Pennzoil 2 cycle oil OUT OF PRODUCTION
Steve Boetto
PostPosted: Thu May 01, 2008 2:34 pm    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
IN CASE YOU MISSED THIS POST UNDER THE OLD TITLE
steve
In a message dated 4/30/2008 9:26:15 P.M. Eastern Daylight Time, N27SB(at)aol.com writes:
Guys, I hate to start a panic here but Pennzoil has discontinued production of this product, the only supply out there is what is in circulation. It has something to do with Shell buying the product line. Lockwood is testing several new products as a replacement. Lockwood recently bought the last 500 cases available.
No one knows about this yet so it is a good time to stock up. Lockwood seems to think that the replacement will be as good or better. Lockwood originally did the testing for Rotax and Penzoil.
Steve B
Firefly 007/Floats
Firefly 0040/ Floats 2008 SnF Grand Champion
In a message dated 4/29/2008 8:01:55 P.M. Eastern Daylight Time, d-m-hague(at)comcast.net writes:
>Where do you all buy your Pennzoil air cooled 2 cycle oil from?
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
R. Hankins
PostPosted: Thu May 01, 2008 7:42 pm    Post subject: Re: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
Steve,
Do mean Pennzoil is phasing out Air-cooled Two stroke oil, or ALL two stroke oil? Could they be replacing it with their snowmobile oil? It is rated TC and TCW3. Says on their website that it is Rotax approved. There are a lot of air cooled Rotax powered snowmobiles out there. I wouldn't think they they would want to give up on the entire two stroke market, but stranger things have happened.
Roger in Oregon
1992 KXP 503 - N1782C
Arty Trost
PostPosted: Thu May 01, 2008 8:09 pm    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
Roger -
Pennzoil air cooled isn't TC rated - and isn't
compatible with Pennzoil's regular 2-stroke TCW3 oil.
(According to Phil Lockwood.)
Arty
Sandy, Oregon
Steve,
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=180630#180630
browse
Un/Subscription,
FAQ,
Forums!
Admin.
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
R. Hankins
PostPosted: Thu May 01, 2008 8:58 pm    Post subject: Re: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
Arty,
Pennzoil air cooled is rated API Service TC. (You may have thought I meant NMMA TC-W vs TC-W3)
Pennzoil snowmobile is rated NMMA TC-W3 and also API Service TC. I've attached the manufacturers documentation below.
I agree with not mixing the two.
2-CycleAirCooled.pdf
 Filename:  2-CycleAirCooled.pdf
 Filesize:  33.13 KB
 Downloaded:  858 Time(s)
AdvancedPerformanceSnowmobile.pdf
 Filename:  AdvancedPerformanceSnowmobile.pdf
 Filesize:  30.48 KB
 Downloaded:  1056 Time(s)
Roger in Oregon
Steve Boetto
PostPosted: Fri May 02, 2008 4:06 am    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
Roger, I am surprised that nobody is picking up on this topic except you. PENNZOIL AIR COOLED 2 STROKE OIL IS GONE. Only existing stock at retailers is left. Lockwood Aviation bought the last 500 cases. according to the nice lady at the Lockwood booth at SnF it has to do with Shell buying the Pennzoil line. I used to buy my oil from a Pennzoil quick change oil place. He would sell it to me at cost. A few months ago he could not get it any more. He said he was told it was out of production. Lockwood Aviation confirmed this at SnF and was surprised I knew.
I was just trying to give you guys a heads up. NOBODY KNOWS ABOUT THIS YET.
Steve
In a message dated 5/1/2008 11:45:17 P.M. Eastern Daylight Time, rphanks(at)grantspass.com writes:
Steve,
Roger in Oregon
Thom Riddle
PostPosted: Fri May 02, 2008 5:30 am    Post subject: Re: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
I emailed Pennzoil directly about this and got the following reply.
Dear Mr. Thom Riddle; Thank you for your interest in our products. The Pennzoil 2-Cycle Oil for Air Cooled Engines is still avalable in 8 ounce bottles. (Part# 4053) Please contact the distributor in your area, phone number 716-693-0150 for help in locating this product.
Sincerely
Product Technical Service
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Steve Boetto
PostPosted: Fri May 02, 2008 8:15 am    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
The reason that the 8 oz bottles are still available at the distributor is because there is less demand for that size. The price per oz is much higher than the 16 oz. If you dig deeper I think that you will find that Pennzoil is not packing any new ones.
