Help with radio intereference
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
andrew.mcmenamin(at)xtra.
PostPosted: Sat May 03, 2008 10:38 pm    Post subject: Help with radio intereference Reply with quote
I hope someone can help me! I have little technical knowledge and may have some of the technical terms incorrect but would appreciate any advice.
I fly a Skyranger with a Simonini engine, at a controlled airfield. The Simonini is an Italian two cylinder, two stroke liquid cooled engine with dual Ducati ignition; two plugs per cylinder. It performs best at over 5000 rpm. I have significant problems with noise on the radio. I have a microair radio and a DRE 4000 headset. The radio is beautifully clear on the ground with the engine not running. After start up, I get an RPM – related interference which makes the radio very hard to hear over 5000 rpm – i.e. at cruise. I am also told the Tower find it hard to hear me. I can overcome it by reducing RPM to 4000 before transmitting but this is not desirable!.
The interference reduces noticeably as I cut each magneto in turn at the full power ground run up (when listening to the ATIS). This makes me think it is ignition related.
The spark plugs are NGK resistor plugs. The plug caps are standard, no resistor and non-shielded. The HT cables are NGK “racing” – i.e. copper core, no apparent shielding.
The radio is positioned beside the two magneto switches on the dash, and shielded by the aluminium firewall from the mags. It is not shielded from the mag switch wires.
I suspect the problem is to do with the HT cables, or the plug caps, or possibly the wires to the mag switches. I have read that I should not use resistor caps when already using resistor plugs. Should I use different HT leads??
Andrew
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
reichec
PostPosted: Sun May 04, 2008 3:20 am    Post subject: Help with radio intereference Reply with quote
I would start with trying to shield the plug wires first, also you should have shielded p lead wires goign to your switch grounding the shield at both ends. also check that your antenna base is well grounded thru the screws into the airframe and that belly oil or other gunk hasnt gotten underneath the antenna mounting, seal those antennas with a good sealant like pro-seal or fuel sealant for a long life seal, I also throw some whitesilicone over the screw heads if the antenna is the thru hole mounting style.
Good luck with what sounds like a non typical flying contraption!
safe flying!
Charles
romott(at)mi-connection.c
PostPosted: Sun May 04, 2008 4:39 am    Post subject: Help with radio intereference Reply with quote
I would try replacing the solid wire HT. I have a noise problems with my
electronic ignition system - Jeff Rose Electroair on my Velocity.
In my research into the problem, the resistance wire used with high energy
ignition systems is key to reducing ignition noise. I tried to find the
article that I had saved - but can't find it right now. Interestingly
enough, I have a Garmin 430 and a Microair 760. Guess what, the cheap radio
doesn't pick up the noise - it is the high dollar Garmin 430. Turning off
the Electroair makes the noise go away.
Time: 11:38:36 PM PST US
From: "Andrew McMenamin" <andrew.mcmenamin(at)xtra.co.nz>
Subject: Help with radio intereference
have
5000
the ground with the engine not running. After start up, I get an RPM -
rpm -
desirable!.
think
resistor and non-shielded. The HT cables are NGK "racing" - i.e. copper
use
HT
leads??
Andrew
Float Flyr
PostPosted: Sun May 04, 2008 4:48 am    Post subject: Help with radio intereference Reply with quote
Sounds like the same type of ignition they put on the Rotax 582. That engine uses both resistor plugs and resistor plug caps (5k plugs BR8ES and 5K resistor caps.) Btw they recommend you only buy solid core plugs, not the ones with the screw on terminal. The solid core plugs have a stronger heavies top than the aluminium screw on clip. The general rule of thumb is to use either resistor plugs or resistor caps... The Duc ignition seems to be the exception that makes the rule.
It that doesn’t work. You can then try looking at shielding your spark plugs or installing an antenna a bit more distant from the engine... I’ll go out on a limb here and bet one full bubblegum the resistor plugs and resistor caps will do the trick. Any takers J
Noel
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Andrew McMenamin
Sent: Sunday, May 04, 2008 4:06 AM
To: avionics-list(at)matronics.com
Andrew
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sun May 04, 2008 5:08 am    Post subject: Help with radio intereference Reply with quote
Shielding the P leads is a good idea. It should be part of the original installation, but... only shield them at one end, where the ground should be strongest. Typically this will be the engine end however some switches have grounded cases at which time the shield should be grounded at the switch end. Shields should NEVER be grounded at both ends because if there is a difference in the strength of the ground from one end to the other (there will be) you have just constructed a capacitive couple to make the interference worse.
Noel
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Charles Reiche
Sent: Sunday, May 04, 2008 8:43 AM
Subject: Re: Help with radio intereference
safe flying!
Charles
----- Original Message -----
From: Andrew McMenamin (andrew.mcmenamin(at)xtra.co.nz)
To: avionics-list(at)matronics.com (avionics-list(at)matronics.com)
Sent: Sunday, May 04, 2008 2:35 AM
Andrew
href="http://www.matronics.com/Navigator?Avionics-List">http://www.matronics.com/Navigator?Avionics-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
jetboy
PostPosted: Sun May 04, 2008 9:12 pm    Post subject: Re: Help with radio intereference Reply with quote
Its going to be difficult to properly shield the wires. NGK used to sell shielded plugs in their range I understand are not available now.
I had bad radio noise on a Jabiru installation and did some RFI testing of various types of HT lead, shielding and R plugs.
Changing from carbon HT leads to inductive resistive wire yielded the best improvement. The brand I used was Bosch so if not available something from NGK, Denso or Magnecore might be similar. Aircraft shielded harness wire was little better than plain copper. Resistor plugs helped, but using extra resistor caps would be unwise.
If your HT leads from the coil packs are not replaceable, slip a small ferrite clip-on supression bead at the coil ends, and another midway. These are obtainable from electronics stores and normally used on audio and computer cabling. I did this on my coil leads as they are copper, and it helped.
The other method is to shift the radio antenna as far away as practical from the engine.
Ralph
Ralph - CH701 / 2200a
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
