		bhancock(at)worldwidewarb Guest
				 Posted: Wed Apr 30, 2008 9:34 am    Post subject: Glide speed and carrier approaches |
				Gang,
 I like practical guides when it comes to things like this, others
 like mechanics and numbers.  I have found Pappy's rule of thumb to be
 accurate. The inboard split of the aileron seems to work well with a
 windmilling prop with the M14P....I've tried it from various
 altitudes and a 170 km/h speed (90 knots).  I seem to remember Brian
 Lloyd doing an extensive test on this some time back and posting it.
 Should be able to do an archive search....
 As for carrier landings, I fly them almost exclusively....CJ, Yak,
 L-39, Lancair...it's my comfort level and fun - and the payoff at the
 end of a boring cross country flight.  That being said it is much
 more to manage in a shorter amount of time.  We fly pretty forgiving
 airplanes, but if your too tight to the runway that will require
 getting closer to the stall (due to steeper bank angle) in the
 constant turn to final.  As mentioned, too far away has other
 problems.  The critical things are airspeed and bank angle.  Just
 remember your stall speed increases with your bank angle.    If
 you're new to the overhead approach, take it slow....start your
 breaks (60 degrees of bank, 2 Gs) at the departure end of the runway
 and then progressively move them towards the approach end as you get
 more comfortable and habit patterns develop.
 My two cents.
 Oh, and start practicing now for the Carrier Landing competition at
 ARS.    It will be on Friday evening.  All Red Star VII is May
 14-18.  If you have not yet registered, please visit flyredstar.org
 to register now.
 Barry
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		kurt(at)scitechsys.com Guest
				 Posted: Wed Apr 30, 2008 9:53 am    Post subject: Glide speed and carrier approaches |
				Speaking of ARS - any news on Rental Cars and maybe a schedule of events?
 Kurt Howerton
 N923YK
 http://cj6.scitechsys.com
 Barry Hancock wrote:
  <bhancock(at)worldwidewarbirds.com>
  Gang,
  I like practical guides when it comes to things like this, others like
  windmilling prop with the M14P....I've tried it from various altitudes
  and a 170 km/h speed (90 knots).  I seem to remember Brian Lloyd doing
  an extensive test on this some time back and posting it.  Should be able
  As for carrier landings, I fly them almost exclusively....CJ, Yak, L-39,
  Lancair...it's my comfort level and fun - and the payoff at the end of a
  boring cross country flight.  That being said it is much more to manage
  in a shorter amount of time.  We fly pretty forgiving airplanes, but if
  your too tight to the runway that will require getting closer to the
  stall (due to steeper bank angle) in the constant turn to final.  As
  mentioned, too far away has other problems.  The critical things are
  airspeed and bank angle.  Just remember your stall speed increases with
  your bank angle.    If you're new to the overhead approach, take it
  slow....start your breaks (60 degrees of bank, 2 Gs) at the departure
  end of the runway and then progressively move them towards the approach
  end as you get more comfortable and habit patterns develop.
  My two cents.
  Oh, and start practicing now for the Carrier Landing competition at ARS.
     It will be on Friday evening.  All Red Star VII is May 14-18.  If
  you have not yet registered, please visit flyredstar.org to register now.
  Barry
		skidmk
  Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
		MarkWDavis
  Joined: 03 Jan 2007 Posts: 104 Location: Syracuse, KS
				 Posted: Wed Apr 30, 2008 10:24 am    Post subject: Glide speed and carrier approaches |
				The purpose of the carrier landing pattern is to recover a group of
 airplanes as quickly as possible while a carrier is turned into the wind
 with a consistent minimum interval.  Most airwings use a 45 second interval
 during the daytime.  It gives enough time to get an airplane out of the
 wires and across the foul line in time for a clear deck for the following
 aircraft.   Night time only increases to 60 seconds.   Too close of
 intervals result in foul deck waveoffs.  Too many foul deck waveoffs and the
 Captain and Admiral get pissed.  Our airwing logged the landing intervals on
 every daytime recovery to identify those that couldn't stay within +/- 5
 seconds of the 45 second target.  All aircraft must maintain a uniform
 pattern to maintain a constant interval.  That's the part we need to work
 on.  Everyone in a formation flight needs to be flying a similar pattern to
 avoid dangerously close intervals for successive landing airplanes.   The
 landing pattern needs to be briefed AND DEBRIEFED on every formation flight.
 Tight or loose doesn't matter as much as uniformity and the wingmen should
 be following the lead's distance abeam out of the break.
 Mark Davis
 N44YK
		buddairbum(at)cox.net Guest
				 Posted: Wed Apr 30, 2008 1:29 pm    Post subject: Glide speed and carrier approaches |
				A note on 180 degree "carrier type" approaches in a civilian context.