If you like this product I suggest that you buy whatever 16 oz stock you can find to hold you over until Lockwood has a new recommendation. Just trying to give the List a Heads Up.
Steve B
Firefly 007/Floats
In a message dated 5/2/2008 9:33:56 A.M. Eastern Daylight Time, riddletr(at)gmail.com writes:
djwatson(at)olg.com
PostPosted: Fri May 02, 2008 8:23 am    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
Did I mention your local Wal-Mart usually has it?
Dennis
rlaird
PostPosted: Fri May 02, 2008 8:43 am    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
Well, that response doesn't really answer the question.... "still
avalable [sic]" doesn't specifically mean that they are producing the
oil, only that some 8 ounce bottles are still available.
Maybe a pointed question would be more helpful and get an answer that
would tell us if the specific air-cooled 2-stroke oil is or is
planning to be discontinued?
-- Robert
Sincerely
Thom Riddle
N221FA Allegro 2000 912UL
N197BG FS1/447
Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense.
- Buddha
http://forums.matronics.com/viewtopic.php?p=180663#180663
There are 10 types of people in this world: those who understand
binary and those who don't.
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
Dana
PostPosted: Fri May 02, 2008 9:08 am    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
At 08:04 AM 5/2/2008, N27SB(at)aol.com wrote:
Roger, I am surprised that nobody is picking up on this topic except you. PENNZOIL AIR COOLED 2 STROKE OIL IS GONE..
The product labeled "air cooled 2 stroke" is gone, replaced by "2 cycle outdoor" which is the same thing. Whether the "outdoor" product is being discontinued I don't know, but this may be the source of the confusion.
We're a tiny market, but with the number of ATV's, dirt bikes, chainsaws, and weed whackers out there I can't seem them abandoning this segment of the market.
-Dana
Sometimes it is easier to beg forgiveness than get permission. [quote][b]
DAquaNut(at)aol.com
PostPosted: Fri May 02, 2008 4:58 pm    Post subject: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
In a message dated 5/2/2008 12:08:37 P.M. Central Daylight Time, d-m-hague(at)comcast.net writes:
-Dana
  If you look on the back of both bottles you have mentioned you will find that they BOTH have the same stock # which is 4130 . The 4130 is located just above the bar code. It is the same # on the " Air Cooled 2 Stroke" AND "Multi-Purpose Outdoor". Penzoil also offers yet another multi- purpose oil but it does not have the 4130 # on it. That is the one that is available at my local Wal-Mart. I just bought a case from LEAF about a week ago and as of then they still had it.
Ed Diebel ( FF# 62)
Dwight
PostPosted: Fri May 02, 2008 6:08 pm    Post subject: Re: Pennzoil 2 cycle oil OUT OF PRODUCTION Reply with quote
<The product labeled "air cooled 2 stroke" is gone, replaced by "2 cycle outdoor" which is the same thing. Whether the "outdoor" product is being discontinued I don't know, but this may be the source of the confusion.
If you look on the back of both bottles you have mentioned you will find that they BOTH have the same stock # which is 4130 . The 4130 is located just above the bar code. It is the same # on the " Air Cooled 2 Stroke" AND "Multi-Purpose Outdoor".>
There are two (or more) Pennzoil 2 stroke oils. The one that the UL community has had such good luck with is now packaged with a blue bar on the bottle. The important thing is that on the back it is rated TC.
The other 2 stroke outdoor Multipurpose oil has been labeled with a brown bar on the front and on the back it is rated TC3 or TCW or something like that. (I'm to lazy to look it up right now) Bottom line is the TC rating is the one that was tested many years ago and was praised so highly for AIR Cooled engines. TC3, TCW etc is primarily for water cooled 2 strokes, IE: Jet Skis, outboards, maybe 582s but not as good as TC rated oil for aircooled 2 strokes.
Water cooled engines do not develop the hot spots that an aircooled engine does thus they dont need as high a quality base stock to make their oil.
Apparently Penzoil figured their Multipurpose oil was good enough for weedeaters, chainsaws, etc since they say it is also for aircooled engines.
When my weedeater seizes up I say screw the lawn work and go in the air conditioning and have a beer. If my 447 seizes thats a whole different matter :^(
When the supply of the true Pennzoil Air cooled 2 stroke oil (TC) dries up, then I guess we'll have to run what ever is available, but dont be confused thinking that the brown bar label tc3 / tcw oil is the same thing or just as good. It isnt....
Dwight
