aircraft's N number and it is good for that airplane only.
Two, present the airplane to the FAA exactly as Van's designed it, get your E-LSA airworthiness certificate, and then install them. Once you have the ELSA AC you can do anything you want, all it takes is a log book endorsement and put the plane back into phase one testing for five hours.
Rick
2008/4/28 Jim and Bev Cone <jimnbev(at)olypen.com (jimnbev(at)olypen.com)>:
Jim Cone
4-peat offender, two 6A's, a 7A, and a 12
Checked by AVG.
4/28/2008 7:18 AM
Jim Cone
PostPosted: Mon Apr 28, 2008 2:23 pm    Post subject: Fuel in wings Reply with quote
Rick,
One, I doubt that Van’s will give a letter of authorization to do this change.
Two, the wing is not set up in such a way that this would be possible. It is not like the other RV wings at all. That is why I suggested that you would have to design your own plane, or at least redesign the wings. That would be a monumental task.
Jim
From: owner-rv12-list-server(at)matronics.com [mailto:owner-rv12-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Monday, April 28, 2008 3:00 PM
To: rv12-list(at)matronics.com
Subject: Re: Fuel in wings
Rick
Jim Cone
Checked by AVG.
4/28/2008 7:18 AM
Checked by AVG.
4/28/2008 7:18 AM
Checked by AVG.
4/28/2008 7:18 AM
Jim Cone
3-peat offender
2 RV-6A's & 1 RV-7A
EAA Tech Counselor
EAA Flight Advisor
PostPosted: Mon Apr 28, 2008 6:21 pm    Post subject: Fuel in wings Reply with quote
Jim, I didn't say it would be practical to do it, either way, just that you could. Smile
Rick
Rick,
One, I doubt that Van's will give a letter of authorization to do this change.
Jim
From: owner-rv12-list-server(at)matronics.com (owner-rv12-list-server(at)matronics.com) [mailto:owner-rv12-list-server(at)matronics.com (owner-rv12-list-server(at)matronics.com)] On Behalf Of Richard Girard
To: rv12-list(at)matronics.com (rv12-list(at)matronics.com)
Rick
Jim Cone
Checked by AVG.
4/28/2008 7:18 AM
Checked by AVG.
4/28/2008 7:18 AM
Checked by AVG.
4/28/2008 7:18 AM
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV12-List All times are GMT - 8 Hours