 Although I'm flying neither a Yak nor a CJ, I make 15-25 approaches a day
 instructing landings in my Pitts,in which many folks also fly 180 degree
 approaches. I did too until I watched a friend, a former Scooter jockey
 flying his Pitts, roll off the perch and miss seeing a C-150 on a long, low
 straight in. He managed to time it so that he never saw the 150 through the
 entire approach and actually touched down about 200 feet directly behind
 him. He roared right up behind it until the wings popped into view around
 the nose and he careened off the runway to avoid it.
 The Navy can fly those kinds of approaches because everyone in their context
 is flying the same kind of pattern in the same place. Plus, they are all
 professionals. On a civilian field, where at least half the people in the
 pattern are severely wanting in commonsense and flying ability, you never
 know where they are going to be. And, once you're committed to the turn, you
 don't have another chance to check final for traffic. Plus, your nose is
 following traffic. I personally know two people who have landed on other
 airplanes flying that approach (no physical injuries in either) and, if I
 know two, there must be dozens of others.
 I now put a short base leg in the approach (I call it a "belly check") to
 give me one more peak. It also eliminates the problem of an over-shooting
 cross wind pushing a pilot into centerline and having to tighten up the turn
 at the bottom, right when you really don't want that much bank.
 No one asked, but that's my two cents and it's worth what you paid.
 Budd Davisson
  Mark Davis
  N44YK
		MarkWDavis
				 Posted: Wed Apr 30, 2008 3:17 pm    Post subject: Glide speed and carrier approaches |
				Budd,
      I agree.  I usually do a quick belly check at the 90 for one last
 glimpse for anyone on short final.  A short puff of smoke can be helpful if
 there's any question of any other traffic around.  But, as your point
 illustrates, the long low straight-in is maybe a more dangerous approach
 than a tight turning carrier type approach.  Never the less, fault is
 immaterial to the victim when someone is killed.
 Mark Davis
 N44YK
		brian-1927(at)lloyd.com Guest
				 Posted: Thu May 01, 2008 9:51 am    Post subject: Glide speed and carrier approaches |
				 	  | Quote: | 	 		   Although I'm flying neither a Yak nor a CJ, I make 15-25 approaches
  a day
  degree
  jockey
  long, low
  through the
  behind
  around
 The pattern is a dangerous place. You have to be aware no matter where
 or how you fly the pattern. You can fly a normal 'civilian' approach
 and find other aircraft where you don't expect them to be.
 One thing I can say about the continuous turn to final, you are
 exposed to so much less of the pattern so you have a smaller region to
 inspect for other traffic just before you start your turn from
 downwind. Bozo on a cross-country pattern is not a threat as he is not
 going to impinge on your airspace until well after you are no longer
 there.
 And I am sure plenty of people can argue. To that I reiterate that the
 pattern is a dangerous place and one must be vigilant regardless of
 how one flies the pattern.
 Hmm, one thing to consider: which is more likely to occur -- some bozo
 flying a bogus pattern or an engine failure? If Bozo is more likely
 then focusing on avoiding that scenario is likely to produce fewer
 accidents than focusing on preparing for an engine-out event. That
 might be a useful datum when trying to decide how to operate a Yak or
 CJ in the traffic pattern (circuit).
 Personally, after thinking about all this and accounting for traffic,
 aircraft complexity, time needed to execute the pre-landing
 checklists, etc., I have adopted the continuous turn to final as what
 I believe to be the safest approach, even when flying spam cans. I am
 open to reasoned discussion as to why this may or may not be the
 correct answer. And, no, "well, the way I was taught in the ...," is
 not reasoned discussion unless you have a clear explanation of why you
 were taught that way.
 YMMV.
 Brian Lloyd                         3191 Western Drive
 brianl AT lloyd DOT com             Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
		ChangDriver
				 Posted: Thu May 01, 2008 6:30 pm    Post subject: Re: Glide speed and carrier approaches |
				OK, ponder these items:
 1) In a prior post, it was stated "stall speed increases with angle of bank."  Well, not really.  We should all become students of the V-G diagram.  Stall speed increases with increased load factor.  It happens that load factor increases with angle of bank.  However, in some banked flight regimes, such as banked descending flight, the load factor may not increase.
 2) At a controlled field, controllers will typically put an overhead break approach 500 feet above the normal pattern altitude for single engine piston aircraft.  This is in the operations manual for air traffic control.
 3) The AIM provides info on the traffic pattern.  The "recommended" pattern is rectangular with left turns.  This pattern is mostly a safety of flight pattern.  It allows a pilot to get wings level before reconfiguring the aircraft (flaps, gear, change power, etc).  It also allows for a visual check of where the runway is (high wing planes) and allows a look at the final approach corridor (remember, if there is an instrument approach for the runway you are landing on, there may be instrument traffic flying an approach and not talking on your frequency yet).  Also, you will note the names of the legs are designed for position reporting.  The only items in "key traffic pattern operations" is to fly downwind at pattern altitude (unless otherwise instructed by a controller) and to complete the turn to final at least 1/4 mile before the runway.  Given this, the continuous turn to final does not conflict with the AIM.
