Posted: Tue Apr 29, 2008 7:09 pm Post subject: Gliding range specs for Nanchang; subject change |
I have no idea what the glide ratio is for the CJ or YAKS... I'd guess
my 50 has one of about 10/1... But that is a pure guess. What I am
curious about as well is how most YAK/CJ folk fly their aircraft in the
pattern. Now-a-days it seems to me that I see a lot of folks in light
civils flying what is commonly known as the "Cross Country Downwind". I
mean when you stand there at the airport, it is hard to believe they are
still in the Class D airspace at New Bern! Little dots on the horizon
kind of thing.
On the flip side, I was taught as a youth to always be within gliding
range of the runway. My instructor said to me: "Boy, it would be pretty
damn embarrassing to crash an airplane at an airport anywhere else than
on the runway". Somehow that made sense to me in a weird kind of way.
As a Commercial Pilot, my instructor made me practice power off at the
180 approaches. I.E., At the point just opposite to the approach end to
the runway on the downwind, the engine was pulled to idle, and you had
to land at a point not more than 200 feet past a set point and NEVER
before. Slips/Flaps/Gear/Turns to final....all at your choice, but NO
MOTOR.
In the military of course, we flew a constant turn to touchdown at a
very specific AOA, ... AKA "The Carrier Approach". I never really knew
how or WHY this came about until I flew a YAK-50. Suddenly the reason
for that became perfectly clear. I fly my 50 so close to the runway on
downwind that when I go over the tower, they can't see me anymore!
Worries the poor SOB's no end, much to my glee!
So I am curious to see the consensus. How many people stick in close
and high versus wide and at perfect pattern altitude? And what are your
thoughts on both...... Which in a way makes sense as being related to
glide ratios?
Mark Bitterlich
Posted: Tue Apr 29, 2008 8:23 pm Post subject: Gliding range specs for Nanchang; subject change |
Wanna get your attention on downwind? Pull the throttle a the east Jesus box
patten that so many are flying. Then see if you make the runway or not. I'm
betting on NOT!
If the edge of the runway is not on your wingtip on downwind atleast in the
52 and the 50 to some extent, you are not going to make the runway when you
pull your power.
To answer your question, I fly an approximate 13 degree Approach in the 50
at 160 Kph. With rolling off the perch at the numbers or just slightly past
my aim point on the threshold. That pretty much is how I fly the 52 also but
with a steeper nose down approach. Those barn doors hanging out makes it a
lot easier.
Doc
jland(at)popeandland.com Guest
Posted: Tue Apr 29, 2008 8:55 pm Post subject: Gliding range specs for Nanchang; subject change |
I had my Examiner during the Commercial check ride say " please no
aerobatics on final" as I maneuvered for the dead stick emergency spot
landing after a spiral descent from 3500 feet overhead.
Basically the CJ comes down like a brick so I acted like a real emergency
and kept it high and used all the drag and maneuvering to hit my spot- got a
bit aggressive on final I guess but made it work. I've always understood
the idea of hitting the far fence at 30 mph rather than the trees in front
of the aim point at 80 mph.
Bomber patterns don't work in the CJ if the motor quits....
MOTOR.
jan.mevis(at)informavia.b Guest
Posted: Tue Apr 29, 2008 9:59 pm Post subject: Gliding range specs for Nanchang; subject change |
I prefer close and high, and always "carrier approach", slipping of what is
too much. Unfortunately there are quite some airfields in Europe where
you're supposed (urged) to fly a circuit like a big Boeing or Airbus and
preferably with a three degree approach on final. So I try to avoid the
bigger airfields as much as possible.
Jan
MarkWDavis
Joined: 03 Jan 2007 Posts: 104 Location: Syracuse, KS
Posted: Wed Apr 30, 2008 4:34 am Post subject: Gliding range specs for Nanchang; subject change |
Flying in Western Kansas and Southeast Colorado, the whole world is pretty
much an emergency landing field. Lots of straight roads and level flat
fields with a handfull of power lines thrown in. Never the less, in the
pattern, I''m never more than 1/2 the distance to the wingtip from the
runway and turn roughly 5 seconds past the intended point of landing less
the wind (which is always blowing). If someone else is in the pattern on an
overly extended pattern, I just tell them I'll be inside them and well out
of their way. I've never owned an airplane that had a tendency to actually
glide when the power was pulled, like T-Craft, etc. In my Navy days, a T-28
glided about like a YAK. The rest, in the event of an engine failure(s),
were simply returned to the taxpayers with a simple pull of a handle between
your legs.
