Jon Reining
Posted: Tue Apr 29, 2008 7:36 am Post subject: Riveting Question |
I was cruising through channels last night and saw something on the Discovery Channel that showed an airplane manufacturer riveting wings.
They used a piece of masking tape over the head of their rivet gun. Why? Is it the "feel"? Does it make it more "non-slip"? Is it standard practice for everybody else in the world?
Jon Reining (with dad Bill)
40514 - we'll finish off the wings some day
Jim Berry
Posted: Tue Apr 29, 2008 8:08 am Post subject: Re: Riveting Question |
Jon
It reduces scratching. One piece of tape is good for only a few rivets before it wears through.
Jim Berry
40482
Finished with all fiberglass last week !
n212pj(at)gmail.com Guest
Posted: Tue Apr 29, 2008 1:45 pm Post subject: Riveting Question |
Protects the skin a little from banging marks; might also keep it from
slipping. Works fine.
John J
drfred(at)suddenlinkmail. Guest
Posted: Tue Apr 29, 2008 2:43 pm Post subject: Riveting Question |
Jon;
I also used just regular scotch tape. I used it on the factory head
side to hold the rivets in instead of rivet tape. Just fold over a edge
so you can easily get it back off. Works just as good as the expensive
rivet tape. Helps keep the scratches off the aluminum. Also, I used to
polish the head of the rivet set on the scotch brite wheel. It also
helps to cut down on scratches/poc marks.
Fred Williams
40515.
90% finishing rule applies.
carl.froehlich(at)cox.net Guest
Posted: Tue Apr 29, 2008 4:05 pm Post subject: Riveting Question |
It also ends "smilies" on round head rivets. I find clear packaging tape to
work best for both standard and flush rivet sets. Masking tape work for
standard rivets but needs to be changed out more often.
Carl Froehlich
RV-8A (400 hrs)
RV-10 (wings)