 Craig
		scott.glaser(at)thedefian Guest
				 Posted: Fri May 02, 2008 10:25 am    Post subject: Glide speed and carrier approaches |
				I recently had some friends going for their PPL and we had a similar
 discussion regarding traffic patterns.  When I was learning my instructor
 bordered on being physically abusive if I was not within gliding distance of
 the runway anytime after being established on downwind.  Several of my
 friends who are currently working on or have recently received their PPL
 looked at me with a blank stare when I asked about this technique.
 Awareness of engine out gliding distance in the pattern wasn't even taught.
 They did of course practice engine outs but that was merely practice for off
 field situation.  They said their instruction was focused on quality of
 their pattern and setting up their approach.  It was taught very much from
 the airline pilot perspective.  It was kind of disturbing if you ask me, but
 then again it's not how I was raised.
 S
				 Posted: Fri May 02, 2008 3:23 pm    Post subject: Glide speed and carrier approaches |
				On May 2, 2008, at 11:23 AM, <scott.glaser(at)thedefiantcompany.com> wrote:
  instructor
  distance of
  PPL
  taught.
 That is *REALLY* odd because a power-off spot landing from downwind is
 a REQUIRED maneuver for PPL. (+200'/-0' from designated touch-down
 point.)
  	  | Quote: | 	 		   They did of course practice engine outs but that was merely practice
  for off
  of
  much from
  me, but
 That was true for a long time but the FAA has brought this home with
 the required demonstration of the power-off spot landing. I let my CFI
 lapse two years ago and had to take a check-ride again. The DE was a
 stickler on this as it had just recently been added to the list of
 required maneuvers. As a CFI one must demonstrate this to CL
 proficiency, i.e. +100'/-0' from the designated touchdown point.
				 Posted: Sat May 03, 2008 3:15 am    Post subject: Glide speed and carrier approaches |
				No, no.  Sorry if I was confusing.  They did perform the power off landings
 but they were never taught to keep the airplane close enough to glide to the
 runway power off at all times.   Wasn't even mentioned in their training.
 S
				 Posted: Sat May 03, 2008 8:20 am    Post subject: Glide speed and carrier approaches |
				On May 3, 2008, at 4:12 AM, <scott.glaser(at)thedefiantcompany.com> <scott.glaser(at)thedefiantcompany.com
  > wrote:
  landings
  glide to the
  training.
 Well, I think Jerry had it right. In the course of a flight you are
 rarely within gliding distance of a runway. And I did make the point
 about the likelihood of engine failure vs. dealing with bozos in the
 pattern. The incidence of bozos is much greater than the incidence of
 engine failure so if you have an either/or situation you need to
 accommodate the more likely scenario.
 So maybe the right answer IS "fly the published pattern."
 But I still prefer a continuous turn to final.
 <sigh>
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 — Antoine de Saint-Exupéry
				 Posted: Sat May 03, 2008 12:46 pm    Post subject: Glide speed and carrier approaches |
				Somewhere where between 2002 and 2005, the feds removed a paragraph from the
 PPL PTS that said they had to set up the aircraft in such a way on approach
 so as to always be within power-off gliding distance. I suspect they removed
 it because it was in direct contradiction to their statements about
 stabilized, power-on approaches in a later section.
 On 5/3/08 9:18 AM, "Brian Lloyd" <brian-1927(at)lloyd.com> wrote:
 > landings
 > glide to the
 > training.
  <sigh>
  ‹ Antoine de Saint-Exupéry
				 Posted: Sat May 03, 2008 1:37 pm    Post subject: Glide speed and carrier approaches |
				Box pattern or continuous turn question aside, back in the day they trained
 you to fly a stabilized approach and still be able to make the runway.  A
 homebuilt pilot found out the ramifications of being too far out at
 Rosamond, CA last year.  First flight of his homebuilt Zenith.  He went for
 a handful of power on base and didn't get it.  He was too far out and hence
 wound up on house roof .25 mile short of the runway (across the street from
 my house).  Granted this a bit of unusual situation in that it was
 homebuilt's first flight but still, staying within gliding distance and
 maintaining the pattern seem like a doable things considering the
 consequences.
		petervs(at)knology.net Guest
				 Posted: Sun May 04, 2008 6:59 am    Post subject: Glide speed and carrier approaches |
				Why does everyone assume that a stabilized approach can only be made in a
 straight line? You can fly downwind, use aimpoint out the side of the
 canopy, roll off the perch and make a 180 degree turn following a constant
 descent path with a constant bank angle flying your aimpoint all the way to
 touchdown. That is precisely a stabilized approach.
 Squatch