Mark Davis
N44YK
dsavarese(at)elmore.rr.co Guest
Posted: Wed Apr 30, 2008 5:13 am Post subject: Gliding range specs for Nanchang; subject change |
Extracted from the Yak 52 manual.
Lift to drag ratio of Yak-52 airplane is K=7 with retracted landing gear and
K=5.5 with extended. So the descent distance could be calculated as: L = K ·
H. Where H is airplane's altitude. Recommended descending speed to obtain
maximum descent distance is 160 kmph without wind, 150 kmph with 5 m/s
downwind and 170 kmph with 5 m/s headwind.
Headwind 5 m/s decreases descent distance by about 10%.
The most favourable turns are performed at 45 degree bank at 170 kmph air
speed, the altitude loss is about 110 m within 12.. 15 seconds for such 180
degree turn.
Dennis
cjpilot710(at)aol.com Guest
Posted: Wed Apr 30, 2008 5:58 am Post subject: Gliding range specs for Nanchang; subject change |
The basic parameter I use that seem to work is at 1000 agl, I can make a 180 turn to a point that is 1/3 the distance in from the wing tip. That does not hold true for lower than 1000 of course. The distance part is still good.
I have a rather neat situation here at Eagles Nest. After TO if I can get to 200-300 agl a 45 deg turn to the right will get me to a pasture long enough for a landing. 900 to 1000 and 35 degree right turn will actually put me on another runway at another airpark. (Yeah we have private fields up the Ying-Yang here). Now that is for a south takeoff. The area around my field to north is woods and a rather large lake. I need 200 feet to clear the woods, so its a water ditching after that. (The lake is totally isolated and chuck full of bass, snakes, and gators)
The point is that you should be familiar the area around your airport and not only plan for the engine failure in the pattern but the takeoff too.
I live under a MOA. That has a lot of advantages!
One. 3 or 4 times a month, after dark, we get the low level night training gun ships and Blackhawks. They are always about 200'. Our airfield must be a check point cause they'll cross dead center of the runway. (We had one land here when his chip light came on). Also we seen every kind warbird over our field when they use the ranges to south and north. Even B-1Bs!
Two. Humphy Dittle has their school over at DAB and they fill the skies and surrounding fields BUT THEY DON'T EVER COME INTO THE MOA.
God I love this place.
Jim "Pappy" Goolsby
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
petervs(at)knology.net Guest
Posted: Wed Apr 30, 2008 12:22 pm Post subject: Gliding range specs for Nanchang; subject change |
I like to be able to spit on the runway from downwind!
Squatch
ChangDriver
Posted: Wed Apr 30, 2008 6:17 pm Post subject: Re: Gliding range specs for Nanchang; subject change |
Ah yes, the old Boeing pattern in the spam can. I instructed some at LNA in Florida where there were many students. I've seen students bust PBI airspace about 3 miles away in the "pattern". I once saw a 152 do a 360 for "spacing" behind a twin. Best thing an instructor can do is pull power in downwind and make em try to get to the runway. It is a lesson they never forget. However, too many instructors are looking for the next job and really don't care as they are there building time not building better pilots.
I moved here (NC) and went flying with a low time CAP guy at RDU. We were give a long straight in approach by the controller. He flew a perfect final approach - for an airliner. Under us were woods, rock quarries, etc. I asked him why he flew the approach like he did. His answer was he had the glide slope nailed. Nice, but why do you need to do that in a 182? No answer. Heck, we could have stayed at 1000 feet AGL all the way to the threshold and still landed on the runway.
Also remember, stay close and be very aware of where the wind is coming from as it may push you out of range (or too close) if not properly corrected for.
Craig
